BJ8 FRONT SHOCKS
BOBBYR
Hi Gang,
I hope everyone is doing fine. I was wondering if any of you have rebuilt the front shocks on your BJ8? I surfed the net, looking for rebuild kits and maybe an article or two, but didn't find anything. Any help with this is appreciated.Thanks again.
Bobby R
roscoe
There are several threads on this site that have dealt with this. I've gone as far as obtaining some garlock type seals that require only slight machining of the housing and would fit both sides of the shaft with the intent of at least being able to reseal them. After disassembling a spare unit, I've come to the conclusion that for the price (around 100 bucks exchange), you cannot beat World Wide Auto Parts(google NOS Imports)for a guaranteed rebuilt unit that has upgraded seals etc. It was fun, but not that much fun. There appear to be absolutely no parts for these units except the valve mechanism) through any of the usual and not so ususal vendors. They were made to be throw away items as far as I can tell.
Keoke
Hi Bobby, Search White Post Restorations . They are in White Post VA and do excellent work. ---Fwiw--Keoke
John_Progess
It is not that difficult to replace the seals with modern double lip seals. There are two different sizes as the shaft is stepped down. You need to mark the internal cam that the two piston rods attach to so that when you reassemble the shock has the same range of motion. When I did my BJ8, the seals were different sizes between the two shocks so you will have to dissassemble the shocks before purchasing new seals. They were all .250" wide but different OD and ID. If the shaft is scored you will also have to purchase speedy sleeves to install under the seals in which case it will be cheaper to have them rebuilt. Hope this helps and have a good day!
John
BOBBYR
BOBBYR
Hi Guys,
Thanks for getting back to me on this. I have seen some sights that have some pretty good prices on these units so I am thinking of buying them. The two in the rear are fine, but the right front is pretty well shot. I guess I'll buy two for the front right now. That should get the control back into the old girl. Thanks again for your response.
Bobby R
fwtexasbj8
Bobby,
I am going to replace mine in the next month or so. Care to share where you have found the best prices?
BOBBYR
BOBBYR
Hi Doug,
Google (NOS auto parts) and check out their prices.I have priced out front shocks for over two hundred each.This company is around ninety each plus a core charge.If these shocks are as good as they say,that's a really good deal.Good luck.
Bobby R
Lin
Peter at World Wide Auto Parts is your answer. I have had two sets of shocks rebuilt by Peter's company, and will send him my Bugeye shocks before long. Great quality, great price, great person to work with who knows his shocks and knows Healeys.
Lin
fwtexasbj8
Thanks,
I had found them for $90 each. Just wanted to be sure someone hadn't found a better price.
AUSMHLY
Lin
FWIW guys, I'd go with a recommendation from one of the guys here, about the sellers knowledge and quality. I would not shop around for the cheapest/best price. I would pay a premium for the good stuff.
If one of the guys here has his product and recommends him, I would not think twice about his price.
"The bitterness of poor quality remains long after the sweetness of low price is forgotten."
Cheers,
Roger
Keoke
BOBBYR said:
Hi Doug,
----Yep N you will need it . Didn't your security system give you an alert! when you hit the page?? A word to the wise is sufficient and you have had plenty of good words.--- :hammer:-Keoke
Bobby R
AUSMHLY BJ8 replacement front Lever Shocks keeps leaking Austin Healey 40
S BJ8 Shocks and Front End Austin Healey 15
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 2
crispy BJ8 Front Suspension Austin Healey 9
pkmh Front Spring Removal For BJ8 Austin Healey 8
M Wanted Bj8 left front wing Austin Healey Classifieds 3
maxwedge5281 Front Shroud Differences: 3000 vs. BJ8 Austin Healey 5
AUSMHLY BJ8 Front End Squeak Austin Healey 25
G BJ8 Transmission Front Seal Austin Healey 10
AUSMHLY 65 BJ8 Front Single Lamps Austin Healey 35
thibault BJ8 plus 55mph Front end shaking Austin Healey 100
pkmh Refurbishing BJ8 Front Grille and Surround Austin Healey 21
J front cross member height from bottom to floor on BJ8 Austin Healey 5
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
wangdango BJ8 front seat redo? Austin Healey 8
4tecdog BJ8 front wheel alignment Austin Healey 11
F Front brake hose BJ8 Austin Healey 4
F front brake hose 67 BJ8 Austin Healey 4
B Front springs for phase 11 BJ8 Austin Healey 1
D Front apron panel on BJ8 Austin Healey 4
G Correct location of front turn signal on bj8 3000 Austin Healey 3
R BJ8 Front Caliper Seal Austin Healey 1
J BJ8 front outrigger Austin Healey 2
R BJ8 Front Brakes drag some Austin Healey 9
Intrisk BJ8 Front suspension screwed bush housing / threaded bush housing re-assembly gap Austin Healey 1
D BJ8 Front Seats Foam on Back Pan Correct Fitting Austin Healey 4
Patrick67BJ8 Photos Needed of Front Wiring Routing - BJ8 Phase 2 Austin Healey 11
C question on the front brake lines for BJ8 Austin Healey 2
Patrick67BJ8 1967 Phase-2 BJ8 - Front parking & turn signal lights alignment Austin Healey 8
AUSMHLY BJ8 left front directional problem Austin Healey 17
G BJ8 Front Emblem Austin Healey 45
AUSMHLY BJ8 front bump stops Austin Healey 1
pkmh Dismantling BJ8 Front Hub From Caliper Disc Austin Healey 20
wangdango BJ8 front fender removal? Austin Healey 8
BoyRacer BJ8 front stub axles & hubs for bolt on wheels Austin Healey 0
J Healey BJ8 Front Shroud Phase1 / Phase2 ? Austin Healey 7
J BJ8 front kick panel attachment? Austin Healey 3
S Front bumper brackets - BJ8 Austin Healey 2
S New Front Hubs, Rotors and Bearings on BJ8 Austin Healey 19
J Late BJ8 front suspension question Austin Healey 18
D Front wheel bearing adjustment BJ8 Austin Healey 4
J I need a dimension on a front shock for BJ8 Austin Healey 2
N BJ8 front Shroud Austin Healey 3
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
