BJ8 Drain Channel Removal
titi
Hi guys,
Has anyone removed the drain channel under the rear hood without dismantling half of the car?
It seems almost impossible as the rear shroud is keeping it in place and I would not like to bend it up.
Regards & thanks for your hints.
titi
Patrick67BJ8
Hi guys,
titi
When myHealey was painted the shop forgot to reinstall the drain channel and they twisted it and reinstalled it. No problem if you have to have help, more than two guys, lol.
bob hughes
Wow
That must have been some wrestling match, I have discussed methods with Bill Rawles and apparently it is possible, but you still have to lift the shroud up a bit at the front. Charley said remove the shroud and get at it that way. I am in the process of rebuilding the back of my BJ7 and for various reasons I removed the shroud. I am currently torn between trying to repair the original drain channel which I thought was reasonably ok until I had it blasted, or to replace it with a new one which I bought some years ago. The new one does not fit properly and so far I have managed to wrangle the back of it into something like the correct shape by jamming it into an opening in the coping of a brick wall and pulling it around to ease the large bend a bit and comparing it with an MDF template that I have made. The two corner bends now need attention but with the cold wet winters we have here I am waiting for spring. Regarding the original one, I have tried welding some of the newly discovered holes with some measure of success but there is a matter of the weld bumps inside the channel area which will be a pig to grind down, I have an idea to remove the front of the channel ( it is an add on anyway and replace it once the bed of the channel has been sorted) alternatively I could patch it with P7 but that would be a bodged job. Sorry to have pirated your thread but it kind of fits in places.
:cheers:
Randy Forbes BJ8 top drain channel questions... Austin Healey 10
Patrick67BJ8 Copper Drain Lines for BJ8 Carb/Intake Manifold Austin Healey 30
Lin BJ8 convertible drain tubes Austin Healey 7
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
AUSMHLY BJ8 Overdrive Oil Passages Austin Healey 2
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
