BJ8 top drain channel questions...
1st, is the top drain channel around the rear of the cockpit removable?
2nd, is this done by removing all the pozidrive screws that secure the chrome trim that surrounds the rear of the cockpit?
I just checked the parts manual, and I don't see a separate piece listed...
I already have the top (and its rear retaining piece) removed.
Thought I'd ask, before I needlessly disassemble any more of this man's car :blush:
Thanks!
Keoke
NOPE!!----Keoke-- :laugh:
Randy Forbes
... stepping awaaay from the screwdriver!
Thanks!
Considering that all five (5) drain holes were plugged (and a few hoses split) it really isn't in that bad of shape; I just wanted to hit it good with Extend, and not have it go all over the things I don't want extended.
John_Progess
I did remove the drain channel to repair some rust damage. You will have to remove the chrome trim. I don't remember if you have to remove the section of upholstery that covers the wheel wells in order to get to the screws. Hope this helps and have a good day!
John
Randy Forbes
Thanks John, I did receive some pictures of one removed from the car (thank you, Patrick) but decided that its condition was sound enough to just treat it with Extend in situ.
I wouldn't want anything bad to happen to the chrome piece while it isn't in the car... :wink:
Apparently, this car's owners are just about to move to Los Cruces, NM, so I guess moisture won't be much of a problem for it in the future!
Patrick67BJ8
Legal Bill said:
Ummm, isn't it welded into place?
No. I sent Randy pictures of mine sowing the "holes" that were used to fasten it to the body. Maybe Randy will post the photos?
Patrick
Randy Forbes
On cue:
Patrick67BJ8
Legal Bill said:
Thank you both. I plan to leave mine right where it is, but I had no idea it was held in with screws.
I can top that!! I didn't even know it was a piece by itself. I thought it was, you know, just there and did it's thing. Jule Enterprises sent it back to me with my refinished subchassis so I'm happy.
Patrick
bob hughes
Every thing is removable Keoke. It's just that the drain channel is riveted in place onto the rear shroud, you will therefore need a respray after you have sorted your original drain channel problem out. :laugh:
D BJ8 Top Installation Detail Austin Healey 3
JamesD BJ8 Top Frame Bumpers Austin Healey 12
M 1966 BJ8 Top Austin Healey 1
RAC68 Cuts in BJ8 Convertible Top Austin Healey 5
RAC68 Repair Traditional Cuts in BJ8 Convertible Top Austin Healey 18
I BJ8 soft top frame dimensions Austin Healey 4
C Top frame pinching soft top - BJ8 Austin Healey 6
Marvin Gruber BJ8 top installation Austin Healey 9
Marvin Gruber BJ8 convertible top recommendation? Austin Healey 0
wangdango BJ8 dash top redo? Austin Healey 1
J Stress Reliever while installing new top on BJ8-smashing the Christmas lights Austin Healey 5
J BJ8 Inside Top Door Rails-How Attach? Austin Healey 6
B replacing BJ8 convertible top Austin Healey 5
BOBBYR BJ8 top dash pad removal Austin Healey 9
Jeepster BJ8 folding top woodwork Austin Healey 3
D Another question 1967 BJ8 top installation,metal retaining strip Austin Healey 1
Jeepster BJ8 padded dash top Austin Healey 1
C Top attachment under side flaps - BJ8 Austin Healey 5
Bob McElwee '66 BJ8 Phase III Top Frame Assembly Austin Healey 3
T BJ8 Top Installation Austin Healey 2
L BJ8 Convertible top Austin Healey 5
R BJ8 Top Trunnion removal Austin Healey 8
L Sports and Classics top for BJ8 Austin Healey 1
BJ8Healeys Installing Robbins canvas top on a BJ8 Austin Healey 12
C BJ8 Smoothline top value Austin Healey 9
AUSMHLY BJ7/BJ8 Convertible Top Austin Healey 34
tahoe healey BJ8 wind screen top weather strip Austin Healey 19
AUSMHLY How to stow a BJ8 top Austin Healey 6
A Soft Top cover and Tonneau BJ8 Austin Healey 3
B BJ7 & BJ8 soft top rear seal Austin Healey 2
B BJ7 or BJ8 soft top replacement Austin Healey 7
J Vented cap on damper piston on top of BJ8 carbs. Austin Healey 13
D BJ8 Overdrive Switch on gear leaver top Austin Healey 2
J Convertible top installation on BJ8- hidem strip? Austin Healey 3
J BJ8 soft top bows? Austin Healey 2
J BJ8- How is the chrome door top molding installed? Austin Healey 11
davidb Austin healey BJ8 - convertible top alignment Austin Healey 9
S BJ8 Convertible Top repair Austin Healey 3
GregW Measurement for shut pillar top piece BJ7 or BJ8 Austin Healey 6
bighealeysource BJ8 top installation Austin Healey 1
bighealeysource Installing a new top on my BJ8 Austin Healey 2
bighealeysource top on my 66 BJ8 Fit on BJ8 top Austin Healey 5
bighealeysource installing BJ8 top Austin Healey 3
S BJ8 Convertible Top Assembly Austin Healey 18
6 Installing a BJ8 Convertible Top Austin Healey 9
6 BJ8 convertible top trim color Austin Healey 1
A Source of Vinyl for padded dash top Bj8? Austin Healey 1
R BJ8 Top Austin Healey 7
A BJ8 Convertible Top Wood Source? Austin Healey 2
A bj8 Convertible Top Drip Rail Help Austin Healey 4
