Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
Is the door seal applied only to the side and bottom channel of the door or is it continued over the top of the lock side of the channel until it meets the rear side trim panels.
Also, is there a seal on the front fender, between it and the door?
The door seal continues onto the trim panel and the end is finished with a chrome U clip (see picture below).
There is a seal on the front fender. For the BJ7, it is a separate piece of the same trim that is used on the windshield pillar. The Anderson Moment book shows it clearly.
I believe there is a seal of some sort between the drain channel and rear shroud. I recall seeing something in the BCS catalog. When I install mine I think I will probably just use Dum Dum between the surfaces as needed.
Thanks for the valuable info. What I realized was that the chrome trim strip going around the back of the shroud completely covers the gap between the drain channel & shroud, so I ended up doing nothing. I imagine that if it leaks later I will remove the chrome & seal the seam under the chrome.
Greg is right .. the drain channel goes under and behind the shroud lip so there should be no 'gap'. Sounds like you may have your drain channel on the wrong side?
I'm using dum dum just to isolate the steel from the aluminum and to provide some type of seal. The seal from BCS may just be a thin rubber gasket between the chrome piece and shroud but not really sure.
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
