BJ7 Rear Disc Brake Setup
MCS
Hello,
I am looking at rear disc brake options for my BJ7. I am doing this because I like the look, I do realize that the stock rear drums work excellent.
I have looked at Denis Welch kit, looks nice but very expensive. Was thinking if I purchased the disc brake adapters from one of the suppliers I could then use XJS jaguar calipers, not sure who's rotors fit.
Any suggestions would be appreciated.
Thanks Phil
Lin
I use the CapeSport kit and while I am pleased with the product, those Jag calipers are heavy. CapeSport now has a second edition product that has lighter calipers and it appears to have an improved handbrake mechanism. Check it out. Let us know what you end up doing.
Lin
M
MCS
Hello Lin,
I had a look at Capes kit ,looks good, just a little more then what I wanted to spend. I may go that route in the end. Sent a PM to Richard, will look at his product.I converted my sprite to rear disc brakes, the total cost was about $ 700.00, that included at $150.00 cable for the park brake.
Phil
John Turney
I have the Denis Welch kit with a Nissan B210 master cylinder that engages the front discs first, which provides good front/rear bias. My only problem is the handbrake as others have noted.
M
MCS
Hello John,
Did the Nissan 210 Master cylinder fit ok or did you need to do some cutting
Thanks Phil
John Turney
MCS said:
Hello John,
Thanks Phil
It fit quite well. If I recall correctly, I used the old push rod, the mounting holes are almost the same as the Girling MC on my BN4.
It is a dual circuit MC with the tubing coming out the bottom. I made two short (~12") sections of tubing from the MC to unions so I didn't have to try to connect the tubing under the MC where I couldn't see what I was doing and couldn't get the connections tight enough. (Even silicone brake fluid burns on a hot exhaust header!)
The tubing from the MC that runs to the front brakes (the one closest to the driver) goes to my 5-way union with the brake switch. I plugged the opening in the union that went to the rear brakes. The tubing from the MC to the rear brakes bypasses the 5-way union.
R BJ7 Rear Axle Maintenance Austin Healey 5
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
chicken BJ7 Rear Quarter Panels Austin Healey 6
D BJ7 Rear rail trim Austin Healey 0
B Rear shroud connection to the floor pan on a BJ7 Austin Healey 21
P Rear Seat Pan Bolt Hole Locations on a BJ7 Austin Healey 1
Griz Rear reflectors BJ7 Austin Healey 32
T BJ7 Slipping Clutch? rear main seal? Austin Healey 11
G Early BJ7 rear window fittings Austin Healey 2
B Spacer between rear air filter and carb - BJ7 Austin Healey 11
B BJ7 & BJ8 Interior Rear Quarter Panels Austin Healey 12
B Tow Hooks for the Rear of a BJ7 Austin Healey 10
rjc157 BJ7 Rear seat Back Austin Healey 5
healeydan BJ7 Top Rear Curtain Questions Austin Healey 7
maxwedge5281 1963 bj7 rear interior trim Austin Healey 45
B Installation of New Rear Seat Surround Panel for a BJ7 Austin Healey 8
maxwedge5281 rear seat pans for bj7 Austin Healey 2
B BJ7 Rear quarter panels Austin Healey 0
C Rear seat panel BJ7 & ignition coil help Austin Healey 14
B BJ7 rear reflector Austin Healey 1
B Rear soft top bow on a BJ7 Austin Healey 15
B BJ7 & BJ8 soft top rear seal Austin Healey 2
M BJ7 rear window ["backllight"] Austin Healey 0
D rear seats BJ7 Austin Healey 1
chicken BJ7 rear seat pans Austin Healey 0
chicken mounting of rear seat pans for BJ7 Austin Healey 14
R BJ7 rear drain channel- Seal or not? Austin Healey 6
B BJ7 Rear Seats Austin Healey 3
R Holes in rear shroud-BJ7? Austin Healey 1
5 WTB: BJ7 Squab Austin Healey 13
5 BJ7 Boot Rust-Through Austin Healey 13
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
R New Hood for BJ7 Austin Healey 3
chicken BJ7 Chrome Trim Austin Healey 15
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
R Changing BJ7 Differential Ratio Austin Healey 10
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
chicken BJ7 Door Fit Austin Healey 27
T Wanted BJ7 parts needed Austin Healey Classifieds 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
D BJ7 Clutch Austin Healey 6
R BJ7 Back Seat-Rest Austin Healey 1
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
