Bizarre turn signal issue
SteveHall64Healey
I’m having an issue with my turn signal that I’m struggling to diagnose - any help would be appreciated.
With the ignition ON:
- the left signal F/R signal lights both light, flash and then cancel correctly. The indicator on the dash does not light as it should (bulb verified ok)
- the right signal F/R both light, flash but do not cancel and then remain on until the ignition is turned off. The indicator on the dash lights correctly.
- If I remove the P-lead from thre flasher, both dash lights flash when switch is in the right signal position
Here’s what I’ve done:
- verified that the signal switch on the column works correctly using an ohm-meter: left signal side has continuity only when switched left and same for right side. No continuity between the common lead and either side when switch in center position. No continuity to ground or between any wires in left, right or center position.
- replaced 3-prong flasher unit. Existing unit had 39.4 ohms between L and X terminals, new one has 33 ohms.
The car is a BJ8 phase 1, with positive ground.
Any ideas?
thanks,
Steve
S
SteveHall64Healey
Steve,
Thanks. I checked continuity between the horn wire and the right turn signal wire and there is zero ohms. Infinite ohms between the horn and left side. I think you’ve nailed the problem. Is there anything I can do short of replacing the turn signal unit?
thanks,
Steve
steveg
Steve,
thanks,
Steve
You buy the stator wiring harness from probably AutoFarm (or in the US, Moss or British Wiring). Not expensive. Probably nothing wrong with the trafficator mechanism itself.
For how-to info - see this great pdf by forum member Lin Rose - with lots of color photos:
https://www.healey6.com/Technical/Trafficator%20Repairs.pdf
Do a search here for previous posts on pulling the wiring through the stator. (apologies for the underscore - don't know how to remove it)
steveg
This isn't everyone's cup of tea. I've removed my trafficator so many times I decided to make it really easy.
Molex connector attaches with a rare-earth magnet. Lower set of wires in pic permanently attached to wiring harness. Upper set to trafficator harness. I put shrink tube around the wire ends as a bunch and simply push them through the stator tube.
RTaillieu
It sounds like the DB10 relay box is acting up, that box hidden on the left inner fender in the engine bay.
The June Healey Marque magazine has an article on what it is and how to check it out.
All the turn signals and brake indications go through this box.
BJ8 phase one's have the box, phase two's don't.
Check out the "Lost 8 terminal flasher relay" thread.
Rick
64 BJ8 Ph1
ozhealey
Steve,
SteveG’s advice is good to look into the trafficator. As is Rick’s to look at the relay box (assuming you dont have separate park/stop/indicator lights).
I just this weekend dismantled and rebuilt (cleaned up really) my trafficator and installed a new wiring loom. I was having intermittent turn signal faults which were a bugger to diagnose (as an electrical engineer I was beginning to question my skills). Turns out the small brass nut on the green wire deep inside the trafficator had come lose over the years and fallen off and so I was getting intermittent contact. All is now good in the world and I am back to full health on the Healey.
Where did you find the short between the horn and left turn signal? Did you disconnect the trafficator wiring loom from the main loom before doing the continuity checks? I assume the horn short you describe is the brown and black wire which while “live” as SteveG indicates, is only the earth path for the horns but would explain some gremlins.
At least if you disconnect the looms, you can isolate any shorts to the trafficator or back in the main system somewhere (perhaps the relay).
Cheers
Tony
steveg
Deferring to those with superior technical knowledge...not sure how it happened but one of my Healey friends had a situation where one of the wires in the trafficator harness had shorted and burned away insulation between the wires. His horn would sound with the car not being driven, just sitting there.
That's the origin of my wiring harness suggestion.
RAC68
Hi SteveHall,
I have already experienced the loss of the left hand turn signal on my BJ8 Phase 1 and, after evaluation, determined it was from a fault in my 54 year old 8-terminal Flasher Relay Box (located behind the brake fluid container, mounted on the inner fender under the 4"Cold Air Duct - see recent past thread). First, how is your Brake Lights working? The Lucas DB10 Flasher Relay Box is the unit which allows the sharing of the Brake and Signal lights on the same filament of the 2-filament rear bulbs and, when the Trafficator is switched left or right, is the intervening box that send power to the appropriate lights (front/back) along with the proper dash indicator. If the Brake is applied on a turn, the side opposite to the Turn indicated, via the Turn Signal Flasher, will display as a solid (non flashing) Brake light. This indicates that, in functional operation, the Turn Signal is dominant and the Brake light secondary.
As a fast check 0n the operation of the Trafficator and Flasher Relay Box, I would:
1# Set the Trafficator for a Left hand signal. If properly linked, terminal 1 (Turn Signal) and terminal 4 (Left Hand) should show battery power. If not, a fault in the Trafficator or its wiring is probable. Also, Terminals 3 & 4 should also show power to the left hand front and rear bulbs as well as the dash turn indicator.
2# By setting the Trafficator for a Right hand signal. Terminals 1,8,6,7 will show power.
If I were to find power not arriving at 1 (turn signal switch) and 4 or 8 respectively, I would first check the ground on the Flasher Relay Box before going further. Keep in mind that the Flasher (not the Relay Box) can also cause difficulties in its connection through the trafficator.
Hope this helps,
Ray(64BJ8P1)
ozhealey
SteveG,
The melt down you describe could indeed have been related to a fault inside one of the horns developing which shorted the brown/black wire and power wire to the horn, or perhaps the power green wires in the trafficator shorting to the brown/black wire or earth. As I said above, the nut came off my green wire and was “floating” inside the trafficator and this nut could have caused all sorts of faults if it had shorted some of the bolt on contacts in the trafficator.
Cheers
Tony
The_architect Bizarre speedometer problem Spridgets 8
Brosky Bizarre cooling leak....intermittent, too!! Triumph 0
JPSmit OK - This may be the most bizarre yet! Spridgets 9
B A bizarre Bugeye story and a surf buddy Austin Healey 3
racing girl Just Plain Bizarre... Other Cars 12
Sherlock Very bizarre "custom" vehicles on E-Bay, Other Cars 13
Carlbanan56 MGB Mgb turn signals MG 17
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
K 68 midget. No horn, headlights, turn signals Spridgets 9
J MGB help, turn signals do not work MG 3
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
K TR2/3/3A The horn and turn signal assembly. Triumph 3
KVH General TR Green Turn Signal Dash Indicator Triumph 8
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
6 Turn Signal Flasher Spridgets 8
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
bighealeysource Turn Signals Austin Healey 21
B General MG Turn Signal Issue MG 1
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
G Engine Will Not Turn Off Austin Healey 10
M Europa turn signal problem Lotus 7
Rob Glasgow Turn Indicator Austin Healey 17
doakley Spitfire Turn Signals Triumph 3
R Spitfire Turn signal wiring Spitfire Triumph 5
J T-Series Won’t turn over MG 23
S TR2/3/3A Rear turn signal lamp and trim installation Triumph 5
BierRunner TR6 Turn Signals/Hazards don't work Triumph 16
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
T TR2/3/3A turn indicator bulbs Triumph 26
Got_All_4 TR5/TR250 Lost Turn Signals Triumph 2
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
BoyRacer LED Turn Signals Austin Healey 5
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
R Turn Signal Knob goes off center Austin Healey 9
E MGB Turn signal bulb MG 5
E MGB Turn signals 65 mgb MG 4
M For Sale chrome turn button fasteners Austin Healey Classifieds 8
steveg Picture needed - front turn light Austin Healey 4
Nelson Turn signal beeper. Spridgets 14
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
nichola TR6 GP3 Camshaft won't turn Triumph 8
M TR6 Turn signal switch stalk Triumph 1
W MGB Turn signals on 78 MGB MG 3
jfarris TR2/3/3A Modified turn signals/brake lights on a 56 Triumph 6
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
