Best alternative option to sleeved thermostat?
cpbol
After doing plenty of reading, it sounds like the OEM style sleeved thermostat is the preferred/recommended style thermostat. My question is, what is the next best alternative? Are you better off running a modern thermostat without the sleeve and lose 25% of your flow through the bypass, or are you better off running the block-off sleeve and no thermostat at all? The context of my question is relative to cooling efficiency - not for using the heater (since we all know heat is not hard to come up with in a Healey!)
When I first bought my Healey__1978__there was nowhere near the parts availability that we enjoy today; I think my first Moss Healey catalog had about 12 or 14 pages.
In any case, we used what we could get our hands on! I used non-sleeved thermostats (160* to 180* ranges) or gutted thermostats for years with no known ill effects.
Nowadays, I used a sleeved thermostat__because I can__and figure here in Florida, I'd better give my cooling system all the proper fitments that I can.
Healey Nut
If I lived in Florida I would take the **** thing out and drive without it. We all know that Healeys run hot and if you do decide to take it out on a cool evening then a chunk of cardboard to block of a section of the radiator works like a charm.
RAC68
Hi All,
As I understand, the thermostat not only controls internal coolant heat but also flow. When running without a thermostat, you will eliminate any control of both and therefore it will take longer for the engine to heat up as well and assume a temperature more conducive for allowing lubricants to be operationally effective. As a result, the period when engine wear is most prevalent will be extended as will the time before efficient fuel burn. Add to this condition is the fact that it takes a period of time in contact for coolant to absorb heat from the engine and give up heat through the radiator.
Therefore, without a thermostat the flow rate and volume of coolant will be fast moving and could pass through the engine and radiator at a rate that will be less efficient for heat transfer to and from your coolant. The result, a longer period of initial engine wear due to slower warmups and higher running temperatures due to fast-moving coolant at driving RPMs.
There are many issues with the Healey Cooling System's design, but I don't believe eliminating the thermostat is much of a fix.
Ray(64BJ8P1)
DerekJ
Ray is correct. There seems to be so much misunderstanding regarding thermostats with some people believing they control the temperature that the engine runs at, which of course they don't. Removing the thermostat would mean the engine takes longer to reach operating temperature and therefore is more likely to suffer wear. That is why in cold temperatures you need a higher temp rated thermostat and vice versa.
Patrick67BJ8
I lived in Florida fir about 6 years. Taking the thermostat out didn’t help one bit as many club members there found out. A good cleaning of the radiator, correct timing, correct fuel mixture helped.
steveg
Every car I know of, old and new, has a thermostat. The factory accountants would have made the engineers leave them out if it could be done without.
IMO the best argument for is DerekJ's - most of the wear occurs when the engine is cold: cold longer = more wear.
mctriumph TR2/3/3A the best kinda folks Triumph 2
K TR2/3/3A What is the best way to prevent the crank from turning ........ Triumph 27
tr6nitjulius For Sale "SOLD" Winter projects: Upgrades 4Sale or Reasonable Best Offer Triumph Classifieds 0
AngliaGT MGB-GT The Best Laid Plans....... MG 3
69MGC T-Series Best Technique to Clean a Canvas Top MG 3
Michael Oritt Best Seat Trim Adhesive Austin Healey 8
J Best Aluminum Fenders? Austin Healey 3
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
G Best fuel option for a 72 Midget Spridgets 5
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
JPSmit some days your best tool is a credit card Spridgets 2
dripdripdrip TR2/3/3A Best place for tonneau & hood stick covers? Triumph 2
D The best place to get shocks rebuilt. Spridgets 8
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
W Best source for Bugeye front shocks Spridgets 3
J For Sale For Sale - 2x TR6 seats in red vinyl - Best Offer! Triumph Classifieds 1
Bob Claffie Best cruise in of the year Spotted 8
longbridgehealey Best way in Austin Healey 2
B TR4/4A What really is the best clutch/bearing combo Triumph 4
I Best glue for rubber door panels? Spridgets 3
N Best cam choice??? Spridgets 5
R TR2/3/3A Best day ever [so far] Triumph 1
C How best to restore red script on valve cover? Austin Healey 7
F Best $25 I've ever spent on my Healey - 2019 Austin Healey Concours Guidelines Austin Healey 0
FlyingCat Spitfire Which carburetor is the best? Triumph 9
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
D Best little tube bender Restoration & Tools 8
N Best lube for a Datsun gearbox?? Spridgets 6
Kleykamp For Sale 1978 MG Midget Best Offer Spridgets Classified 0
DornTRoriginal TR2/3/3A Electrical Wiring Best Practices Triumph 13
I General TR Best car cover Triumph 8
M Best Interiors Austin Healey 20
Jer Confirming the best choice for clutch / release bearing for my 67 Midget Spridgets 2
N Best carpet glue???? Spridgets 5
S Best Ethylene Glycol/Water Ratio to avoid overheating? Why? Informal Survey. Austin Healey 27
B best diff British Motor Corp 5
Boink Pre-War MG-TB wins best in class at Forest Grove Concours MG 7
T TR2/3/3A What is best way to flush engine after antifreeze got in oil?? Triumph 2
GTP1960 Not the "best car ever made" by a long shot Other Cars 14
glemon Mercedes 450SL Best Car Ever Made? Other Cars 7
MisterB Spitfire Best year for a Spitfire? Triumph 12
D TR4/4A Best SU overhaul service to use? Triumph 10
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
Gerald_Gordon TR4/4A Best carpet for TR4 Triumph 2
C Best Replacement BN1 Leaf Springs Austin Healey 5
Jim_Gruber Headlight Trim Rings on my BE - Removal - Best Methods Spridgets 5
A Best fibreglass/GRP Bugeye bonnet Spridgets 21
D TR2/3/3A Best TR3B seats - repair or replacement? Triumph 11
Popeye TR4/4A Best way to transport a bare tub? U-haul utility trailer? Triumph 11
