TR2/3/3A An odd 56TR3 Commision Number?
karls59tr
Bronze
A Triumph club member here is restoring a TR3 with a "6" in front of the TS on the Commision plate.
Anyone seen this and know the significance of the 6?
TR4nut
Could be wrong but I thought cars that came into Canada from the factory had the date code at the beginning -6 stood for 56?
UK to Canada import as Don reports.. I am highjacking the thread for a second. I've had a couple of TR4a's that had a 1 in front of the CTC (1CTCxxxxxx) commission number, was that a dealer thing or anyone know anything about that.
Marv
Andrew Mace
Marv
Marv, I suspect that more likely indicates a car assembled in Belgium, usually for European Continent delivery but occasionally for US (Belgian-assembled Spitfires were not uncommon here). Anything unusual about either of those 4As, such as German-spec. lighting, etc.?
Vila
I have the same thing with my 1962 TR4 Commission number, it has a 2 in front of the original number.
Shortly after buying the car I found out about a Canadian requirement for the first digit of the vehicle number to start with the last digit of the year the car was originally sold.
It turns out that when I got my British Motor Industry Heritage Trust certificate my car was made in the UK and had in fact been originally imported to Canada.
I don't believe the 2 was not originally on the plate since it does not line up with the other numbers.
Visit my new and improved personal website at: www.jakegingervila.wix.com/bobs-vintage-cars-
Vila
1933 Chevrolet
1962 Triumph TR4
1984 BMW 633 CSi
NeilRogers
Member
Some Canadian provinces (possibly Ontario) may have required a number to be stamped in front of the commission number, but it was definitely not a Canada wide thing. My car was sold new in Edmonton, Alberta and does not have any extra numbers stamped on the commission plate. I have never seen a Canadian car with an extra number.
G General MG odd but true! MG 8
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
K TR2/3/3A An odd thought.....vinyl wrap a TR3? Triumph 8
K TR2/3/3A An odd brake question? Triumph 2
TRclassic3 TR2/3/3A Odd observation when bleeding Triumph 5
S Engine or Tachometer Odd Problem Austin Healey 7
PAUL161 T-Series Odd spark plug encounter! MG 10
Y MGB More things that seem odd.... MG 2
Y MGB An odd (and probable long-shot) request... MG 5
R Has this ever happened to you? Any odd Sprite story... Spridgets 8
A T-Series Arkansas MG Odd Lifter Wear MG 12
sparkydave Odd discovery, but still ran OK Spridgets 1
Rut TR6 Odd wheel Triumph 4
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
K TR2/3/3A Odd question re: rear axle hitting fuel line? Triumph 4
CJD TR2/3/3A Odd Commission number Triumph 16
steveg Odd problem but it got me home! Austin Healey 9
H TR2/3/3A Odd Speedometer Behavior Triumph 3
J TR4/4A Odd Commission Number Triumph 16
D odd photo Jaguar 6
R Odd Wiring Failures Austin Healey 14
MisterB MGB New Guy- Looking at Early MGB-Odd one MG 5
AN5Sprite Source For Odd BSW Tap Needed Restoration & Tools 9
R Odd Bonnet question Spridgets 2
K TR2/3/3A Odd looking modified TR3 on Craigslist...saint luis obismo Triumph 24
DrEntropy This tops my "odd cars spotted" personal best Spotted 1
K TR2/3/3A Odd Clutch Failure...Clutch crosshaft bushing goes for a walk! Triumph 6
Flash_Harry MGB '71?? MGB on eBay - a bit odd?? MG 10
J TR4/4A Odd TR4 transmission question Triumph 10
J TR2/3/3A Need an odd part for a TR3 Triumph 4
M TR2/3/3A Tring to find odd TR3 parts again Triumph 24
T photo - odd request Triumph 5
frankenstang57 Sorta odd 1500 question... Spridgets 4
TRclassic3 TR2/3/3A Odd TR3A suspension issue Triumph 11
D Odd pair today Spotted 17
A Ignition rotor recommendations - odd failure Austin Healey 11
texas_bugeye Odd rear suspension Spridgets 8
JPSmit Odd week for odd cars Other Cars 34
BoneIdle Odd squealing in 4th gear MG 2
Sherlock A rather odd truck/motorhome Other Cars 0
B Spitfire odd noise from Spitfire rear Triumph 5
mikecyc72usa So far so good, but now an odd question Triumph 2
JPSmit odd screen in Mozilla FORUM Navigation Questions 5
Got_All_4 TR2/3/3A TR3A odd windshield studs needed Triumph 4
jvandyke odd noise from the rear [of the car] Spridgets 8
R Odd problem Spridgets 3
swift6 Odd Triumph Logo... Triumph 14
jhorton3 Odd Piece In Spring Spridgets 8
v8mgbal odd structural question Spridgets 6
