Spitfire An automatic for a Spitfire
Coastalman
I have an opportunity to get a Spitfire with a blown motor, but with a very nice body. My wife has ridden many miles with me in my Healeys so I thought this might be a chance to do something good for her. She would drive a Spitfire if it was automatic drive.
Do any of you on the forum know of a small engine with automatic transmission that could be installed in a Spitfire without a major modification of the existing body work/engine bay?
If I could make this work without a big hassle it would be fun and make my wife happy to have a LBC that she could drive.
Thanks,
Charlie
dklawson
Hey Charlie! I've been wondering how you were doing. Will you be up here for the show this year?
For the gearbox conversion are you thinking of staying with the Triumph engine or changing that at the same time? I don't know how hard it is to find an automatic Miata but I would imagine a complete Mazda engine/gearbox transplant might be a good choice. See the link below.
https://jalopnik.com/5691898/for-6000-the-spitiata-is-the-lee-majors-of-sportscars
If keeping the Triumph engine, you'll want to look for a gearbox no longer than the Triumph single rail gearbox with overdrive. You might have to modify the transmission tunnel (of the tub) if this is an early Spit. That would give you a fair amount of length to work with. Unlike the BE or Spridget, the Spitfire has a removable transmission tunnel which is fairly wide. Originals were made in a cardboard-like material and I have seen aftermarket ones in fiberglass and some form of plastic. Tunnels of the later two materials could be customized to work with larger (wider) gearboxes if necessary.
Some of the larger Triumph sedans could use a Borg-Warner (35?) automatic but I think those all bolted up to the larger 6 cylinder engines and fit cars with wider tunnels. I think some of the Triumph Dolomites had automatics but you aren't going to find those as donors in the U.S.
number6
I believe the Sunbeam Alpine used a Borg Warner type 35 auto unit coupled to the 1725 engine, not sure that it will fit a Spitfire however. I had that unit in a Rover 2000 SC and as I remember it,
it was quite wide in dimension. I have heard that Mazda rotary's are a fit for a spitfire. You might try the British V8 website for information. They cover a lot of conversions that do fit the car.
Andrew Mace
Unfortunately, the BW35 is incredibly wide, likely necessitating major surgery to a Spitfire type chassis, since the rear part of it would sit where the main rails have tapered in to little more than a "backbone"! Even the experimental TR3 with the BW35 sacrificed a good bit of foot and leg room. Plus, by today's standards, it's a pretty inefficient three-speed box.
I like the suggestion of a Miata drivetrain, in part because they're probably not hard to come by nor outrageously expensive. Otherwise, small RWD engine/tranny combos are pretty scarce these days (thinking to the days of RWD Corollas, Chevettes, Datsun B-210s and the like).
C
Coastalman
Hi to all and Doug, I was thinking about a full motor/transmission conversion. The Miata sounds good. I will check out the link. In fact, a neighbor with an automatic Miata was just telling me today that she was thinking about selling her Miata. I would probably get a better deal from a salvage yard. If I get the Spitfire I will keep everyone updated on the build.
Doug, I will not be at any of the shows in the near future. I am having back surgery on next Monday and I will not be doing any events or car work for about 4 weeks or maybe more. I am hosting the Ice Cream Social for classic British cars again in August on the 19th if you can make it down. Email lf you want details.
Now I will have time to figure out how to make the Spitfire an automatic.
Charlie
dklawson
I'm sorry I won't see you at the show. It's been a few years since we've met face to face.
I did not read all of the article I sent you a link to. However, they did mention the Miata drivetrain weighed less than the Spitfire engine and gearbox... with more power. It sounds promising. Let us know if you pursue it.
martx-5
... However, they did mention the Miata drivetrain weighed less than the Spitfire engine and gearbox...
The article mentioned that the Miata engine had both aluminum head and block. Not so, the NA, NB 1.6 and 1.8 engines have cast iron blocks with aluminum heads. The gearbox is larger also. I doubt it is lighter then the Spit engine and gearbox.
Edit: I just looked up the weights of the Miata 1.8 engine and gearbox. Engine with head, intake, flywheel, clutch & ancillaries comes in a close to 300 lbs., gearbox with TO brg etc at about 85 lbs.
What's the Spit engine weigh??
dklawson
The reference pages at the Spitfire & GT6 magazine site say the weight of a stripped Spitfire engine is 220 lbs (without the flywheel or ancillaries). They did not say which displacement engine that weight was for. The folks at Triumphexperience use that 220 lb figure for the 1500.
Paul Tegler has a page where he discusses alternate engines and their weights. Link below.
https://www.teglerizer.com/triumphstuff/performancedata/III_whichengine.htm
Paul lists the Triumph 4 speed gearbox as 42kg. Paul lists the weight of the Spitfire engine as 125kg... presumably with flywheel and some ancillaries. Adding Paul's figures a basic Spit engine should be close to 167kg (as much as 368 lb).
The article on the Miata swap may have underestimated the weight of the Mazda engine but the total drivetrain weight might still be slightly less than the standard Spitfire parts.
Charlie, be sure to look at the page I linked above for other possible engine swaps.
C
Coastalman
Thanks Art, Rick and Doug. I will do a bit of research before I jump into a project like this. I also have a local Sprite, not BE, as a possible buy, but that would not be automatic. My thinking on this is to provide a LBC that my wife can drive. I remember a BE that was at the 50th party in Pa. that I attended that had a Chevette engine with automatic in it. It was a very nice fit and worked very well. I don't know if there are any Chevettes around anymore. It was nice though.
Charlie
G Spitfire automatic tranny for a 69 spitfire Triumph 6
J TR4/4A TR4A automatic transmission conversion Triumph 6
DrEntropy Shift rod seal in an automatic? Jaguar 7
G MGB-GT 1968 MGB GT 1800 AUTOMATIC MG 0
G MGB-GT 1968 MGB GT AUTOMATIC MG 2
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Got_All_4 Stag Stag automatic Triumph 8
JPSmit MGC Automatic MGC GT for sale MG 1
NutmegCT Any Borg-Warner automatic trans experts here? Other Cars 5
JodyFKerr Stag Sourcing a Stag Type 35 automatic Triumph 4
A TR2/3/3A 1960 TR-3 V8 automatic photo Triumph 17
vping T-Series Automatic in a TD MG 3
M 1980 Mini 998 w/Automatic British Motor Corp 15
deadair TR2/3/3A TR3A with automatic transmission? Triumph 15
abarth69 MGB-GT 1969 MGB GT with automatic MG 2
S TR2/3/3A Automatic Transmission for TR3A Triumph 16
d_valentino 1969 Mini w/ automatic gearbox and air bags British Motor Corp 12
CharlieCarpenter Need Help - wiring Automatic Cooling Fan Austin Healey 9
G Early 100/6 engine, automatic transmission Austin Healey 2
jsneddon possible automatic trans question Other Cars 8
aeronca65t automatic trans question Other Cars 11
PAUL161 A Nice V6 Conversion. And, An Automatic With It! MG 20
Brosky TR6 TR6 V-8 Automatic, with optional clutch pedal Triumph 9
PAUL161 MGB MGB Automatic Question *DELETED* MG 30
7 Automatic transmission??? Spridgets 17
kyreb1862 Wedge 1979 TR7 Roadster Automatic Triumph 0
S Automatic Choke ? MG 1
skinsgamer ZS Automatic water Choke adjustment Spridgets 11
bmurphy7369 1975 XJ6 SII ZS with Automatic Choke Help Needed Jaguar 11
G Automatic choke MG 5
S Alpine MK IV Automatic BW35 Sunbeam (Rootes) 3
78Z An Automatic Lotus - how sad Lotus 7
S where to get rover automatic gearbox MG 3
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
