Amplified Antenna?
111
Now that forum members have helped me determine that my current antenna is not stock, I want to replace it with a retractable one so I can fit a car cover on. I like the suggestion of an auto retractable that one forum member has. However I just called a local shop to see what they had in stock and they are out of the auto retractable that would most likely fit my car. They said that many people favor an amplified antenna which does not have a mast at all. According to them reception is good, and they put them on classic cars, motorcycles, etc.
So I was wondering if anyone has ever installed one, and how well do they work? Also if there are any common places to find a auto retractable antenna that will fit in the space allotted and about how much they cost?
A
aerog
I have an amplified dipole antenna that is supposed to stick to the inside of the windshield. I mounted it under the dash cover. It works, sort of, sometimes. On the glass I'm sure it would work ok.
I usually just resort to the CD player.
Gliderman8
Since I did not want to drill a hole in my freshly painted car I decided to install an amplified Blaupunkt antenna.
After using it for two years I'm not all that happy with it.... my guess is that it might work better on a newer "electronic" radio; I have the original 1970's Bendix radio and honestly when I hook it up to a regular car antenna as a test, it pulls in distant stations much better.
Could it be that the amplifier is not compatible with an older radio?
CZ_Dave
PAUL161
A nice place to put a electrical retractable antenna. Plenty of room for a smaller unit on either side. PJ
JPSmit
Very Cool!!! But if you let it off the jackstands won't they go through the top panel? :jester:
PAUL161
So that's where that scraping noise is coming from! :jester:
PAUL161
What did you decide? Did you install a new antenna?
Keep us up to date! Were a very curious bunch, <span style="font-weight: bold">so don't go to sleep on</span><span style="font-weight: bold"> us! </span> PJ
111
Thanks to your good advice and pictures I went with a Metra 44-PW22 automatic power antenna.
Reception is good, and now I can go with an inexpensive car cover rather than buying a custom fit one with an antenna opening.
Plus it looks much better than a fixed antenna when the radio is off and the mast is down.
T Moss Hide-away amplified aerial part no. 230-555 FORUM Navigation Questions 1
kodpkd Antenna Removal Austin Healey 9
Bocaray TR2/3/3A TR3 Antenna Hole Plug/Cover? Triumph 2
S Radio Antenna Spridgets 5
Jim_Stevens TR2/3/3A Antenna hole? Triumph 11
T TR2/3/3A Antenna Hole Blanking Plug/Fender Mirror Placement Triumph 6
maxwedge5281 radio antenna location Austin Healey 17
M TR2/3/3A TR3 Antenna Triumph 10
drooartz Out with antenna, in with mirror MG 8
R radio antenna Spridgets 11
S TR2/3/3A tr3 radio antenna hole Triumph 15
JohnnyO Antenna installation Spridgets 19
M Is this antenna factory Spridgets 7
K antenna location in a TR6 FORUM Navigation Questions 0
K TR6 antenna location in a TR6 Triumph 6
bcbennett Radio antenna lead Triumph 3
T MGB Antenna Access 72 MGB MG 2
D Antenna position Austin Healey 10
GBRandy TR2/3/3A TR3 Antenna Triumph 8
Gliderman8 Antenna Placement Restoration & Tools 11
angelfj1 TR-3A Radio Antenna Options Restoration & Tools 4
2wrench Dropped radio antenna into fender. Triumph 21
G Fully retractable radio antenna Triumph 5
69MGC Removing an Antenna from a 79 MG 8
RSMTR8 Wedge TR8 Radio and Power Antenna Triumph 4
jjbunn Radio Antenna MG 12
RSMTR8 Wedge TR8 Power Antenna Triumph 0
C whip antenna Jaguar 0
Velox BJ8 Antenna Question Austin Healey 3
T Antenna options MG 5
A MGB 1977 MGB Antenna Installation??? MG 4
G radio antenna replacement Triumph 7
S Removing Antenna?? MG 6
