Amp, MP3 player and speakers of choice?
Lin
OK Roger, I have begun a new thread. My plan is to use an amplifier and an iPod, but I am not really happy with my speakers under the dash - not enough bass. Could you describe your system in a little more detail? Any under dash images of speaker locations? Thanks.
Lin
1960 BT7 in restoration
1959 Bugeye
Keoke
Hi Lin, while we are waiting on der Roger tell me what speakers you have and what amlifier you propose to use.---Keoke
AUSMHLY
Hi Lin,
The way I set my system up is to use a Garmin Nuvi 660 and self powered computer speakers. Both the Garmin and self powered computer speakers use cigarette lighter adapters to power them. So no need for an additional amp for power.
You mentioned not enough bass with your current speakers.
I must have tried 8 different computer speakers in my Healey. The ones that fit and sounded the best were:
Sony SRS Z510
Creative Gigaworks T20
The Sony speakers will fit way up in the back of the dash, above the heater box rail. On both the driver and passenger sides. So they are really hard to see, even if you bend down and look under the dash.
The Creative speakers were a little bit larger, so they could not fit up there. They could be screwed into the heater box rail for mounting.
The Creative speakers were the best of all the speakers I tried. Much cleaner, louder and have bass and treble control. As far as bass output, once hard wired and the job was done...Great. I have a lot of bass. Tight bass, not boomy. Nice to have treble control, for I ended up turning that down a bit.
If your looking to hide the speakers more than what I have done with the Creative, then consider using the Sony SRS Z510 speakers. Here’s a link:
https://www.amazon.com/Sony-SRS-Z510-Personal-Active-Speakers/dp/B000095SAX
If you interested in the Creative Gigaworks T20 speakers, here’s a link:
https://www.creative.com/products/product.asp?category=4&subcategory=28&product=14299
Here’s a link to some photos of my installation:
https://pg.photos.yahoo.com/ph/rfc_2002/a...m/ph//my_photos
Hope this answers your questions.
Cheers, Roger
GregW
Hi Roger,
Is that 4 speakers under the dash?
AUSMHLY
GregW said:
Hi Roger,
Hi Greg,
Yup. At the moment I am only running one pair.
Someone is making some sort of gadget that will let me wire the other pair in. All about what the Garmin sees. The Garmin is OK with one amp, but not two amps. This gadget should fix that problem.
Currently, one pair of speakers sounds good until you hit about 50 mph. After that, the Healey lets you know your driving a Healey. Another pair of speakers does increase the DB's. Which I'm hopping will help from turning the volume up as much. The more you turn it up, the higher the distortion. Distortion usually is followed by failure.
Of course there is a point where the Healey is so loud that it doesn't make sense to try to compete with it.
How's that sound? What? I can't hear you!
Roger
Keoke
Hi Roger, that is a pretty good setup. That is true when the Healey winds up it gets noisy and $3000.00 worth of the best equipment you can lay your hands on won't beat it. Regarding your reference to more db's with the additional speakers. I do not think this will materialise if you need more db's, then you need more gain in the driving amplifier of the speaker, assuming the speaker has the ability to handle the additional power.---Fwiw---Keoke
Lin
Lin
Roger, thanks so much!
Do you have the dimensions of the speaker? I could not find them on the spec sheet on line.
Thanks
Lin
1959 Bugeye
healeynut
Roger -
That's an awesome installation!! Where is the Tuner/Amp unit, and what kind are you using? I would really like to rig up my BJ8 with something I can plug my iPod into and have the whole thing hidden like you have.
Lin
Lin
Well, it is thanks to Roger!
Today I replaced the speaker system I was going to use in my car with the Creative Gigaworks speakers recommended by Roger. I have the new components installed and I must say that the system does sound great. I cannot say that I have tested it in a running car, because mine isn't to that point yet, but I don't anticipate any problem. Plenty of volume and bass with separate bass and treble controls. The speakers are nicely hidden and power is supplied with a Radio Shack accessory power adapter (cigar lighter). No external amp or subwoofer necessary.
I highly recommend this setup and again, thanks to Roger for the recommendation. I am using an iPod plugged into the input jack of the amplified speaker. I don't care about having a radio so I went this route.
Lin
1959 Bugeye
healeynut
Lin -
Can you upload some pics of your installation? Roger's pics are no longer accessible for some reason.
Thanks!
Lin
Lin
Sure, I will take some pix tomorrow and upload them.
Lin
1959 Bugeye
Lin
Lin
Hi Patton,
Yes, I am using negative ground.
Lin
1959 Bugeye
AUSMHLY
Hi Lin,
Glad things worked out for you. I too look forward to seeing your installation.
Patton, my car is positive ground.
Simply reverse the two wires at the back of the female cig ligher adaptor.
healeynut, here's the photos I posted before:
Cheers all, Roger
Keoke
And Roger, don't forget to tell Patton to mount the cigar lighter in a plastic bracket or he may burn the whole car down.---Keoke-- /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
Patton! I be biased,but I think it is a better idea to put ground the right way around.---- /bcforum/images/%%GRAEMLIN_URL%%/yesnod.gif
AUSMHLY
Good point Yoda.
Patton mount the cigar lighter in a plastic bracket or you may burn the whole car down.
Make sure you isolate everything if staying positive. May be a good idea to fuse things along the way too. Roger
B TR4/4A In-Line fuse 25 or 35 Amp? Triumph 21
S TR2/3/3A amp meter Triumph 3
K TR2/3/3A Is a 25 AGC fuse equivalent to an original 30 amp fuse? Triumph 10
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
N TR5/TR250 amp gage shows discharge when lights are on Triumph 39
K TR2/3/3A 30 AMP Fuses Triumph 2
S TR2/3/3A NW or the N side of the amp gauge for the OD? Triumph 4
K For Sale TR3 Amp Gauge Triumph Classifieds 0
C TR6 30 amp to 60 amp ammeter conversion Triumph 2
TomMull induction amp meter Restoration & Tools 3
Kirk_Fisher TR4/4A Need oil pressure and amp guages Triumph 8
B TR6 Does a 75 amp alternator require a wiring upgrade of any kind? Triumph 3
rjc157 amp meter Austin Healey 4
S TR2/3/3A Another Amp Meter & Regulator Question - TR3A Triumph 19
Tr3aguy TR4/4A Amp Gauge TR3 vs TR4 Triumph 4
V Fuse amp ratings MK III Spridgets 1
hondo402000 TR6 TR6 Amp Meter question Electrical guru needed Triumph 4
hondo402000 TR6 TR6 Wiring/amp gauge question Triumph 8
hymodyne 63 amp 7127 GM Delco alternator Triumph 1
tahoe healey amp meter Austin Healey 35
D TR2/3/3A TR-3 Amp Meter Triumph 17
sail Amp Meter Triumph 4
Brosky TR6 Up-date to Bolt On 72 amp Alternator for TR6 Triumph 35
PAUL161 Volt Gage Verses Amp Gage. MG 15
vping Amp Guage Questions MG 13
roofman Flippin out Amp guage Triumph 10
Webb TR6 TR6; Amp Gauge Not Reading Positive Triumph 7
C TR2/3/3A TR3 Amp Gauge to Volt Meter Triumph 8
AUSMHLY volt meter vs amp meter Austin Healey 21
J TR4/4A Amp to Volt meter wiring question TR4 Triumph 7
D TR2/3/3A TR3 AMP Gauge Triumph 1
Got_All_4 HELP ON BOSCH 55 AMP ALTERNATOR CONVERSION Triumph 1
wkilleffer Series III XJ6 a/c amp questions Jaguar 1
O 110-amp Bosch Alternator Upgrade MG 47
AUSMHLY Installation of a GPS/MP3 in my Healey Austin Healey 6
G Positive ground MP3 audio installation MG 7
Jim_Gruber Fuse for Sony AM/FM CD Player Spridgets 6
Shinsen774 Radio CD Player Suggestions MG 10
S TR4/4A Radio/CD player install help in tr4 pos ground Triumph 6
6773 cd player Spridgets 16
roofman CD player hookup suggestions Triumph 15
B Hidden cd player/radio behind blanking plate? Austin Healey 23
roofman Radio/CD player hookup Triumph 10
1973purplemidget Installing A CD Player? Spridgets 2
scott_74 CD Player Installation Spridgets 6
W CD Player for B MG 6
RobSelina CD player install question.... Spridgets 7
G Wedge CD player for TR7/8 Triumph 3
S TR6 am/fm/cd player for TR6 Triumph 7
M CD Player Jaguar 0
