SteveBones
Hello,
I wanted to start out by saying I noticed another thread regarding Amp Meter gauges issues. I wanted to post my own so I can be specific on what I am trying to figure out. My car is a TR3A that I have now back on the road after sitting in a garage for 10 years. You all have been extremely helpful in getting me thru some other challenges including correcting the distributor timing issue a few months back. The car is running great except...........
The issue
The TR3a gauge amp meter needle is moving or really "swinging or spiking" past the + 20 amp range and back past zero. When I start the car the Amp meter is steady and showing approximately 5 amps. After a short time or when I increase the rpm's on the engine, the amp meter needle then starts to "jump" with quick swings.
Condition of the car
I replaced the voltage regulator with the Moss version that was tested prior to shipment. I also replaced the generator. The wiring harness was replaced as well by the previous owner and is in good condition.
What Have I checked (Did I do this correctly?)
I measured the voltage from the voltage regulator including the regulator itself and the cut out (great suggestions on this from the other post). I used a digital volt meter and measured based on what is recommended in Haynes manual for the regulator. Going by memory, I call the Haynes manual said the regulator voltage range should be between 16.1 and 16.5 at 50 degrees F. Another publication suggested putting a thin card board piece between the cut out points so the reading will remain steady. I have not tried this with the cut out, but did see a change in the reading so I was not able to confirm the actual regulator voltage. Any suggestions on measuring the regulator voltage range would be much appreciated. As required I also disconnected the 2 wires connected to A and A1 and connected together using a 12 gauge wire to connect.
What is the Real Issue?
I am really trying to figure out why the amp meter needle moves so dramatically. Again the reading is fine when the car is first started but then starts spiking from what I am guessing is a current spike. Any ideas on where to look to isolate and fix would be much appreciated.
Thanks & Happy Holidays!
Steve
The issue
Steve
