aluninun shut face pillar cover on BJ8
bluegrass john
I could not find any history on this subject so I will ask if anyone has suggestions about installing the aluminum shut face trim on a Austin Healey BJ8: I was curious as to the best way to trim this dimpled material and form it to fit without damaging the dimpled surface. Is there a preferred supplier that offers a better fit and finish than the others or are they pretty much all the same? If this has been covered in another thread I am sorry for the repeat questions.
Any suggestions or ideas would be appreciated or a reference to another thread................. this something better left to the experienced professional?
Thanks,
John
Top Down Resto
John,
As far as I know the panels are supplied by AH Spares to the other vendors, well made but there are slight differences from an original. Do you have your originals? I use them as templates for a correct fit. There is a process of cutting, edge finishing, and trial fit, to get them looking correct. New sill replacement inner or outer can be a problem on shutface fitment if not done correctly. I can dig up some pics if you like.
Carroll Phillips
Top Down Restorations
RAC68
John,
You are talking about fascia plates and fitment is focused toward the rear vertical jam with some area exposed toward the hinges side of the sill. Since every vertical jams and sills are hand installed with limited assembly accuracy during production, you can expect not to find any body part that will have exact dimensions with your car. Find a best location for your sill plate and adjust the rear edge to allow the vertical jam to fit behind. Since the sill and jam fascia plates are a way to cover most issues, the installation of interior colored vinyl beading has been fitted between the jam plate and fender to cover the gap.
Enjoy the task,
Ray (64BJ8P1)
B
bluegrass john
Thanks for your replies............I do have my originals and will use those. It is my understanding that Kilmarten also makes a finisher set but you have to purchase the kit that supplies all the pieces required for both sides. I have been told Kilmartin finishers are of very high quality and fit very well; i am only needing the pieces to do the left side.
Any thoughts on how to trim the metal without causing damage to the dimpled metal Cut off wheel or small metal shears ??
Thank,
john
RAC68
John,
Then finish pieces are too thick for shears to do a good job. I do not think you will have much to cut off and a good file or a cut-off wheel followed by a file would be sufficient.
Ray (64BJ8P1)
Patrick67BJ8
Thank,
john
I had to replace the sills/jambs on my Healey and the original aluminum finishing plates were in poor condition. I put masking tape on the backsides of the plates and held them in place against the jambs. Note the distance between the edge of the plates and the jambs where the door seals fit! If your originals worked good with the door seals and you did not replace the jambs you are ahead of the game. Place the plates in position and with a small point marker draw the outline of the plates from the backside using the fender as a guide. You might want to place some tape on the fender too.
I trimmed my plates using aviation snips and followed up with a file to finish the edges.
I was going to say, cut your margins with a good quality sharp pair of aviation snips__Weiss or Milwaukee quality, NOT Harbor Fright! Then do final finishing with a relatively fine file. You can remove the tool marks from the file, ideally with a 2" right-angle die-grinder, outfitted with Scotch-brite pads.
I Bought an aftermarket set, as all the odd originals I had (still have, sign me up to hoarder's anonymous too) each had some blems on them. It was frustrating at first, as none of the pieces seemed to be made for even a British car, let alone a single model of Healey, but once you start whittling them down, a little bit off each one__per side__it starts coming together. It was some consolation that the piece covering the windlace fit without requiring any rework.
Top Down Resto
attachment.php
attachment.php
attachment.php
attachment.php
Here is an original set for you to see how they go together, use a phillips #4 screw to set them up first ,then replace with the new pozi drive screws as they get damaged easily (heads) USE THE CORRECT screwdriver (POZI drive)
Piping is black
Carroll
pan Door Shut Face Panels Austin Healey 0
K TR2/3/3A Old school battery shut off switch....... Triumph 3
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
S TR2/3/3A fixed one of those brass fuel shut off deals? Triumph 13
P Question about BJ7 Shut Face Finisher Fit Austin Healey 3
J Gas pump auto shut off question Austin Healey 2
edkap2002 TR6 Issue of the day......restart and idle after shut down Triumph 21
MisterB Shut pillar differences? BN4 to BJ8 Austin Healey 7
SherpaPilot TR6 Engine Will Not Shut-Down Triumph 4
M TR2/3/3A Engine does not shut off right away. Why? Triumph 8
J What's the Secret- Keeping New Aluminun Shut Face Finishers Looking New? Austin Healey 7
M TR2/3/3A Car won't shut off with generator connected Triumph 6
AH100M BN2 Door Shut Pillar Trim Austin Healey 2
P Overheating after shut down & recommendation on thermostat Austin Healey 3
T seat Belt Buzzer Wont shut off Triumph 5
B Engine Dieseling a Bit at Shut Down Austin Healey 12
N AH100-4 shut panel replacement Austin Healey 6
R Brake lights won't shut off Triumph 8
bighealeysource How to clean aluminum shut face finishers ? Austin Healey 9
B Shouldn't the fuel pump on a 3000 MKII shut off... Austin Healey 3
brgrmyster TR6 TR6 Overheating after being shut down Triumph 36
Superwrench Door shut gusset Austin Healey 3
bighealeysource Best way to remove aluminum smudge from shut face Austin Healey 1
L Doors slam shut Austin Healey 16
N Aluminium facing on sills and shut pillar, BJ8 Austin Healey 7
M Shut Pillar installation - 62 BT7 Austin Healey 3
Jim_Gruber Picture of Shut panel behind front wheel Spridgets 9
JohnnyMead Modern Fuel Shut-off for Our TRs? Triumph 12
toysrrus TR2/3/3A TR2 / 3 Feul Shut-Off Vlave on Ebay! Triumph 5
K TR2/3/3A TR3 Gas Line Shut-off Valve Triumph 12
bighealeysource Best way to trim shut face finishers Austin Healey 3
livinginthepast BE horn never worked. Now it won't shut up Spridgets 12
dklawson Bad Economy Forces Crane Cams to Shut Down Spridgets 7
M Driver Door Just Won't Shut Tightly Spridgets 2
B Shut Face Finisher Austin Healey 1
M 90 XJS Windshield Wiper Won't Shut Off Jaguar 5
GregW Measurement for shut pillar top piece BJ7 or BJ8 Austin Healey 6
hondo402000 Starter problem and motor wont shut down Triumph 22
Bob Claffie Trunk shut off switch Austin Healey 8
R BJ-7 Shut piller seals? Austin Healey 14
G Shut pillar placement bj8 Austin Healey 9
H How Does Battery Cable Connect to Shut Off Switch? Austin Healey 21
bighealeysource Shut face finisher polishing ? Austin Healey 8
AUSMHLY Shut face finisher, placement Austin Healey 19
RSMTR8 Wedge TR8 Shut Off Triumph 6
AUSMHLY Shut face finisher-where to purchase a good set??? Austin Healey 34
71tr fuel line shut off valve Triumph 16
S BJ7 Shut Panel Adjustment Austin Healey 9
George Zeck Fuel Pump / Rough Shut Off ..... Spridgets 2
B TR6 Thrust face repair Triumph 1
