Alas! A bit of progress.
blkcorvair
Well when I picked up my parts car and several days later denoted it to be road worthy, I never thought I'd spend two months working out the kinks. Well Im still waiting for my grill but the insurance is done and its off to DMV tommorw. This left some for time for me to get back to my original project. The fenders from WC have only been sitting around since the Carlisle show collecting dust. Took out a whole bunch of metal (SWA) to make room for the new tires. I also got to assemble the Passenger side A Arm with all new parts. Feels good to be working on my goal vehicle again. Here's some pics...
Speedy_Pete
Looking good so far, what's the plan for the engine? I notice the rear aches are a little wider than standard, I assume it will be for go as well as show?
B
blkcorvair
I would love to build an A series, but I hope to get this into scca when done. Planning to build for HP class at least to start out with, Havent read all the rulebook but from what I understand the stock displacement engine must be used? Also check out the fitment of the early rear valnce to eliminate the rubber bumper mounts. Shaved the holes and welded in a reccessed rear plate. Kind of hard to see but looks good so far. Cut the other wheel arch today
Bugeye58
You can run a fully modified 948 in HP, or you can run a lightly tweaked 1275 under the "Limited Prep" rules. NOBODY runs a 1500.
Go back and fully read the production car rules before you commit to doing the 1500.
Pay close attention to the roll cage section of both the PCS and the GCR, too.
Jeff
B
blkcorvair
Ive got the rollbar section down pretty good and have done some favors for a local tubing bender so that shouldn't be a problem. Ive seen the sections in HP that clarify the modifications allowed but wasn't sure if you could swap a 1500 car with a 1275 engine. That I would love to do. I'd like to back it up with the Rivergate and lock out first gear if that will fly. I read that you must retain your stock grill, but the 1500 has the nasty rubber bumper. Spridgetech offers the fake version, do you know if an early style grill would pass?
Bugeye58
Sure, the early grilles pass just fine. When you register the car with the SCCA, you just declare the year to be a '72 or whatever.
Many of the current racers start out with rubber bumper tubs, as there are some inherently stronger features.
As far as the Rivergate goes, I can only think of two tracks in the country where overdrive would be helpful in a Sprite. Elkhart Lake and VIR. I prefer to just change rear end ratios for different tracks.
Jeff
Sportsdoc
Good looking A-arms. Where did you get the parts?
Richard
66 Sprite restoration in progress
B
blkcorvair
A arms... homeade blast cabinet and using my boiler room as a paint curing booth. Rebuild parts came from Moss. Got a special 15% off first order coupon, so I ordered everything I could afford!
JimLaney To Glue or not to Glue... alas, poor Booby Spridgets 5
T Alas...they are fading away... MG 1
DrEntropy MGB A bit of disappointment MG 4
DrEntropy Bit of Historic Lotus News Lotus 0
DrEntropy Bit of nostalgia: Other Cars 14
Michael Oritt Vapor lock--a foolproof if a bit radical solution... Austin Healey 8
JPSmit Interesting bit of trivia tonight Other British Cars 0
NutmegCT Does this ad seem a bit peculiar? Other Cars 8
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
roscoe Distributor problem [a bit weird] Austin Healey 15
Gundy Runs a bit...then quits Spridgets 18
HealeyRick Runs a Bit - Then Quits Spridgets 23
Brinkerhoff TR4/4A Belgium built TR4A, is a bit unusual ! Triumph 16
Rut MGB Last little bit MG 0
I BJ8 is running a bit rough. . . Austin Healey 7
drooartz Bit of history on my new Bugeye Spridgets 0
B Engine Dieseling a Bit at Shut Down Austin Healey 12
M_and_P A bit of flex British Motor Corp 5
drooartz Off Topic Okay, this is a bit classier than the duct tape MG 4
Flash_Harry MGB '71?? MGB on eBay - a bit odd?? MG 10
G One bit the dust Triumph 12
drooartz A bit of workbench art MG 4
G Spitfire Bought a Spit today, a bit bummed out Triumph 12
T TR4/4A TR4A - A Type OD Solenoid - need a bit of help Triumph 7
RickB A bit scary this morning - ice Spridgets 22
KVH These Leaks are a Bit Shocking--Even for a TR Triumph 7
Hap Waldrop Acme Speed Shop just got a bit more speedy Spridgets 13
PC power bit to square drive socket adapters Restoration & Tools 3
Morris Had a bit of insomnia last night... Spridgets 3
glemon 11/64s drill bit tranny mounting trick Triumph 10
5 Is this bit off a healey? Austin Healey 8
jlaird Doing a bit of something. Spridgets 26
Wizardd MGB '77 MGB runs for a bit, then shuts down MG 28
angelfj1 PROJECT UPDATE - A Bit of Progress Triumph 13
drooartz Brosky, nice bit in the papers! Triumph 12
jlaird A bit of battery info Spridgets 4
drooartz Bit more progress tonight, nearly there Spridgets 21
Morris If only it were this easy...[ a bit OT ] Spridgets 5
W A bit more progress Spridgets 7
MGBGT_noob T-Series Clutch mater cylinder little plastickey bit MG 2
NutmegCT A bit of history Triumph 14
Tabcon A bit more restoration progress with pics. Triumph 24
W A bit of progress Spridgets 14
DrEntropy Bit of eye candy: Other Cars 26
mikecyc72usa A bit embarassing, this Triumph 2
Morris Bit OT: dangers of petrol Spridgets 8
eschneider help - what is this bit? [XKE, I think] Jaguar 6
