To Glue or not to Glue... alas, poor Booby
JimLaney
When I joined up I said I was a beginner, and here's some proof: Which fasteners should have loctite on them and which should have anti-seize? Do I want anti-seize on my head bolts or loctite or nothing?
In general I understand that if it might shake loose, I might want to use some color of loctite...but if I want to be able to get it out again and it gets hot or rusty, use anti-seize. Any better guidance than that?
Head bolts should be lubed with oil and torqued to spec. It is the stretching of the bolt that creates the clamping force and keeps the nut from backing off.
Joe Schlosser
jim
Are you interested in just the head bolts, then see above, Or are you looking for general information about what bolts/nuts should be locktited, nylocked, torqued or never seized?
there are a lot of nuts and bolts on your LBC and all are treated differently. Suggest you ask specifically regarding each issue.
If you are not interested in concours use nylocks wherever the temperature will allow.
Anything that is going to get torqued needs to be lubed as torque is always measured as the fastner is being stretched and moving.
Neverseize is usually to protect dissimilar metals where galling could happen and freeze the fastener. IE steel sparkplugs in Aluminum heads.
As I said specific questions are better than generalalities
twas_brillig
And use Loctite blue 242 on everything else. Check your manual etc., but (for example) torques vary depending on whether or not the threads are dry or lubed. I tend to use anti-seize on anything I want to occasionally undo (e.g. spark plugs), and loctite on everything else. I'm sure others will chime in with more specific, accurate, wisdom. Doug
SD Bugeye
I've also found that simply replacing spring lock washer with new ones makes sure things stay tight .
old lock washers have there corners at the split rounded off no longer bitting in and spring action weak.
JimLaney
JimLaney
Thanks all for your help. If I ask about each fastener, I'll spend life at the keyboard so generalizations are good direction pointers for me. Thank you again for the help!
V vintage glue type for veneer? Sunbeam (Rootes) 13
I Best glue for rubber door panels? Spridgets 3
N Best carpet glue???? Spridgets 5
davidb Latest - upholstery glue Austin Healey 14
Rut Bugeye door panel glue Spridgets 13
bugedd Carpet glue and roll bar padding Spridgets 4
johnrip Wedge Convertible Top Glue TR7 Triumph 2
T Leather and vinyl glue Triumph 4
I What is best glue to use? Triumph 16
RickB How to glue velcro to Midget? Spridgets 3
glemon Best Glue for Header Rail Triumph 8
I What kind of glue to use for ribbed bugeye panels? Spridgets 7
mgedit Glue for Vinyl on Dash/Glove Box Door Triumph 10
HAN8L1965 Carpet Glue and Snaps Spridgets 20
JPSmit glue website Restoration & Tools 4
I TR6 What glue for TR6 magnet in gas cap? Triumph 9
L What is your favorite top glue Austin Healey 3
RickB Carpet - PO apparently didn't like glue... Spridgets 19
J Recommend a carpet glue. Austin Healey 8
JPSmit Glue/ room temp question Restoration & Tools 5
angelfj1 Gorilla Glue - How do I get this off of my hands? Restoration & Tools 16
Jayrz Old Carpet glue removal MG 2
Atrus Vinyl Glue Spridgets 10
ronzet Carpet Glue MG 38
Stewart Best glue for dash? MG 7
N Why Glue in Carpet Sets? Triumph 8
10musketeer Vinyl Seat Cover- To Glue or not to Glue Spridgets 4
Lin Disc brake dust shield rubber seal glue Austin Healey 1
H Fusor glue is cool MG 8
jerrybny Type of glue to use Triumph 5
Lin shroud glue/sealer location Austin Healey 14
JFS Interior Trim & Carpet Glue Triumph 4
T Alas...they are fading away... MG 1
B Alas! A bit of progress. Spridgets 9
