Gundy
1380. HS2s. Aldon distributor. SU pump. Petronix ignition. Lucas sport coil. After an extended drive
it starts bad miss then dies. Will not even attempt to fire up. Just wind for nothing. Getting fuel.
No spark. Hot coil. By the time the flatbed gets there it fires right up. Pay the guy to follow me home.
30 mile drive. Almost at my driveway it dies again. Tow truck loaded it for the 1/4 journey to the
barn. Replaced that hot coil with another Lucas. Yep. Runs then dies and coil is hot. Replaced with a
blue Bosh. Runs then dies. Now it won't start even after an overnight cool down. Replace the Petronix.
It runs then dies. In my driveway after 20+ mile drive. Let it cool for a few minutes and ..varoom.
WTH....
Bought a set of points to install, which is what I was using before the Petronix.
Now the Petronix in there now fires right up and runs great but I know it will fail on extended drive.
Then I got to thinking....installed a ballast resistor.
We shall see when the road dries ....Mimi doesn't do rainy roads.
the car had no ballast resistor with the points.
The instructions from Petronix shows connection w/out resistor as preferred wiring but also shows
wiring with a ballast resistor.
Dang...we need the rain, in a bad drought, but I can't wait to see if I nailed this problem.
Car fires, idles and goes varoom with the resistor installed.
Endurance test is all that is lacking.
Fingers crossed. I really don't want to go back to points. Just a personal preference.
On the bright side...I have a new Lucas Sport coil and points in reserve now.
WTH....
