Fuel pump runs continuously!
V
vagt6
Just installed a new Moss SU fuel pump on my MK III '74 Midget. It's the points-type pump, Moss says it's the correct replacement.
I hooked it up, turned on the ignition and the pump just runs continuously, won't stop clicking. And, it's much louder than the old one!
What could be the problem? Does the "inlet" fuel hose go to the gas tank and the "outlet" go to the engine? Could I have the hoses hooked up backwards?
Any ideas, gents??
Thanks for the help!
V
vagt6
With help from the great Dave Dubois, the SU guru, I fixed the problem.
This SU fuel pump must be installed with the outlet line oriented on top (I didn't do this), AND, I had the outlet and inlet lines reversed.
So, I re-oriented the pump and reverse the lines. FIXED!
I must say, if you ever need help with anything that has "SU" stamped on it, rebuilding, fixing, etc., call Dave Dubois. Not only is he very knowledgeable and helpful, but he's an honest businessman.
Never met the guy except on LBC websites. Free expert advice, just for the asking. The kindness of strangers, it's what makes the hobby feasible for amateur mechanics like me. Couldn't do it without 'em.
Thanks, Mr. Dubois. :thumbsup:
dklawson
I have exchanged several emails with Dave over the years. I could not agree with you more. He is a wealth of knowledge and very willing to share what he knows.
jlaird
Lots and lots of business men in the community that are like that. If I listed them all I would miss someone important.
V
vagt6
Sadly, I still have the problem!
Fuel pump acted okay for a bit, then went back to continuous running.
Question: Where does the "inlet" line on the fuel pump go: to the gas tank, or to the engine end???
dklawson
The hose from the tank goes to the pump inlet.
If you can clamp off the fuel hose coming out of the tank, you may benefit from bench testing the pump. You can use a battery charger to power it and a "safe" substitute for fuel would be mineral spirits, diesel, or kerosene. You want something that won't accidentally burst into flames.
Billm
As Doug said a bench test is the best way to test the pump.
one test that I have done is to see what the pump pressure is; I hook about 15 feet of clear plastic (Tygon) tubing to the output of the pump and run it up the side of my house, then I power up the pump. 3' of rise is 1 PSI, 6' is 2 PSI, etc.
BillM
V
vagt6
While bench testing the pump, I can feel suction at the inlet and air blowing out of the outlet. However, when I plug the outlet turret with my finger, the pump keeps running. Blocking the inlet turret will cause the ticking to slow way down, but not stop completely.
Could the brand new Moss pump have an air leak? What am I missing?
It doesn't make sense that a fuel pump would run all the time, whenver the ignition key is turned on. Is that normal for an SU AUF 214?
Other ideas???
V
vagt6
BillM
Bill, the pump is definitely blowing air, seems fairly robust. I'd very roughly estimate that it's at least 2-3 psi.
The problem is the continuous running. Could that be right, to run all the time?
dklawson
Repeat your bench test with liquid (mineral spirits, etc. as mentioned above). Air is compressible and the way the pump toggles, it will not stop until something incompressible (like fuel) prevents the pump's moving parts from opening the points.
V
vagt6
Many thanks, Doug. I'll do the flow test and see what happens.
Back in a few minutes . . . :crazyeyes:
Platinum
Plug the outlet side of the pump <span style="font-style: italic">after</span> you have <span style="font-style: italic">fluid flow</span> and see if it slows/stops the ticking?
JPSmit
BillM
yes, I'm sure it should be continuous. in the same way that the mechanical runs continuous when the engine is running - only difference is with electricity, you can run the pump without running the engine - either way the float prevents too much gas getting in.
V
vagt6
Here's what Dave Dubois said about the pump running continuously: it doesn't. It's supposed to stop clicking when the float chambers are full. Makes sense.
<span style="font-style: italic">Mark - When the engine is not running, the pump will pump fuel into the float chambers of the carburetors and once they are full, the pump will stop clicking. A pump with new check valves that are sealing almost perfectly will not click again (theoretically), as long as the engine is not running - in the real world, the pump may click once ever 15 seconds or longer. When the engine is running, the pump will continue to click as it replenishes the fuel used from the float cambers. The rate of clicking will be determined by how fast fuel is being used from the float chambers.
Cheers,</span>
And, the problem seems to be fixed. It appears that air was sucking into the fuel hose where it connects to the hard lines on the outlet, the hose clamp was too loose. This was causing the pump to run-on. When I turned on the ignition I noted fuel dripping under the car! So, I snugged up the offending fuel hose clamp and the leak stopped. The pump also stopped running/clicking constantly.
Went for a test drive, seems fine. And, the pump does NOT click all the time.
Thanks to everyone who offered advice here, couldn't drive this car without you.
Cheers to all . . . :thumbsup: :driving:
dklawson
I'm glad you got it resolved. When you let Dave know, please tell him I said hello.
Platinum
This is where it was going when I posted the suggestion about blocking the line at the output end after fuel was present. If the output is blocked off and the pump keeps running there's a good chance it's sucking air at the inlet side or the flapper valves in the pump are not seating. Most times it's sucking air. And it will not always be evident by fuel leaking, either. A deteriorated or cracked hose can "valve", allowing air IN but not allow fuel back out.
Good ya found it. That stuff can make ya crazy. :wink:
V
vagt6
Good point, Doc. I installed new fuel hoses when I installed the new pump, too, to be safe.
Strange about the fuel hose sizes: the correct size fuel hose is 5/16", which fits the fuel pump turrets fine but seems a bit large for the hard fuel lines which are 1/4". You really have to snug up the hose clamps tightly to the hard fuel lines with the 5/16" hose to get a good, airtight seal that won't leak.
And, you have to be very careful NOT to tighten the hose clamps too tightly on the plastic SU fuel pump turrets, it will crack the turret (I prefer the metal turrets on my old SU pump - the replacement had plastic ones). A hair-line crack that let in air in one of those fuel pump turrets would be difficult to detect. Now THAT would drive you crazy. :crazyeyes:
A learning experience, and a good one thanks to Dave Dubois and the helpful folks above.
Jack of all trades, and master of none. :crazy:
AndreL TR6 Conversion to electric fuel pump Triumph 10
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
D TR4/4A TR4a Fuel Pump Triumph 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
D MGB Fuel Pump MG 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
P XJ12 Fuel pump relay 85 Jaguar 4
petnatcar Fuel Pump Upgrade Austin Healey 2
R Electronic Conversion on an SU Fuel Pump? Restoration & Tools 2
T TR6 Fuel pump lines Triumph 2
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
R Electric fuel pump wiring Spridgets 4
T SU Fuel Pump Mounting Austin Healey 5
D TR2/3/3A More Fuel pump questions. Triumph 10
Donald1107 59 TR3A Fuel Pump Triumph 48
BobHaskell SU Fuel Pump Pressure Austin Healey 1
Cutrog1 Fuel Pump Ticking Austin Healey 13
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
S SU fuel pump servicing Austin Healey 4
71TR6 TR2/3/3A AC Fuel Pump Lever Triumph 10
E MGB 1965 mgb fuel pump removal MG 2
D For Sale Su fuel pump Other British Classifieds 5
D For Sale Su fuel pump Austin Healey Classifieds 5
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
vette A Quiet SU Fuel Pump Austin Healey 2
A TR4/4A AC Fuel Pump stuff Triumph 11
AngliaGT Fuel Pump Problems Spridgets 2
B SU Fuel Pump Parts Austin Healey 8
B TR4/4A Mechanical fuel pump vs electric Triumph 16
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
J TR4/4A Fuel pump saga Triumph 4
longbridgehealey Fuel pump racing, no gas Austin Healey 26
D General TR Fuel filter before the pump. Triumph 2
T 66 Austin Healey fuel pump replaced Austin Healey 30
C Well I Tried with a new SU fuel pump British Motor Corp 0
T TR2/3/3A Questions on fuel pump installation Triumph 7
sundown TR6 Fuel pump Triumph 10
