MGB Air leaks and fast idle speed
wkilleffer
Good evening,
I have a question about the fast idle speed on my 1974 MGB. It's equipped with an engine from around '71 or '72 with HS4 carbs.
The choke has always seemed a little tricky. I'll get it adjusted to the point that the car is idling around 1500RPM when cold with the choke pulled. I'll start driving and the engine will start to warm up a bit, though the pointer on the temp gauge will very much be at the left side of the gauge.
As the temp starts to creep up, the idle speed will rise as well.
I've been told that a rising fast idle speed is indicative of an intake-related air leak.
Is this true? If so, what's a good first step to take in finding and curing the leak?
Thank you,
-William
Platinum
A good "low tech" method is to use a length of surgical tubing (or other hose of similar I.D.) and with one end near an ear, move the other end around all the gasketed intake areas. DO NOT stuff the thing into an ear.
My British pal calls it a "listenin' pipe."
wkilleffer
wkilleffer
Might suck the brains right out of your head?
Grantura_MKI
Can also use brake cleaner. When the leak is found, the idle will rise. Have used the pipe method for years, as well.
good luck.
wkilleffer
wkilleffer
But I was right in thinking that this issue is likely to be an air leak?
Joe Reed
You can check for a vacuum leak easily enough, but I don't think you have a problem. It's normal for the idle speed to increase as the engine warms up. IMHO, a 1500 RPM cold idle is too high. Try setting it closer to 1000 RPM and see what happens...
Mickey Richaud
:iagree: And I believe a vacuum (air) leak would show itself as a rough idle that would smooth out and increase when the mixture is richened, as when spraying fuel of some sort (like brake cleaner as suggested above) at the leak's source.
Let us know what you discover.
JPSmit
And this just jogged my memory. It took me a couple of years to realize that I needed to set the idel when the engine was hot - not cold. Then the choke could take of cold starts. So now, it idles bang on at 800 rpm - only when warmed up.
Joe Reed
:encouragement: Easy fixes are great! I once had a memory...I just can't remember where I put it...
JPSmit
Lol. Good stuff.
wkilleffer
wkilleffer
Problem is that going too much lower than maybe 1200 is tough. 1200 almost seems the lowest I could go without a bunch of rich-running chugging. I know the mixture is going to be rich, but where do you draw the line with the choke?
Adjusting the choke is, frankly, a pain compared to adjusting the regular idle and mixture.
Where on the B's tach would you estimate 800RPM to be?
M TR4/4A Difference between two Oval Air Filters Triumph 3
K TR2/3/3A Foam air filters for S U's Triumph 7
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
WHT DW ITG Air Filter Austin Healey 3
Carlbanan56 MGB Puling air MG 5
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
Writer2022 GT6 Overheating after fitting air filters Triumph 4
Celtic 77 MGB Tinny Zenith air regulator MG 0
Celtic 77 MGB Seized air pump issue MG 25
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
D BT7 Air Vent Control Cable Routing Austin Healey 0
DrEntropy MGB Air filter MG 16
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
F TR4/4A Replacement air filter for SU HS6 Triumph 6
A MGB MGB flap and air box MG 60
R For Sale TR6 AIR CLEANER BOX Triumph Classifieds 1
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
tahoe healey Cooper Air Filters Austin Healey 7
petnatcar Air Scoops Behind the Grille Austin Healey 0
D Wire Wheels and Air Leak Austin Healey 16
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
PC air back there... Spotted 0
equiprx Air Compressor Moisture mitigation Restoration & Tools 17
S TR2/3/3A restore my original air filters Triumph 5
J Wanted ZS 175 CD-2 Air Valve Triumph Classifieds 0
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
E MGB Oiling foam air filter MG 3
E MGB SU carb air cleaners MG 10
RAC68 Cold Air Bilge Blower update Austin Healey 13
P TR6 New front shocks & air in clutch Triumph 15
N Air filters Austin Healey 5
M Cooper's Air Filter on H1 Carbs Spridgets 5
TomMull Scroll Air Compressor Restoration & Tools 13
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
M TR6 Tr6 fresh air vent replacements Triumph 1
S TR2/3/3A Stock air cleaners and aftermarket air cleaners. Triumph 7
T TR6 Air vent rod connection Triumph 1
tahoe healey Cooper decal on air filter Austin Healey 2
tahoe healey cool air pull knob nut Austin Healey 15
F Heater pipe and air duct routing BT7 Austin Healey 3
AUSMHLY Hose, vent pipe to air cleaner, BJ8 Austin Healey 7
tahoe healey Original Air Filter Maintenance Austin Healey 4
AH67 Air Cleaners for Mark I BT7 Austin Healey 4
B Air Deflector Assembly Austin Healey 2
I T-Series air cleaner/ noise suppressor MG 1
D TR2/3/3A Air filter Triumph 11
R Screen for warm air side Austin Healey 26
D BT7 air ducting / cooling Austin Healey 20
