For Sale Air Horns for SU HD6 Carbs
jfarris
Two air horns (velocity stacks) for SU HD6 1.75" bore carbs. The air horns are 3" tall and will not fit a TR3.
Will trade for shorter stacks.
$40 plus shipping.
gbtr6
I have a TR6 with HS6's, look like the same pattern. Do you know if they'd fit on an HS6 carb?
Thanks,
Perry
Rut
Jim,
Ill take those if they are still available.
Thanks, Rut
jfarris
jfarris
PM sent to GBTR6
jfarris
jfarris
Sold!
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
T looking for simple Weber Wisdom, and angled air horns Spridgets 1
mrsprite question about air horns/trumpets Spridgets 11
X New Air Horns MG 0
M TR4/4A Difference between two Oval Air Filters Triumph 3
K TR2/3/3A Foam air filters for S U's Triumph 7
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
WHT DW ITG Air Filter Austin Healey 3
Carlbanan56 MGB Puling air MG 5
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
Writer2022 GT6 Overheating after fitting air filters Triumph 4
Celtic 77 MGB Tinny Zenith air regulator MG 0
Celtic 77 MGB Seized air pump issue MG 25
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
D BT7 Air Vent Control Cable Routing Austin Healey 0
DrEntropy MGB Air filter MG 16
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
F TR4/4A Replacement air filter for SU HS6 Triumph 6
A MGB MGB flap and air box MG 60
R For Sale TR6 AIR CLEANER BOX Triumph Classifieds 1
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
tahoe healey Cooper Air Filters Austin Healey 7
petnatcar Air Scoops Behind the Grille Austin Healey 0
D Wire Wheels and Air Leak Austin Healey 16
PC air back there... Spotted 0
equiprx Air Compressor Moisture mitigation Restoration & Tools 17
S TR2/3/3A restore my original air filters Triumph 5
J Wanted ZS 175 CD-2 Air Valve Triumph Classifieds 0
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
E MGB Oiling foam air filter MG 3
E MGB SU carb air cleaners MG 10
RAC68 Cold Air Bilge Blower update Austin Healey 13
P TR6 New front shocks & air in clutch Triumph 15
N Air filters Austin Healey 5
M Cooper's Air Filter on H1 Carbs Spridgets 5
TomMull Scroll Air Compressor Restoration & Tools 13
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
M TR6 Tr6 fresh air vent replacements Triumph 1
S TR2/3/3A Stock air cleaners and aftermarket air cleaners. Triumph 7
T TR6 Air vent rod connection Triumph 1
tahoe healey Cooper decal on air filter Austin Healey 2
tahoe healey cool air pull knob nut Austin Healey 15
F Heater pipe and air duct routing BT7 Austin Healey 3
AUSMHLY Hose, vent pipe to air cleaner, BJ8 Austin Healey 7
tahoe healey Original Air Filter Maintenance Austin Healey 4
AH67 Air Cleaners for Mark I BT7 Austin Healey 4
B Air Deflector Assembly Austin Healey 2
I T-Series air cleaner/ noise suppressor MG 1
