David,
The large screw is called the "slow running valve" or "slow running screw"; the one on the linkage is the "throttle stop adjusting screw" or "throttle stop screw".
If you remove the slow running screw, you should see a spring, a brass washer and the remains of the o-ring. You could use the brass washer to determine the size o-ring you'd need.
The Brooklands book: "SU Carburetters Tuning Tips & Techniques" is highly recommended and has a very good section on rebuilding the HD carb with pictures showing how to install the flexible plastic bushings. I found this process to be easy with the book.
Using this book, when I disassembled my HD8s, I found the plastic bushings had worn and the brass shafts were excellent.
After the rebuilds, my car idles at about 500 rpms with the slow running screws only; if I add just a hair to the throttle stop adjusting screws it idles around 800.
