A Senior moment
kc_doyle
Ol Yeller was running just a tad rough so I decided that today would be the day to dig into it. First things first so I pulled the plugs and checked the wires. Plugs: nice and tan. Next check the points: Closed the points and ran a piece of white paper between them. I could feel a bit of a snag on the paper so I called both parts houses intown and neither had points in stock. I figured that while waiting for them to get them I would just clean up the points that were in there. I also checked the cap, roter etc. Everything was in good shape. I took the points out, buffed them up nicely and reinstalled them, gapping them to .015 as my book says. I put the plugs back in, checked the wires, put the cap back on and was ready for the moment of truth. She spun over and not a pop. I thought that Crypty had come to Wisconsin. Nothing to do but take the cap off and try to find the problem. With the cap off it was pretty simple to see that there was no rotor where there should be one sitting. Slapping myself on the back of the head, I put the rotor where it should be, cap back on, Roger Houston, Vrooooom, we have lift off.
I'm sure that no one else in this fine group has ever done anything like that.
tdskip
I don't think you need to be a "senior" to have that happen - believe me when I say you are not the only one that has done that - lol.
NickMorgan
Done exactly the same! :crazy:
DougF
I don't look at that as a senior moment, as I am only a late sophomore-early junior.
bob67bgt
I am a bit lost. I wondered over from the MG forum. 20 years ago when i was in my early 30's i put a new clutch in my MGA. Got the engine bolted back in and then saw the release bearing sitting on the bench. Next step, start all over. Does senior start at 30? Bob
TR4nut
Yep, only good thing is that you can't drive off and lose the rotor that you've balanced on top of the valve cover.
Andrew Mace
kc_doyle said:
...I'm sure that no one else in this fine group has ever done anything like that.
Uh, yeah, sure. :angel: Actually, I think my first such "senior moment" was when I was a senior in high school in 1970! and I've probably done it at least once very four-five years since then....
T
Tinster
I wish MY PROBLEMS
were senior moment.
Crypt Car - dead as petrified wood
Dale
NutmegCT
forgot the rotor? you're not alone!
how's this for forgetful: drain the oil, change the filter, pour in four quarts at the top ...
... see four quarts spreading over the floor - then remember the drain plug in your pocket.
argh.
Tom
tdskip
argh.
Tom
<span style="font-style: italic"><span style="font-weight: bold">Now that is funny</span></span>. At least you didn't wonder why she was taking 8 quarts before you realized.
kc_doyle
kc_doyle
I'm too Da**ed old for a rite of passage. Been a shade tree wrench turner for far too long to do something like miss the rotor... Probably all of these new fangeled computer run autos have me complacent. "put in fuel, Change oil every 5000, and just drive um.. Don't even have a Dizzy.. Humph.
dirtbill
I've done many way dumber mechanical ommisions and find it has much more to do with impatience and distraction than age. How about rebuilding an antique tractor carb, re-installing on the tractor, turning on the gas only to have it flow all over the ground 'cause the float needle is still on the work bench? Duh.
Bill
Adrio
I first got my tr3a in high school back in the late 70's. I first forgot the rotor then; and since then I have gotten better at forgetting the rotor. I guess they are right when they say "practice makes perfect"
kc_doyle
kc_doyle
Guess I got the points set right, and the rotor in the right place. Wife and I went out and put on over 65 miles hitting "rummage sales." With the LBC we don't have room for very much "Stuff." It was a beautiful afternoon and there are so many little county roads..
vivdownunder
Worse than a rotor button senior moment is to overlook replacing an oil filler cap. Once topped up the the wife's DOHC Brit car, notorious for oil usage, and off she went on a shop till you drop. Came home complaining of engine bay smoke plumes and a dreadful smell. When I lifted the hood, oh my God what a mess.
Think I'd have preferred it all over the garage floor like Tom.
Viv
Cheapsnake
I've seen kc at work before and I can be pretty sure it wasn't a senior moment but more likely the lubricant he was using...and it wasn't WD-40 if you get my drift.
kc_doyle
kc_doyle
It didn't work well at all. More adult beverage and back to the drawing board..Till I get it all sorted out, I'll just have to reinstall the rotor.
Platinum
I can say I've regularly left that blasted rotor on th' bench as I spun up an engine.... "WTF?!?!"
A highly humbling experience.... and not as enlightening as it SHOULD be. :devilgrin:
C Another senior moment Austin Healey 5
J TR6 TR6 senior moment..... Triumph 7
M Dang Another Senior Moment Triumph 3
jlaird Senior moment MG 4
Nelson Senior memory aid Spridgets 12
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
BigGreen For Sale Anderson / Moment Restoration Guide for sale Austin Healey Classifieds 0
Michael Oritt Anderson/Moment Restoration Guide for sale Austin Healey 8
J For Sale Healey Books: Anderson/Moment Restoration Guide; Robert Bentley; 100-6/3000 Factory Austin Healey Classifieds 7
pkmh Humorous moment while detailing Healey flasher unit Austin Healey 5
Rob Glasgow Joyous Moment Austin Healey 5
drambuie Bonneville salt flat moment Austin Healey 15
S eBook Version of Anderson/Moment Restoration Guide Available Austin Healey 21
R Moment restoration guide Austin Healey 2
mrsprite A moment of silence, please Spridgets 10
T OT - Interesting moment at Isle of Man TT Triumph 6
J Watershed electrical moment? Triumph 32
T Wedge Rare moment of discipline - TR7 Spider in NorCal Triumph 13
Jim_Gruber My Dumb Present Owner moment Spridgets 24
Glen_B A special Spridget moment Spridgets 2
B Sad moment! Spridgets 38
regularman Anyone have a fuel tank off at the moment? Spridgets 3
prb51 TR6 Top Gear TR6 moment Triumph 9
BIBBER MOMENT OF INSANITY? Other British Cars 73
tahoe healey New favorite Healey moment Austin Healey 9
SCguy TR4/4A TR4 Uh-Oh Moment Triumph 13
P I bought a Singer in a weak moment and ........... Other British Cars 17
sparkydave A "well duh" moment... Spridgets 9
timbn2 Anderson & Moment book, which one? Austin Healey 10
sparkydave A humbling moment.... Spridgets 1
M A moment of silence please.... Triumph 2
