TR6 TR6 senior moment.....
jessebogan
Hello Folks,
I am assembling a TR6 engine. As returned from the machinist, most of the block plugs were removed. I have hit a snag or two, and I hope somebody can help jog my old brain cells. This is an early 69 engine. First, above the oil filter mounting area there is a large threaded hole (12 oclock on the filter opening) What goes there? If it is just a plug, anyone have any idea what size? I have a good supply of things like that, but nothing that fits... Moss shows nothing, and so does Rimmer Bros. The second thing is the customer supplied the external oil feed line. It seems WAY too long, so what an I missing on that? If I were to install it on the rear cam bearing "port", the braided line is about twice as long as it needs to be.
thanks,
jesse
Gliderman8
I think that is for the oil pressure switch.... be right back, going into the garage to have a look at my engine.
Edit: OK, I just had a look at my engine. The hole you are referring to is NOT for the oil pressure switch. On my engine, the hole just above the oil filter (at 12 o'clock position) seems to have a plug in it. Looks like at sometime someone (or the factory) put a plug into the hole and pounded it down.
As for the external oil feed, I don't think they do much... just my opinion.
Gliderman8
On my '73 the relief valve is at the 9 o'clock position just under the dizzy.
RagTopMan
Just checked my '68 TR250 engine which is likely very, if not exactly, similar to your 69 TR6. 12 o'clock position, just above the oil filter housing is a plug.
Check TRF part number PU1404. Description: "Plug, oil gallery".
TR3driver
Great Pumpkin - R.I.P
TRF has the plugs available, I think that one is PU1404 (but you have to buy 3 of them using PN PU1404/3).
I'll echo the above sentiments: Lose the oil feed line. As long as a decent quality oil is used and kept changed on schedule, the stock oiling system works quite well. And the external oil feed introduces way too much oil to the top of the head, where it causes problems like this:
DNK
Jesse- i know it is a customers car and He/She is always right.
So ...just make the suggestion to them.
If they really want it, who are we to say no?
BierRunner TR6 TR6 Trunk Lock Striker Triumph 1
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
A For Sale 1974 TR6 Triumph Classifieds 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
JPSmit TR6 at lunch today Spotted 0
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
charlie74 ‘74 1/2+ TR6 Spotted 0
E TR6 TR6 flip-up bonnet question Triumph 4
Marvin Gruber For Sale 1974 TR6 for sale, $7200 Triumph Classifieds 3
T TR6 TR6 Tire Pressures Triumph 2
