Ok forum folks, I think I might have stumbled across, for the second or third time, a watershed moment in my TR3 troubleshooting career. I have been babbling on about starting problems in various disguises for a few years but I think that I have finally got a solid lead here.
Symptom:
With battery fully charged and having the TR running beautifully the day before I go out and turn the ignition key and click..then all ignition off. Dead as a doornail. I poke around aimlessly for a few minutes tightening up battery cables and checking other stuff and try starting again. Same sequence. A strong click-clicking of my electric fuel pump then either a very weak few turns of the engine and then click. Lights out all over. If I am very lucky the engine will start up on the first few turns. If I am not I usually assume that the battery is bad. This time I know the battery is good and is well charged.
Now, I am hoping against hope, mostly because the weather is so unseasonably nice that I NEED to be riding around in my TR, that you all can give me a direction to go on my hunt based on this observation. When I turn the engine over from the starter/soleniod in the engine bay, with the ignition switch off, it turns over as I would expect a fully charged battery to turn over a competent starter. If I then turn the ignition switch on, then push the same starter in the engine bay, it barely turns. I might get a couple of turns or three at most. Unless the engine has been run recently then not enough to start.
So the question I want to pose is why is there such a difference when I add in the ignition system which of course has to be present and accounted for if the engine is to start?
I thought that the two electrical systems, though related by the same battery power source, were separate from each other. It seems to me that there is something about turning on the ignition that is draining so much of the battery power that there is barely enough left over to turn the starter at a sufficient strength to start the engine. Any ideas on either where that load could be or how I could find it?
Lastly, if I am lucky enough to get the car started with the anemic few turns of the starter that the ignition on state allows me...then the car runs like a perfectly. Once it has warmed up even just a little I am able to restart it because it is then so easy to start. For example if I can start it first thing in the day then I am good for the rest of the day. But the next day I have the same problem starting.
I have done a bunch of tests with the two most recent being testing the continuity of the positive and negative cables. I am going to replace both of them just for good luck even though they tested fine. I am also going to clean up the place where the negative cable grounds to the firewall. I don't have any high hope of this being the issue though as I believe that the healthy turning of the starter without the ignition on shows that the battery and its cables are doing there thing competently.
Thanks very much,
Jim Lee
Symptom:
Thanks very much,
Jim Lee
