TR4/4A TR4 Uh-Oh Moment
SCguy
I installed my new TRF steering rack today and finished the front end, radiator, etc. I then stuck my wheels on the car (its on jack stands) and spun the rear tires. I then put the car in gear and spun the rear wheels again. They spun!!! What's going on? The u-joints are contected (they didn't spin). Am I missing something? /ubbthreads/images/graemlins/confused.gif
TR4nut
Have someone hold the opposite side wheel while you try to spin one- if it still spins then yes I think you have a problem, but otherwise I think its just the differential doing what it should be doing. With that I'll shut up and let the folks who actually know exactly how the differential works chime in (I've never fiddled with them)!
Randy
AltaKnight
If I understand your question correctly.
They should be able to spin with the transmission in neutral.
Even if the tranny is in gear spinning one wheel would spin the opposite wheel in the other direction due to the differential which is how it's supposed to work.
Or am I completely missing the point on your post?
G
It's supposed to do that. Notice that the other wheel will be turning in the opposite direction.
TR4nut
Larry-
That's the design and intent of the differential - it lets the rear wheels rotate at different speeds. If they didn't, every time you turned a corner you'd have some wheel hop and tire wear. Some mechanical engineering genius originally came up with the design - I always wanted to tear one apart just to fully see and therefore understand its workings but as yet I haven't had the opportunity.
Randy
YankeeTR
[ QUOTE ]
Does he have spiders in his differential?
[/ QUOTE ]
I found a MOUSE in one..... /ubbthreads/images/graemlins/hammer.gif
T
Tinster
The Differential in my Tr6 was filled with oak sawdust
and cedar wood chips. The PO told me that was the
recommended procedure since the TR differentials have
an original design flaw and leak too much oil.
The sawdust and cedar chips provide a form of
"dry" lubrication that does not leak. The PO
recommended changing the sawdust and chips every
10,000 miles.
Of course the Crypt Car died after only 67 miles
so I guess I have many miles remaining on my sawdust
and wood chips lubrication system!!
t
Geo Hahn
[ QUOTE ]
The Differential in my Tr6 was filled with oak sawdust and cedar wood chips...
[/ QUOTE ]
I've heard that used to be a common trick that some used cars dealers would use in a failing gearbox to mask problems.
SoCal - Re differentials: Stare at the exploded view in a manual or the Moss catalog awhile & you'll either understand how they work or get a headache. If the head still feels fine then stare at an exploded view of the overdrive unit, that one will give you a headache.
G
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
I was referring to the spider gear. Does the TR diff have spider gears?
70herald
[ QUOTE ]
10,000 miles.
[/ QUOTE ]
Ever read "The Grapes of Wrath?" There is the chapter where the used car salesman is selling "Jalopies" and filling the worn out differentials with sawdust to stop the noise.
Dale did you replace the differential yet? I have a sneaking suspicion that sawdust in not going to help you reach 10,000mi
Yisrael
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Twit TR4/4A First startup of TR4 Triumph 4
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
R Tr4 restoration books Restoration & Tools 2
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
Twit TR4/4A early tr4 check straps Triumph 4
Twit TR4/4A restoring TR4 sun visors Triumph 0
