A real noggin scratcher...
Morris
On my way home from work yesterday in stop and go traffic, I said to myself, "Wow. This car is really running and driving well. I think I am getting close to having it dialed in. It's getting good mileage, making good power and running smoothly. Everything is nice and tight, too. Especially the clutch."
45 seconds later the clutch went out. Or rather, the clutch pedal started getting closer and closer to the floor before engaging the clutch. When I had no more clutch at all, I ground it into second, took the first available exit, and found a safe place to park. After making a few calls to let people know I was going to be late, I inspected the car. Granted, the thoroughness of inspection I can execute in a parking lot is limited, but I could find no signs of leaking brake fluid. All the parts and pieces where were they should be, and the reservoir on my brand new master was full of fluid. The fluid, which was completely replaced a few months ago was rather brown. Other than that, I could not find anything unusual. I hoped back into the car, pumped the pedal about ten times and got full pressure back. I drove the car around for the rest of the evening without issue.
Any idea what the heck happened?
smaceng
I think you will find that a more closer examination will find that either the new clutch master cylinder is leaking around the piston, or the slave cylinder is leaking. 95% of the time, it is one of the above. Why this happens so often in British cars I do not know. I have never replaced a slave or a clutch master in a Japanese car.
Scott in CA
JPSmit
Yes, I know exactly what happened, you thought the above thought! Right up there with "Gee the traffic seems light today, I think I'll be early." and "I'm sure the officer didn't notice." (which I myself accidently thought earlier this week :wall:)
Happy thoughts work at Disney and in Neverland but for LBC's the only option is grumpy dangerous thoughts like "Gee, this car is running like cr*p today." or "Is that a misfire?" or "I think the brakes are getting soft." Then and only then will you be able to reliably drive your car and hate every minute of it the way the manufacturer intended.
sheesh. :madder: :devilgrin:
Deleted member 8987
If the fluid is at the same general height, you can usually rule out the slave. When the slave goes, fluid leaks past the seal, and it goes out on the ground, refilling the master from the reservoir each pump of the pedal, dropping the reservoir level.
The "rather brown" comment is bothersome...not worrisome, just bothersome. You didn't mix fluid types, did you?
RyanBez
I notice you are in Austin, any chance the fluid started to boil? Hot day in stop and go, just a thought. Explains why letting it sit for a bit and it fixed itself.
Morris
Morris
I did not mix fluid types.
I was wondering if the issue might be boiling fluid. However, I have been through much worse traffic and heat without experiencing clutch troubles. The exhaust pipe does pass near the slave... perhaps that played part?
Billm
Slit some plastic tubing (1/2" or so) and slide it over the clutch line. See if it helps.
BillM
Westfield_XI
I wonder why a man who owns an MG, a Vauxhall and a Fiat would have an attitude like that?
JPSmit
:whistle:
RyanBez
bug_sixty said:
huh maybe bleeding issue somewhere..air pocket that worked its way through
If it was an airpocket it wouldn't disappear unless there is a leak which I think you find. Do you have a single or twin M/C the air pocket could be switching between brakes and clutch possibly? But I wouldn't think air pocket imo.
Deleted member 8987
What year and what engine?
Any chance the exhaust is close to the slave or the pipe to the slave? The only time in my life I have ever had hydraulic clutch issues was on a logging road, slow grind, and the exhaust heated the slave, boiled the fluid. Depending on the layout of the feed pipe, air runs uphill, so any air bubbles could have migrated back to the master and vented in the reservoir.
Just a thought.
Morris
Morris
It's a 1500. Typically when air bubbles get in the clutch line it takes an act of congress to get them out. But I guess anything is possible.
Deleted member 8987
Okay, on a 1500, does your exhaust go straight back or cross under near the bell housing?
Is the exhaust close the the slave at any point?
RyanBez
Looks like it does. Seems like a logical explanation.
G
Morris, new m/c is bad. No way you boiled fluid. Mine gets hotter than yours and it's never happened. Change the m/c and blow out lines and s/c.
Do final bled by removing s/c, point bleeder up, open and compress slave. Close bled before release and repeat. once you have no more air comming out, compress slave w/ bleeder shut for final purge of any air through line and out into res.
racingenglishcars
Scott in CA
Funny thing about that. I have been wondering for the last 25 years when I will have to change the slave cylinder in my Land Rover. I did actually change it once back in the early 80's
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
Editor_Reid For Sale 1956 Austin-Healey 100M [real one] Austin Healey Classifieds 0
Lukens For Sale Check out this tr3 project for sale... A real treasure trove Triumph Classifieds 0
Healey Nut This one claims to be a real factory 100M Austin Healey 21
Healey Nut If you want a M but cant afford the real M price tag Austin Healey 24
AngliaGT Real Mini Spotted 0
simon1966 All the prep is done, time for real paint! Austin Healey 6
Jim_Gruber Bugsy was out for his first real romp today! And it was fun!!!! Spridgets 3
Jim_Gruber Bugsy is alive and went for his first real drive this afternoon. Spridgets 9
KVH TR4/4A Replacing the Real Axle Tube Seal Triumph 17
TomMull Real Deal [Apparently] Griffith on eBay TVR 16
KVH General Tech Centering Real Main Seal Triumph 4
KVH TR4/4A Real Main Seal and Pulling the Engine Triumph 19
HealeyRick Real Vintage Racing Austin Healey 15
HealeyRick I'm Guessing It's A Real One Austin Healey 16
HealeyRick OK "M" Experts - Real or No? Austin Healey 18
DornTRoriginal TR2/3/3A Installation of Brake Line Clamps on Real Axel Triumph 1
Boggsy64 MGB Convert away from Z/S a real boost? MG 17
sqbsprite What will be the real price? Spridgets 11
7 Post-War Other Basically the real problem is.. Triumph 9
DNK Was this real to start? Lotus 7
J Does a texas cooler make a real difference ? I now am using an a moss flex fan ! Austin Healey 24
aeronca65t A-H 3000 for sale - looks like a real barnfind Austin Healey 7
Sarastro Here's the REAL way to rebuild a Triumph engine! Triumph 1
C Stag Looks like a real nice Stag Triumph 8
5 Would the real OEW shade please stand up Austin Healey 13
6 It's snowing, 1st real one here! Spridgets 5
RAC68 What is the Real Horsepower? Austin Healey 26
G Real Classic Triumph 1
doates 1st Real Drive Triumph 7
M BN2 real axle reboun buffer picture needed Austin Healey 3
Morris The REAL function of the roll bar Spridgets 16
PAUL161 OK,OK, Is This For Real, or Another Fluke? MG 1
JPSmit I've never seen one of these for real Spridgets 5
toysrrus RE: "MAIN REAL SEAL" Installation Info. Needed: Triumph 13
apbos A Real Sebring Sprite Spridgets 14
Jer Insurance Appraisal vs. real world ... Spridgets 2
T The Bugeye is a "real" car again Spridgets 4
Sherlock A real beauty... Other Cars 4
J Is this for real?? Austin Healey 7
drooartz Tunebuggery Day 1: real progress! Spridgets 7
Steve1970 this just in: wife not crazy, fuel leak was real! Triumph 27
T I think I have it figured out...real roll bar Triumph 7
T TR6 Real TR6 Up-date Triumph 9
aeronca65t "Real" Escort Twin Cam Other British Cars 18
JPSmit real progress!! Spridgets 4
tahoe healey real reason for no tunes Austin Healey 21
kyreb1862 Was This A Real Factory Color? Austin Healey 8
kyreb1862 For The Real Project Fans Other Cars 1
jvandyke First "real" tour Spridgets 3
