BN2 real axle reboun buffer picture needed
musme
Can anyone supply me with a picture of the rear axle rebound buffer picture or its dimentions shpecially height
Moss part 675-500 not availale for BN2
What is the difference with 675-510 for BN4
Where can I buy the buffer ?
Moss does not have it, victoria either
Thanks,
Jose
I'm working from memory here, and may be mistaken, but IIRC the bump stops on our BN2/100M had width-wise bends in them; i.e. the metal base is not flat (and the rubber part is shaped so that the upper surface is flat). This is so that the base of the stop fits flush with a bend in the chassis rail. IOW, from this photo, I don't think this part is correct for a 100, although you might be able to modify (bend and shape) it to fit.
I'd call BCS and see if David has them.
richch
No, no, that's a chassis bump stop pad. Jose is talking about the conical bump stop that mounts under the pair of U bolts on top of the axle, left and right sides.
Bob is right in that the pad he's talking about is not flat on the Hundred, but can be mounted in a vise and easily bent to contour for the Hundred.
A BN2 Chassis Alignment Austin Healey 8
T 100 BN2 Possible Ignition Issue Austin Healey 9
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
H BN7 and BN2 Lengths Austin Healey 3
Gundog61 BN2 Brake Drums Austin Healey 5
bighealeysource BN2 Master Cylinder Austin Healey 91
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
MikeAH100M BN2 Tight Steering Austin Healey 4
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Gundog61 BN2 Steering Box Leak Austin Healey 2
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
Martinld123 Problems with my BN2 Temp Gauge reading Austin Healey 13
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
Guido36 9k-Mile BN2 at Auction Austin Healey 13
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
MikeAH100M Oil Pump for BN2 Austin Healey 4
Martinld123 Healey 100 BN2 Water Pumps Austin Healey 9
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
Guido36 BN1/BN2 Sidescreens Austin Healey 0
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
roscoe Caving In [5-speed conversion for BN2] Austin Healey 29
J BN2 Shift Lever Bushing Replacement Austin Healey 6
Editor_Reid Oddities Found During BN2 Revival, Part 2 Austin Healey 6
Editor_Reid Oddities Found During BN2 Revival, Part 1 Austin Healey 4
3 BN2 clutch pedal and exhaust downpipe Austin Healey 14
S For Sale RARE FIND BN2-BT7 and? Trans Parts for Sale Austin Healey Classifieds 2
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
J 100 bn1/bn2 id Austin Healey 26
wangdango BN2 wheel cylinders/rebuild/replace? Austin Healey 3
Z For Sale 1956 Austin Healey BN2 Factory hood Austin Healey Classifieds 0
D Wanted BN1 or BN2 Donor/Parts Car Austin Healey Classifieds 1
BoyRacer Steering Column Height Adjustment on BN2 Austin Healey 1
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
C Wanted 100/4 BN2 1956 Le Mans side windows Austin Healey Classifieds 0
Martinld123 Fuel Tank Cap 100 BN2 Austin Healey 7
Martinld123 Just installed LED headlights in BN2 Austin Healey 15
aero3113 BN2 Front Chassis Rail Austin Healey 6
Jake For Sale FS: BN1/BN2 Kilmartin Chassis Repair Parts, New Austin Healey Classifieds 2
bighealeysource Wanted Looking for missing BN2 door and cockpit moldings Austin Healey Classifieds 0
bighealeysource Turn signal gremlins on BN2 Austin Healey 2
A BN2 Boot Lid Austin Healey 4
P BN2 new wood steering wheel install Austin Healey 5
W Gear Lever Boot for BN2 Austin Healey 5
J BN2 shift bushing replacement Austin Healey 5
wangdango BN2 wheel cyclinders/replacement Austin Healey 1
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 1
K Wanted W.T.B. Late 100 BN1-BN2 DOOR HINGE Austin Healey Classifieds 0
P BN2 Walnut Steering Wheel Austin Healey 10
P Healey BN2 Distributor Question Austin Healey 1
