RE: "MAIN REAL SEAL" Installation Info. Needed:
toysrrus
Howdy Folks,
Well; My engine is all detailed etc etc.
We were going to install the New Clutch the other day & I had purchased a "New" Split Alum "Rear Mail Seal" from Moss.
Would anyone know where I can find the proper procedure for the Removal & Installation of this?
We opened up a "Can of Worms" possibly by breaking the seal on the existing Main Seal so; Now there`s no turning back.
My biggest question is this: Does the "Crank" have to be removed to re-install the New Seal????
Thanx in Advance,
Russ
TR3driver
Great Pumpkin - R.I.P
Re: RE: "MAIN REAL SEAL" Installation Info. Needed:
In a word "yes".
The workshop manual describes the preferred method, which is to use a purpose-made mandrel to center the seal around the crank. Note that many agree that the dimensions in the book are not correct, the seal portion of the mandrel should be only 2.818", not the 2.822" shown in the book. (I've also heard that the tool Moss sells is even worse oversize.)
However, it can be done by wrapping thread around the crank journals, both the main journals (to hold the crank centered in the bore) and the seal scroll (to give the required small clearance between the seal & scroll).
toysrrus
toysrrus
Hi Randall,
"Thanx" for the info.
Regards, Russ
MrAlex
Member
I used teflon (plumbers) tape to obtain the spec'd gap using the crankshaft instead of the tool. I did this with the engine vertical though to remove any gravity load. I am real happy with the results as it does not leak at all.
toysrrus
toysrrus
Hi Mr Alex,
Thats quite interesting! So; You "DID NOT" remove the Crank; Correct?
I`m not a Technician or Mechanic by any stretch of the imagination so I have "NO CLUE" exactly what you mean there?
Where during the re-assembly did you put the Teflon Tape?
Also; How or What would I use to seal the area between the back side of the Alum. Seal & the Block itself?
Thanx, Russ
PS: I`m forwarding these comments to my Brit Mech. Guru for his use so; Whatever/Whomever would like to make comments about this; Please do so!
TR3driver
To use the teflon tape method (or thread as I mentioned), you remove the crank and wrap the rear main journal, plus the scroll area of the crank. Then the crank and rear main cap are temporarily installed; and the seal halves put into place against the covered scroll area and the bolts tightened. Then the crank & rear main cap get removed again to remove the tape/thread, and continue with final assembly.
The book recommends "shellac" between the seal & block; Permatex #3 will work fine.
https://www.permatex.com/products/Automot...3_Sealant_a.htm
It's also suitable for soaking the felt that seals the rear main cap to the block.
This is all covered (except the thread/tape bit) in the factory workshop manual; either you or your mechanic should definitely have a copy of it. It's not all obvious to the casual mechanic, and getting it wrong will result in leaks or worse.
toysrrus
toysrrus
Howdy Randall,
"Thanx" for all the info.
I / We do have the workshop manual. But, In my opinion; There is no better education available than a "Physical Hands On" experience.
Thanx Again,
Russ
toysrrus
toysrrus
Hi Folks,
Yesterday; We had the engine sitting "Vertical". Removed the Rear Main Cap & Old Seal. Cleaned "Baby Butt Smooth" all surfaces.
With "Crank still Installed"; We tried a "Dry Run" for the fit of the New Rear Main Seal & The upper 1/2 (Looking at the Head) threaded on pretty "Snuggly". We thought we were "Good to Go"; "NOT"!
Each time we "Re-Assemble" the Main Cap & tighten it down (Not even torqued); We "CANNOT" turn the Crank?? We removed the Main Rear Seal (Dry run again) & tightened the Main Cap (Torqued) & Crank turns.
"WHAT THE HECK ARE WE DOING WRONG?
"ALL SUGGESTIONS, COMMENTS, EDUCATION" etc. are "WELCOME"!!
Thanx, Russ
PS: All above work done while Crank is still "INSTALLED"!
PPS: Note that the Mounting Holes on the Seal "DID NOT" match up very well at all on 1/2 of the Seal.
Tim Tucker
Would it be possible to take some shim stock or paper and verify the seemingly obvious: that the scroll area of the crank is touching the scroll seal? If it is, then something has gone wrong. I have the tool, so I have never done it this way. Sounds reasonable. The thickness of string/tape seems critical. If the bearing shells are in place (at least the front and rear to keep alignment?), I would plastigage and add that much teflon tape or string as suggested. With the scroll area of the crank centered, center the seal around it.
Basic question: Can you mount the seal without it touching the crank? I am sure Randall will have suggestions. I have installed one of these: the one currently in my TR4 back in '86. Good Luck!
Tim
MDCanaday
Are you tightening the bolts that hold the seal to the cap and block??they should be loose untill the cap is tight.
MD(mad dog)
toysrrus
toysrrus
Howdy Folks,
Yesterday; We re-installed the "Old" Seal. I cleaned it up to like brand new. We did a few "Dry" runs & all seemed to be OK.
So; We got out the "Schelak" (Is that how you spell that)? Sealed everything, Torqued the Main Cap & then Torqued the Seal. The crank is "Cranking" and all seems to be fine.
It was an expensive education! Now that we`ve "Elongated" the holes in the "New" Seal (Needed to that to line up with Block holes); I`m going to give "VB" a call & see if they will issue me a credit. "LOL" there!!
Thanx for all the input folks,
Regards, Russ
HerronScott
Russ,
I had meant to ask earlier if there was a reason that you bought a new one versus using the original one.
Scott
toysrrus
toysrrus
Hi Scott,
Being "Un-Knowledgable" about the Rear Main Seal; I did`nt think you could "Re-Use" the old seal. But, Due to the fact that there are no rubber seals involved etc; I have to believe its OK.
When we Test Drove the TR; It was on Jack stands & did`nt leak etc etc. Engine, Trans and Rear all sounded real good. When my Brit Mech. pulled the Engine etc. He said it leaked out the back end. Thats what made me go to a new seal. That was a mistake (Live and Learn). It actually was OK.
I contacted "VB" yesterday & told them about the mis-alignment of the mounting holes in the seal & perhaps the "ID" being too small causing the Crank not to turn.
Surprisingly; Their giving me a full credit even after elongating some of the mounting holes. Those guys are OK in my book.
Regards, Russ
HerronScott
Russ,
That's good news on the refund.
Scott
KVH General Tech Centering Real Main Seal Triumph 4
KVH TR4/4A Real Main Seal and Pulling the Engine Triumph 19
B Rod & Main Bearings Recommendations Austin Healey 10
J Rear Main Seal Kit Austin Healey 1
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
D MGB 3 Main bearing 1800 & Moss Supercharger MG 1
algot1901 1950 Prefect/Anglia Trsnmission Main Bearing Retainer Other British Cars 2
S TR2/3/3A rear main seal is leaking Triumph 13
J RIB CASE MAIN SHAFT ASSEMBLY Spridgets 2
R Wanted 3 main crank MG Classifieds 1
R Wanted 3 main crankshaft MG Classifieds 0
J General TR Main bearing caps Triumph 6
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
D TR2/3/3A Main ground connection Triumph 2
R Main Bearing Cap Removal Austin Healey 12
S MGB early transmission vs od transmission for 3 main engine MG 5
D rear main seal Austin Healey 13
G TR4/4A And the fun continues...rear main leak Triumph 5
D BT7 main bearing seals Austin Healey 11
Michael Oritt 100 Main Bearing Caps--removal in situ Austin Healey 9
B General MG Solutions for topical MG rear main leak? MG 7
T BJ7 Slipping Clutch? rear main seal? Austin Healey 11
Boggsy64 MGB Crank doesnt turn freely - new main brgs MG 21
charleyf TR2/3/3A Center main cap engine Triumph 4
Joe Schlosser Bugeye Main Switch Spridgets 11
wkilleffer MGB 1974 MGB- New main wiring harness, but no start MG 11
Gerard 1098 10CC rear main seal conversion Spridgets 4
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
T General TR main bearing Triumph 9
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
KVH General TR Rear Main Seal--Minor Problem Triumph 4
KVH General Tech Crankshaft Main Bearing and Oversize Puzzle Triumph 5
K TR2/3/3A Refresh...main reson why idle will lower when kicking the gas pedal? Triumph 3
Editor_Reid Rear Main Seal for BN2 Austin Healey 12
Gerard 1098 "10CC" rear main Spridgets 0
J BJ8 rear main seal kit - is it necessary and worth the risk to install? Austin Healey 33
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
S TR2/3/3A front main cap sticks proud Triumph 6
sim HUS 2 main jet adjustment Spridgets 40
C TR4/4A Rear main seal Triumph 36
S TR2/3/3A rear main seal Triumph 20
E 100 4 Does anyone recognize this rear main seal mod? Austin Healey 12
A 100 engine main bearing cap nut question Austin Healey 0
B Rover V-8 main bearings Rover / Land Rover 5
KVH TR4/4A Viton Rear Main Seal Triumph 12
oxford main bearing caps Austin Healey 4
C Rear Main Seal Leak with Moss Retrofit Austin Healey 21
TR3driver TR4/4A "Mad Marx" rear main seal for TR2-4A once again available Triumph 10
S TR2/3/3A tr3 rear main Triumph 24
