TR6 72 TR6 alternator questions
roofman
Pretty sure my alternator has quit. Being an amatuer Tinster I have a few questions.
1. How do you test alternator output and what should it be?
2. My old alt. is a lucas. On the black plastic cover it shows a large 1 with small 5 6 7 next to it. The 5 6 7 is stacked w/ 5 on top and 6 7 below it next to a large 1.
This seems to indicate it is a 15, 16, or 17. What does it REALLY mean?
3. Simple amp upgrade suggestions?
RomanH
A quick and easy way to determine if your alternator is charging is to connect a volt meter to the battery. While the engine is running get the RPMs up a bit, the voltage should be between 13 and 14.6 volts IIRC. If your voltmeter is showing 12 volts or less you are not charging.
As for the rest, I don't know.
TR3driver
Great Pumpkin - R.I.P
Got_All_4
I agree with Tr3driver. If your current Lucas alternator has a internal voltage regulator then it should be a drop in conversion. Some have said that the terminal is the same and others said they had to eject the terminals out of the terminal block and plug them in individually. I did one in my 250 and what a difference. I did have to do some wire jumping because mine has an external voltage regulator. Also had to grind off some of the adjuster bracket. I now can run a radio, H4 headlight conversions and my dash lights are still bright. Good luck. Larry
TR674
roofman
good chance it is the voltage regulator. Is the ignition light on when the motor is running?
Regards
Craig
roofman
roofman
No ignition lightwhen motor running. I did not drive the car for about 2 weeks and when I went to start it and battery went weak. Put the battery charger on it and all was well for the day, but amp guage hovered at center line showing no charge. Went to start it 3-4 days later and same thing. I have a newer Optima Gel battery, so I am pretty sure that is not the issue.
How do you tell if mine has an internal or external voltage regulator?
Does the Fiesta alternator have the 3/8" pully?
TR3driver
That description sure fits a bad battery. Does the ammeter stay centered when you turn the headlights on ?
At the very least, I would want to check the charging voltage before putting a lot of work into replacing an alternator that may be fine.
Only the TR5/250 had the external regulator; all TR6 were internal. Look for the black plastic cover on the back of the alternator; externally regulated models have no cover.
Some do, some don't. Best plan on moving the pulley from your old alternator.
roofman
roofman
Stopped at auto zone today, and can order the Fiesta model for $108 w/no pully ( not available with pulley so I guess I have to hope the shaft size is the same also. I will check the recommended alternator and battery checks after work tonite. The battery is only 6-8 months old but i guess could be bad based on the other posts of crap parts.
TR3driver
Not hard to kill a car battery in just a few weeks; all it takes is leaving it run down. Or overcharging it (which I believe the Optimas are particularly sensitive to).
roofman
roofman
Just came home for lunch. I charged the battery for 3-4 hours this morning.
With car not running turned on headlights and amp guage goes 3/4 up towards discharge.
Started car amp guage goes up 2/3 for a minute or 2 and settles in just barely into charge range. Turn on headlights and goes barely into discharge. both these last 2 readings only 1/8 inch above and below the bottom center line. Turned on the lights and revved up engine and no change in readings.
Put the volt meter on the battery with car not running and got 12.25. With car running partial choke at 1200 rpms I get a reading off battery terminals of 13.66 and with more revs about 13.8. Thoughts?
TR3driver
Did the ammeter stay on discharge when you revved the engine with the headlights on ? Or did it swing back to zero or slightly positive ?
The former would likely indicate an alternator problem (probably one bad diode so it still puts out something); while the latter sounds more like a bad battery.
Check the voltage (and the ammeter reading) with the engine at fast idle (like ~2000 rpm). Between 13.9 and 14.4 with little or no charge on the ammeter is correct; but it can be lower if the ammeter shows charging. Check first on the battery posts, and then as close to the alternator as you can get.
Bad connections are common, and can act like a bad alternator (or bad battery). The voltage at the alternator is allowed to be a few 0.1 volts higher, but anything over 0.5 says you have a bad connection somewhere.
I had a Chevy once where the ground lead to the motor was loose. It would make contact enough to start the engine, then let go again going down the road. That was a fun one to find !
roofman
roofman
Tried again, 12.37 sitting and not running.
Start car and idle to 2000 rpm I get 13.67 amp guage staight down. When I turn on the lights at 2000 rpm it drops to 13.4 and guage still staight down and showing no positive or negative gains.
TR3driver
Still sounds more like a bad battery to me.
I would be looking for a way to do a load test on the battery. Walmart and Sears I think used to do it for free.
I mis-typed before, 13.6 is the lowest acceptable votlage (according to Lucas) rather than 13.9. And Optima says their battery should charge at 13.3; so your 13.67 should be charging the battery.
The 13.4 sounds a bit low, but that might just be voltage drop in the wiring.
roofman
roofman
Battery tested ok at autozone, will attempt the alternator drop test above tonite. Is 13.66 at the battery with car running at 2000rpm enough to keep battery charged or should that number be higher?
TR3driver
13.66 should be fine. As I mentioned before, Optima says minimum is 13.3 and up to 15.0 is acceptable.
https://www.optimabatteries.com/publish/o...ical_specs.html
If your AutoZone has one of those automagic battery testers, I wouldn't place too much faith in it. Few years back I had what I knew was a failing battery, but the gizmo at Pep Boys said it was fine. Within two weeks, it wouldn't start the car at all. Their machine just said "needs charged". When I told them it had just been charged, they claimed my charger was defective. So, I challenged the manager to charge the battery any way he wanted to and then start my car with it ... he finally backed down and admitted the battery was bad. Screwed me on the replacement too, but the problem went away. Although I didn't cut the battery apart to find out, I'm pretty sure it had a broken or partially broken conductor inside the case.
roofman
roofman
Thanks for all you help TR3driver. I brought the battery home cleaned the terminals, cleaned the alternator connections up and now I get a 14.2 reading. I guess I will just have to wait and see what a few days brings.
martx-5
Sounds like you solved the problem. Dirty conections can easily account for a 1/2 volt drop. /bcforum/images/%%GRAEMLIN_URL%%/driving.gif
M TR6 Alternator Issue for 72 TR6 Triumph 7
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
K TR6 71 TR6 Alternator Connections Triumph 9
sundown TR6 1973 Tr6 alternator Triumph 6
F TR6 TR6 Alternator Overcharging Triumph 2
S TR6 Quick TR6 alternator question Triumph 6
F TR6 76 TR6 Alternator Triumph 21
hondo402000 TR6 MY alternator died TR6 Triumph 8
martx-5 TR6 TR6 Alternator Problem Triumph 1
T TR6 73 TR6 Alternator Triumph 4
T TR6 TR6 alternator Triumph 17
Brosky TR6 Up-date to Bolt On 72 amp Alternator for TR6 Triumph 35
Brosky TR6 Fiesta Bosch Bolt on TR6 Alternator Triumph 35
B TR6 TR6 alternator conversion Triumph 20
B TR6 71 TR6 Alternator Wiring Triumph 2
TR674 TR6 TR6 Alternator Triumph 3
Airfix TR6 TR6 alternator wiring? Triumph 5
hondo402000 TR6 alternator up grade for 71 TR6, what works Triumph 8
D TR6 TR6 Alternator Triumph 2
M TR6 TR6 Alternator/Fan Belt Issues Triumph 9
P TR6 Delco alternator on TR6 Triumph 1
AltaKnight TR6 TR6 alternator output Triumph 8
A TR6 alternator que 70 tr6 Triumph 4
Bill Redd TR6 tr6 alternator Triumph 3
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
