do t forget the tool to remove the cap screws. The second from the bottom is for 5th gear. Stretching the spring us okay, but I've been told that it will return to its manufactured spec after a while.You can do this in any gear position you want, although neutral is simplest, especially if you have the shifter out. Removal of these items will not affect any components inside the gearbox.
Under each of the three cap screws you will first find a spring. After removing the spring, you will probably need a small magnet to remove the ball. Their entire purpose is to create a little extra pressure on the shift rod when it is in gear or in neutral. It does this by pushing the ball into an appropriately located notch on the rod. My main concern here is that, since all 3 sets don't show the same part #, that perhaps the wrong combo was used in the bottom(5th gear) location. We have a W58 "training" unit at work. I will see if I can get some pics to make this easier to understand.
