5 Speed Driveshaft Yoke
John Kuzman
Does anyone know if the driveshaft splined slip yoke used in the "Smitty" conversion is a specialty item or an off-the-shelf item? If off-the-shelf, what specific application? Thanks.
J
John Kuzman
Been calling and emailing for over a week. No response.
HealeyRick
It's going to be the yoke from whatever fits the particular Toyota tranny you have. You'll need to have a new driveshaft made up incorporating the Healey flange at the back and the Toyota yoke at the front. The driveshaft shop will be able to source the proper Toyota yoke, probably an aftermarket part at less cost than the Toyota dealer
Michael Oritt
And in the process you can opt for a sealed U-joint that does not need to be greased.
FWIW, long ago I needed a new yoke--front, I think--for my BJ8. My dad took it to a local engine shop and an old-timer working there recognized it as the same one used in Volvos of the same vintage; at considerably less cost than a 'genuine' Healey part. Perhaps the yoke was a Jensen part?
steveg
The Toyota splined yokes are widely available aftermarket; the Healey joints are standard sized. The Toyota yokes are a standard size which fits all the W-series trannies.
You measure the distance between the flange on the back of the trans and the flange on the front of the diff. The driveshaft maker will know how long to make the driveshaft.
Take your Healey driveshaft so they will be able to see the specs of the U-joint at the rear.
Patrick67BJ8
I think the original Smitty 5-Speed instructions had Driveshaft instruction details if anyone still has a copy, maybe they can post them?
steveg
The easier method outlined above is how my driveshaft guy approached it. Smitty would have you buy the parts separately and take them to your shop. My guy said that wasn't necessary - they have all the parts. As the drawing shows, they'll deduct 3/4" -- to allow for variation as the axle moves up and down. Do not use my 20-3/16" as marked below without verification.
J
John Kuzman
Steve -
Thank you very much for the attachment. It shows the yoke as "Toyota 1-2303-21". That is what I needed. My problem is that the yoke on the driveshaft supplied with the 5 speed kit will not slide far enough in to the transmission. It slides in about 2.25" then hits a solid, metal on metal stop. It is not on far enough to bolt the rear flange.
The transmission was supposedly re-built by a professional. I just want to try a different yoke before I once again go through the pain of pulling another transmission.
For my earlier problems, see: https://www.britishcarforum.com/bcf/showthread.php?110884-5-Speed-Issue&highlight=kuzman
Gee, one of these days I may actually get to drive my BJ7 with a 5 speed!
steveg
Steve -
John - Can you post a picture of the yoke in place?
J
John Kuzman
Steve -
Went down the shop and looked at the yoke. It is a Spicer and looks like YXE. Those are the only numbers on the casting.
Here are two pictures I took last fall with the yoke installed as far as it will slide. The first picture shows the splines on the output shaft looking down into the shift tower.
steveg
John -
What is the yoke hitting when you insert it? It should probably slide forward into the area of the splines in your first picture.
Look how the splines are larger in diameter than the shaft - that implies the yoke should slide forward of the splines.
Are you sure the yoke is engaging the splines and not getting hung up on a burr on the end of the shaft - have you rotated the driveshaft as you insert the yoke?
What is the distance the yoke goes in?
HealeyRick
Steve -
The part # in the Smitty's manual may not be correct. Read this post: https://www.ahexp.com/phorum/read.php?13,30673 Have you checked the internal splines in the yoke to see if you don't have a bent or damaged one? That would explain why the yoke would only go on so far before stopping.
J
John Kuzman
Steve -
I cannot see/tell what the yoke is hitting, but it is a solid stop, not just a snug interference. The yoke goes in about 2.5" before stopping.
Additional information to dwell upon: This same driveshaft and yoke slides in fine to the first transmission that I installed (jumps out of fifth gear). I found a Toyota 21 spline yoke on eBay and bought it just to play with. ($18.00). It is not the correct u-joint configuration, but it is a Toyota application, 21 spline, and the exact same OD and ID as the yoke on the driveshaft. It slides in without any problems!!!
And now to add more confusion to this never ending saga, I have an old junkyard Wxx Series transmission that I bought several years ago. Condition unknown, but it shifts into all gears. Both yokes fit it fine!!!
Rick: Powerline Industries has an East Coast distributor who I plan on calling this morning.
J
John Kuzman
The latest: Powertrain Industries, through their distributor, sent me the 2303-21 yoke. It slides on perfectly! Now the downside, the 2303-21 yoke mates with the 2326-25 end weld yoke. This end weld yoke is for a 2.5" diameter driveshaft. The driveshaft that came with the Delaney kit is a 2" diameter. I would need to have made a whole new driveshaft. Sure wish Delaney would respond. This is getting ridiculous.
steveg
John - do you have anyone in your area who rebuilds Toyota transmissions? It would seem you need to talk to an expert and show him your stuff.
Lots of landscapers use Toyota trucks - there's gotta be someone.
Did you measure the OD of your new yoke with a micrometer at several places along its length - and compare it to the one that won't slide in all the way?
Try loosening the bolts that hold the rear housing to the center section and see if the yoke will jiggle into place. Maybe there's a close-fitting bore that's slightly off alignment and maybe the OD on the problem yoke is slightly larger.
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
PAUL161 Jag 5 speed? Jaguar 5
T Datsun 5 speed potentially available from wrecker: Spridgets 0
Bayless What oil for Datsun 5 speed? Spridgets 7
L General MG Five speed MG 6
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G 5-Speed Conversions Austin Healey 15
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
Michael Oritt Pilot Bearing Adapter for Smitty's 5-Speed Kit Austin Healey 3
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
shadowfever Datsun 5-speed info neede Spridgets 5
Michael Oritt Smitty's Five-Speed Manual Austin Healey 1
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
PAUL161 T-Series 5 Speed Road Test MG 25
PAUL161 T-Series 5 Speed Transmission MG 85
WHT Tremec T-5 Five-Speed Transmission Austin Healey 39
Michael Oritt Difficult-Shifting Toyota Five-Speed Austin Healey 17
crispy Idle Speed Variation Austin Healey 19
Cappy Toyota 5-Speed Austin Healey 3
Cappy Toyota 5 Speed transmission Austin Healey 4
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
T maybe a Datsun 210 5 speed available in Oakland? Spridgets 2
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
I GT6 A type OD vs D type - engagement speed? Triumph 3
HealeyRick Toyota 5 Speed - Truck or Supra? Austin Healey 16
Michael Oritt Toyota 5-speed shifter bushing Austin Healey 7
roscoe 5 speed conversion question Austin Healey 9
Lin Toyota 5-speed bell housing drain hole Austin Healey 14
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
roscoe Caving In [5-speed conversion for BN2] Austin Healey 29
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
Editor_Reid “Healey: Cars for Speed & Glamour” Exhibition Austin Healey 5
S TR2/3/3A Speed O not working Triumph 27
M TR6 5 speed conversion Triumph 33
PAUL161 T-Series Who's still building 5 speed conversions. MG 4
Zitch For Sale TR4 - 4 Speed Triumph Classifieds 7
mctriumph For Sale 5 speed kits for supra conversion Triumph Classifieds 0
B "Healey 5-Speed"/Pete Delaney Contact Austin Healey 27
M 5-speed, 1968, 4.2, E-Type, OTS Jaguar 3
Bayless Question on 1 speed wiper motor Spridgets 2
Rut 5 speed install Spridgets 14
drooartz Leaking 5-speed drain plug Spridgets 26
Michael Oritt Toyota 5-speed Problem Austin Healey 28
F TR6 Squeal When Turning Sharply at Low Speed Triumph 6
S Wedge 4-speed gearbox problem Triumph 6
