5 Speed Driveshaft Yoke
J
John Kuzman
Steve -
Both of the splines measure 1.495 " OD the entire length of the yoke. The tech at PTI noted that the Spicer yoke that came with the kit is a 20 on 21 spline. One spline is cut down. The spline that fits is spec'd as an involute 21 spline.
Do you know if your driveshaft is 2" or 2.5" diameter? Did you use the 2303-21 yoke?
I found a local high performance shop that specializes in Japanese vehicles. They race a Toyota Supra. Going down there this morning.
steveg
Will look forward to hearing how it turns out.
Sorry can't answer questions about part numbers or diameter of shaft. Probably a 2"-er.
A driveshaft guy made it up for me and it just fit. Lucky me, I guess.
J
John Kuzman
Pete Delaney does exist! He called me this morning, but we were both on the road. He gave me some suggestions, and I will try his ideas. He is also going to talk to his driveshaft builder to gather additional information. I will follow up once I complete Pete's suggestions and have my sit down with the drive train guru at the local performance shop. They are a first class shop. A service area filled with Datsun's (one Fairlady), Toyota's, Honda's, Mazda's etc. Mostly older models. A couple of SCCA race cars. The drivetrain technician was out today. He has over 27 years of gearbox experience. The owner and the counter guy knew just about everything concerning Toyota W-xx Series transmissions.
Patrick67BJ8
One odd thing I found out when I was having problems with my Toyota transmission sliding out
of 5th gear was that there were no part numbers on a lot of stuff so the shop that repaired the transmission had to match the parts with parts they had in stock.
J
John Kuzman
UPDATE: I am officially 5 speeding! The Gearbox Guru from the race shop stopped by my shop last Saturday (Okay, I enticed him with a six-pack). He looked over the situation and agreed that the Delaney Spicer slip yoke is the proper yoke for Toyota W-xx Series transmissions. He thinks that the second transmission, now installed in the Healey, could be a W Series, but not a 58. No way of really telling what it is without doing a detailed exam and gear ratio test.
He took some measurements and took the other Toyota splined yoke that I had (Toyota 1-2303-21) and said he would have his driveshaft guy build me a driveshaft that would work. Picked up the new driveshaft this morning. All is good.
He also took with him the first transmission that would jump out of fifth gear. He said that the transmission was never "rebuilt" as the seller claimed. At best, someone changed the oil seals. The fifth gear slider is junked and the entire fifth gear assembly is pretty much scrap. He wants to finish the rebuild and put it through its paces in his test jig. Then I will decide if I want to swap out the transmissions.
steveg
John,
If you decide you want to do a 'science project' to see which transmission(s) you have, on the bench:
-- Print out the Wikipedia article "Toyota W-series transmissions" - it has all the ratios
-- get yourself a piece of art for a circle divided into percentages, print out a copy for the front of the trans and the output end
-- IIRC the reverse gears are most unique (refer to article); Supra 5th is .78 (128%) the rest are around .85 (118%). You get the percents by dividing 1.0 by the ratio (i.e.1.0/.78 = 1.28)
-- if you have the shift lever off, the shift pattern is a mirror image, i.e. reverse is all the way to the left and forward; 5th is left and rearward
-- put the percent wheels on front and back of trans
-- If you have the Supra (W58 IIRC), with it in 5th, rotate the input shaft one full turn and you'll observe the output has gone past one full turn to the 28% point
-- If reverse is, say, 3.5 then you'd see the output shaft move approximately 29% in the other direction.
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
PAUL161 Jag 5 speed? Jaguar 5
T Datsun 5 speed potentially available from wrecker: Spridgets 0
Bayless What oil for Datsun 5 speed? Spridgets 7
L General MG Five speed MG 6
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G 5-Speed Conversions Austin Healey 15
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
Michael Oritt Pilot Bearing Adapter for Smitty's 5-Speed Kit Austin Healey 3
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
shadowfever Datsun 5-speed info neede Spridgets 5
Michael Oritt Smitty's Five-Speed Manual Austin Healey 1
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
PAUL161 T-Series 5 Speed Road Test MG 25
PAUL161 T-Series 5 Speed Transmission MG 85
WHT Tremec T-5 Five-Speed Transmission Austin Healey 39
Michael Oritt Difficult-Shifting Toyota Five-Speed Austin Healey 17
crispy Idle Speed Variation Austin Healey 19
Cappy Toyota 5-Speed Austin Healey 3
Cappy Toyota 5 Speed transmission Austin Healey 4
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
T maybe a Datsun 210 5 speed available in Oakland? Spridgets 2
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
I GT6 A type OD vs D type - engagement speed? Triumph 3
HealeyRick Toyota 5 Speed - Truck or Supra? Austin Healey 16
Michael Oritt Toyota 5-speed shifter bushing Austin Healey 7
roscoe 5 speed conversion question Austin Healey 9
Lin Toyota 5-speed bell housing drain hole Austin Healey 14
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
roscoe Caving In [5-speed conversion for BN2] Austin Healey 29
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
Editor_Reid “Healey: Cars for Speed & Glamour” Exhibition Austin Healey 5
S TR2/3/3A Speed O not working Triumph 27
M TR6 5 speed conversion Triumph 33
PAUL161 T-Series Who's still building 5 speed conversions. MG 4
Zitch For Sale TR4 - 4 Speed Triumph Classifieds 7
mctriumph For Sale 5 speed kits for supra conversion Triumph Classifieds 0
B "Healey 5-Speed"/Pete Delaney Contact Austin Healey 27
M 5-speed, 1968, 4.2, E-Type, OTS Jaguar 3
Bayless Question on 1 speed wiper motor Spridgets 2
Rut 5 speed install Spridgets 14
drooartz Leaking 5-speed drain plug Spridgets 26
Michael Oritt Toyota 5-speed Problem Austin Healey 28
F TR6 Squeal When Turning Sharply at Low Speed Triumph 6
S Wedge 4-speed gearbox problem Triumph 6
