Gliderman8
5-Speed conversion up-date
With way too much time on my hands I began the conversion process.
Below are some photos detailing the steps I have gone through to remove the tranny.
From top to bottom:
Bleed and remove the clutch slave cylinder
Remove the speedo cable
Disconnect the rear drive flange from the drive shaft (prop shaft for Steve :laugh: )
Out she comes with a little help from below with a floor jack.
Since I have a flat finger pressure plate, I will need to replace it with a bent finger pressure plate to accommodate the new hydraulic throw-out bearing.
edit: Drive shaft out for balancing today.
To be continued.......
Note: if you have any heater issues, NOW would be the time to address them
From top to bottom:
