3.54 Ring and Pinion
BJ8TONY
Rob
Why do feel this is the best modification that you have made??
If you put a lot of miles on your car you'll appreciate less NVH. Key points:
- much more relaxed pace on highways/freeways (where, face it, you do most of your driving if you cover long distances)
- (slightly better) gas mileage
- second gear more useful in most instances
- first gear not so gosh-awful low (takes a little more finesse to get a smooth launch, though--best to more-or-less just dump the clutch)
Since Big Healeys are pretty torquey, and not drag racers no-matter-what, overall it's a terrific upgrade. One astute writer once claimed the 3.54 diff with 28% O/D was the best possible configuration.
Keith_M
I'm curious about this. Was this an original item for a limited number of years? Why are there so few available?
I did an internet search and didn't come up with much information, but I did find this site that appears to be selling new ones. Anyone have more information?
https://www.354gears.com/index.html
Keith
Rob Glasgow
BJ8TONY, I think it's the best modification for all the reasons Bob mentioned above. It really makes the car a pleasure to drive.
Keith, I believe the 3.54 ratio was standard on Healey's made without an overdrive. The OD was an option on the early cars but not many were build without OD. That's why those rear ends were scarce. I don't know if the later cars (BJ8) all came with OD and the 3.9 ratio.
... I don't know if the later cars (BJ8) all came with OD and the 3.9 ratio.
I believe that's the case. A while back (10-12 years maybe), Michael Lempert--of steering wheel fame--had a limited production run done. He charged $200, and I got a set. '354gears' is being run by Michael's son. There are some other manufacturers making them, but now the cost is very high (around $700 or so). I think Denis Welch might have them; Gary Hemphill had them for a while but he's out of business.
Keith_M
Thanks for the replies and the info. I did find them at Denis Welch, but they're 595 British pounds, which translates to $960! Yikes!
It does seem like a nice modification though. I'll have to watch the one on ebay...
Keith
davidb
Several years ago I had a whine in my BT7 rear end, and I had read that the Austin Westminster (a six cylinder British sedan) used a compatible rear end for Healeys, that allowed for better cruising at speed, so I found a scrap dealer who had several old Westminsters, swapped him for some surplus MGB stuff, and changed out the old rear end for this one, which was stamped "39T11". This apparently equates to the 3.54 ring and pinion discussed here, at least according to the website listed below. If you can find a scrapyard with old Brit cars, these models were pretty popular back in the 60s. https://www.ntahc.org/techtips/REAREND1.html
Now I'm not a technical person (far from it), but from a purely subjective observation, I have found this to be a better setup than what was originally in the car.
stretchit2
I put the Lempert Gears in last year and I think they are great. One of the guys in the So Cal club just ordered and received them from Lempert in short order. As I understand it they have extra sets right now. My advise would be to snap these up before there all gone.
I bought in early and I waited more than a year for mine, and I would do it all over again.
Get em while there hot.
Jeff
BigGreen
Link to Lempert anyone ?
Hans
BJ8Healeys
I got one of the first 3.54 gear sets of the production run by Mike Lempert in 2002. That is, I received and installed the gear set in 2002 but it was two years from deposit to receipt of the product. My continuing thanks to Mike for starting and continuing the project to remanufacture the gears through to the finish. I agree that for anyone who puts miles on their Healey, the modification from 3.91 to 3.54 gears is about the best modification that can be done due to easy cruising and slightly better fuel economy. It has been that for me for 65,000 miles.
Overdrive remained an "option" for Healeys to the end of BJ8 production, so it isn't true that all later cars had overdrive. However, very few Healeys came to North America without overdrive and the 3.91 rear end. Non-overdrive equipped cars were much more common for RHD cars for the UK home market. There were some few "Personal Export Cars" specially ordered by the first owner without overdrive (probably to save a few bucks), and some of these came to North America. Thus, original 3.54 rear ends have always been pretty rare hear. There were other Austin cars that used the 3.54 rear ends besides Healeys, but I think they also were relatively rare in America.
Keith_M
I see there is now another of these on ebay, but this one is "brand new" and $600. I'm assuming this is one of the Lempert-made ones.
Keith
5
57_BN4
What are you guys doing to recalibrate the odometer/speedo for the new diff ratio?
I had a speedometer shop install new ratchet gears for the odometer and trip meter. The speed cal is just done by moving the needle.
steveg
You remove the cable from the back of the speedo, attach a pointer to it, such as a piece of masking tape, push the car through 52 feet, 9-1/2" and measure the number of turns the pointer makes. This enables the speedo shop to re-calibrate your speedometer. I've used Nisonger in New York; West Valley Instruments (Morris Mintz) can do it in LA.
Nisonger has a pdf on how to do this.
Peter Roses just added the 3.54 to his BN6 with the 28% overdrive and he informs me 3000 rpm is now about 81mph!
My BN6 has the 3.54 axle with the Toyota W58 Supra trans which is 22% overdrive and 3000 rpm is about 74mph.
C For Sale New in box 3:54 ring & pinion Austin Healey Classifieds 4
T How do I clean sand out of a ring & pinion? Spridgets 2
JAV 3.5 ring and pinion Austin Healey 18
P Identifying a Ring and Pinion Austin Healey 8
M For Sale bj8 ring and pinion gears 3:55 for sale Austin Healey Classifieds 6
K TR2/3/3A Ring and Pinion Wear? Triumph 11
Sarastro TR4/4A Looks like I need a new ring and pinion... Triumph 30
histerical Ring and Pinion Spridgets 8
B Ring and pinion question Austin Healey 29
aeronca65t Ring & Pinion Spridgets 8
R Installing pinion and ring gear Austin Healey 11
MikeAH100M Pinion/Ring Gear Lash Spridgets 2
TulsaFred 3.90 ring/pinion Spridgets 24
I Correct ring and pinion gear ratio for Bugeye? Spridgets 5
Ed_K Used ring and pinion set for sale in classifieds Austin Healey 0
B spridget ring and pinion.. what type Racing 0
B Spridget ring & pinion What year? Spridgets 11
H 3.54 Ring and Pinion Austin Healey 16
Dave Richards 3.54 ring and pinion gear Austin Healey 13
Randy Forbes 3.54:1 Ring & Pinion... Austin Healey 5
C Ring and pinion question... Triumph 4
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
sail TR4/4A Piston Ring Question Triumph 6
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
K TR2/3/3A The chrome ring around the bakelite horn button? Triumph 4
J TR2/3/3A 87mm piston ring gaps Triumph 15
Jim_Stevens TR2/3/3A Ring gear shot? Triumph 26
B Snap Ring Plier Restoration & Tools 3
S CHROME RING, shift lever grommet ....? Austin Healey 3
dbenichou289 TR2/3/3A Headlight outer trim ring Triumph 6
dbenichou289 TR2/3/3A Carb Sealing Ring Triumph 6
DrEntropy MGB Ring Gear Roulette MG 12
S TR2/3/3A glass and ring into new bee hive sockets Triumph 15
sundown TR6 Proper ring gaps Triumph 6
TomMull hydraulic fittings "O ring face" Restoration & Tools 6
M TR2/3/3A Another TR3 Piston Ring Gap Question Triumph 1
J TR2/3/3A Hastings Piston Ring End Gap Issue Triumph 16
I TR6 Aluminum trim ring band removal Triumph 5
T TR4/4A Attaching headlight trim ring Triumph 6
D BT-7 tri-carb ring gap Austin Healey 10
bfitz Zenith Stromberg O ring question Other British Cars 8
J TR6 Ring gear repair Triumph 13
KVH General Tech Hastings Oil Ring Triumph 13
H Wanted Herald headlamp Chrome Rim retaining ring Triumph Classifieds 0
T Question regards headlight ring 'thickness' for bugeye Spridgets 3
G Heater Control Valve AH BJ7 - O-Ring Placement[s] Austin Healey 2
6TTR3A TR6 Magnetic ring in the early gas cap Triumph 2
Gliderman8 TR6 Starter not engaging into ring gear Triumph 32
JPSmit Question four - headlight trim ring Spridgets 9
tinman58 General TR Ring Gear @ 6000 rpm's Triumph 6
