For Sale 1979 MGB for sale
wingsandwheels
69k miles, one owner before me. Great driver, starts easily, excellent oil pressure, no taps/knocks. Usual British car oil leaks. New redline oils in drivetrain. Nice, complete example of a late 'B. Has minor rust behind/below the wheels, structural channels are fine, floors solid, battery area solid, bulkheads solid, spring mounts solid. Paint is OK, some sap spots, etc. as the car sat for a while. New alternator, fan motor, hoses, plugs, wires, seat belts, dash cap, fabric tailored seat covers, etc. All gauges, clock, switches and controls, interior lights, etc. work. New cheap radio. New Hankook 185/14 tires, trim. Shocks good, front bushings will need attention over the next few years. Brakes good. Most original emissions plumbing in place.
Ok soft top w/ decent window, OE hardtop (needs door seals) and tonneau.
Good candidate for a spruce up or just drive for a few years and tackle it one Winter. Easy first hobby car.
I bought this from a local elderly gentleman, the first owner, as a fun driver (decided my TR6 is too original/nice for running errands, etc., due to some close calls probably from the small brake lights and no CHMSL), but another fun car opportunity dropped in my lap. Need barn space.
Ask any questions. Car is in central Mass.
$5,250
pipermeister at yahoo . com
boxofparts MGB busy tach on 1979 MGB at 75 mph MG 3
wingsandwheels MGB 1979 MGB coil w/ altered wiring MG 6
N MGB 1979 MGB exhaust replacement. MG 1
A MGB 1979 MGB Flasher Big Headache MG 3
T MGB 1979 MGB with Weber carb MG 7
R MGB Testing temp sending unit 1979 MGB MG 6
C MGB 1979 MGB Zenith Stromberg Carburetor MG 3
1979Roadster MGB 1979 MGB SITTING FOR 17 YEARS MG 12
C MGB 1979 MGB steering wheel socket? MG 1
C MGB 1979 MGB door mirrors MG 4
C MGB 1979 MGB Photos MG 6
PAUL161 MGB MGB 1979 MG 2
P MGB 1979 MGB NEWBIE fuel tank replacement MG 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
T 1979 Datsun 210 at U-Pull in West Palm Beach, FLA Spridgets 1
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
FlyingCat Wanted 1979-80 Spitfire Radiator Mount Bracket and Cradle Triumph Classifieds 0
N For Sale 1979 Triumph Spitfire Triumph Classifieds 2
Morris For Sale Fuel Injected 1979 MG Midget Spridgets Classified 0
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
T Spitfire 1979 Triumph Spitfire 1500 Triumph 3
T Spitfire 1979 Triumph Spitfire 1500 rear wheel alignment Triumph 4
B Spitfire 1979 Spitfire Emissions Triumph 4
D 1979 Spitfire Spotted 0
R Spitfire Lbs of compression Spec for 1979 Spitfire. Triumph 3
Andrew Mace Wedge 1979 [Fed.] TR7 fuel tank questions Triumph 6
AngliaGT 1979 B Owner's Manual MG 6
startech47 1979 Midget rear hub bearing nut torque spec. Spridgets 3
M zenith float adjustment 1979 MG 1
ronzet Needed EGR valve for a 1979 MG Midget Spridgets 20
H Valve cover paint 1979 Midget Spridgets 8
startech47 1979 Midget Wheel Bearing Numbers Spridgets 0
P 2 midget problems 1979 help! Spridgets 2
B Have Available for Midget [Its from a 1979]... Spridgets 0
B 1979 Midget Wiring Diagram, Harness, etc. Spridgets 6
B Spitfire Sellng my 1979 Triumph Spitfire 1500 Triumph 1
PATR8 1979 MG for sale MG 1
B 1979 MG Midget Headrest available..just pay shipp. Spridgets 2
1979Roadster 1979 OVERDRIVE TRANNIE MG 3
B Help with 1979 Radiator Spridgets 19
B 1979 MG Midget Headrest Available! Spridgets 3
B My 1979 Midget...before and on its way to rebirth! MG 10
kyreb1862 Wedge 1979 TR7 Roadster Automatic Triumph 0
startech47 Static timing a 1979 Midget Spridgets 4
X 1979 LE console removal MG 9
S 1979 rear shock conversion kit worth it? Spridgets 10
S White disk in drivers seat 1979 Midget? Spridgets 3
C Triumph colors from PPG book 1979 Triumph 2
