MGB 1979 MGB Flasher Big Headache
allendale1bozo
1979 MGB roadster.....I am so confused! Flashers will not funtion. Right rear flasher will not light. Bulb good, flasher switch is good, ground good, hazzards work (fast) except that one rear right. This is (I think) the reason why my turn signals will not operate ... Any ideas/ new member/ thanks...:hammer:
Platinum
Re: 1979 MGB Flasher Big Headache
First, welcome aboard!
If it is JUST that one lamp, you likely have a bad bulb or contact at the base of it. Lens off, bulb out, do a "hospital clean" treatment to the socket and contacts. Just replace the bulb, they're cheap.
bob67bgt
I have also seen where the socket thats crimped to the tail light base is not grounding. Might want to try a jumper wire to ground and see if thats the problem. If non of your turn signals operate then the hazard switch may be dirty inside or the 2nd flasher is bad. I think one is behind the radio console and the other (which operates the signals) is on the passenger side behind the dash. Welcome to the BCF! Bob
Platinum
Go HERE and find the appropriate wiring diagram for reference,
The hazard switch effectively changes between the hazard circuit (making all four corners flash at once on its own flasher) and the directional signal one.
If the ONLY bulb not flashing is that rear one with the hazard switch in either position, the bulb/socket is your issue. If the directional signals don't function AT ALL on either side, look to the hazard switch or directional flasher Bob referenced on the starboard side under the dash. You may have two problems at once.
boxofparts MGB busy tach on 1979 MGB at 75 mph MG 3
wingsandwheels For Sale 1979 MGB for sale MG Classifieds 0
wingsandwheels MGB 1979 MGB coil w/ altered wiring MG 6
N MGB 1979 MGB exhaust replacement. MG 1
T MGB 1979 MGB with Weber carb MG 7
R MGB Testing temp sending unit 1979 MGB MG 6
C MGB 1979 MGB Zenith Stromberg Carburetor MG 3
1979Roadster MGB 1979 MGB SITTING FOR 17 YEARS MG 12
C MGB 1979 MGB steering wheel socket? MG 1
C MGB 1979 MGB door mirrors MG 4
C MGB 1979 MGB Photos MG 6
PAUL161 MGB MGB 1979 MG 2
P MGB 1979 MGB NEWBIE fuel tank replacement MG 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
T 1979 Datsun 210 at U-Pull in West Palm Beach, FLA Spridgets 1
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
FlyingCat Wanted 1979-80 Spitfire Radiator Mount Bracket and Cradle Triumph Classifieds 0
N For Sale 1979 Triumph Spitfire Triumph Classifieds 2
Morris For Sale Fuel Injected 1979 MG Midget Spridgets Classified 0
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
T Spitfire 1979 Triumph Spitfire 1500 Triumph 3
T Spitfire 1979 Triumph Spitfire 1500 rear wheel alignment Triumph 4
B Spitfire 1979 Spitfire Emissions Triumph 4
D 1979 Spitfire Spotted 0
R Spitfire Lbs of compression Spec for 1979 Spitfire. Triumph 3
Andrew Mace Wedge 1979 [Fed.] TR7 fuel tank questions Triumph 6
AngliaGT 1979 B Owner's Manual MG 6
startech47 1979 Midget rear hub bearing nut torque spec. Spridgets 3
M zenith float adjustment 1979 MG 1
ronzet Needed EGR valve for a 1979 MG Midget Spridgets 20
H Valve cover paint 1979 Midget Spridgets 8
startech47 1979 Midget Wheel Bearing Numbers Spridgets 0
P 2 midget problems 1979 help! Spridgets 2
B Have Available for Midget [Its from a 1979]... Spridgets 0
B 1979 Midget Wiring Diagram, Harness, etc. Spridgets 6
B Spitfire Sellng my 1979 Triumph Spitfire 1500 Triumph 1
PATR8 1979 MG for sale MG 1
B 1979 MG Midget Headrest available..just pay shipp. Spridgets 2
1979Roadster 1979 OVERDRIVE TRANNIE MG 3
B Help with 1979 Radiator Spridgets 19
B 1979 MG Midget Headrest Available! Spridgets 3
B My 1979 Midget...before and on its way to rebirth! MG 10
kyreb1862 Wedge 1979 TR7 Roadster Automatic Triumph 0
startech47 Static timing a 1979 Midget Spridgets 4
X 1979 LE console removal MG 9
S 1979 rear shock conversion kit worth it? Spridgets 10
S White disk in drivers seat 1979 Midget? Spridgets 3
C Triumph colors from PPG book 1979 Triumph 2
