Order of Assembly? Do and don'ts?
christophe
I am about to start the reassembly of the 1960 3000 austin healey and I'm trying to get a game plan before I just start throwing parts on the car. Any advise would be greatly appreciated. I hate when I bolt an item on only to realize i need to remove it before I can install another item.
My thoughts are that the #1 item to be addressed is to make the car into a roller, so i should start with the suspension, then the brakes, brake lines, and steering.
After the car is a roller with operating brakes and steering, then i plan to drop the engine and transmission into place. Next i will install the fresh air ducts and any other items that appear to be near impossible to install once the fenders are in place.
Once all of this is finished, the car will go back to the paint shop for final fitment of the exterior panels and after that is finished, they will be painted. Normally I would not start installing parts until after the entire car was painted, but due to the complexity and tight fit of the healey components, there is no way i want to install the engine and transmission over top of freshly painted fenders.
Ok, so if you have any suggestions on items that should or should not be installed or a link to a thread that shows a nice progression of assembly on a superstructure, that would be great.
Thanks
RestoreThemAll
Wiser, more experienced people than I will join in I'm sure. I would suggest painting the inner side of all panels before bolting on. I'd think that everything, like air ducts that you mentioned would go on before the engine install. That said I've heard folks on this forum speak of plenty of engine installs with the shroud in place. It would be nice if someone had a step by step process.
AH100M
Are you putting in a new wiring harness? That should go in first, along with the battery cable. Then the suspension and then the brake lines. The instrument panel and gauges are easier to work on without the steering column in place. Air ducts next. Engine/gearbox next, then body panels including shrouds. The rest of the interior is next to last. Last is the top (hood). Chrome trim, etc. as appropriate. You may want to attach the fender spears to the fenders before you mount them unless you have thin arms like me!
HealeyRick
This is a good order of operations, but before you dig in, now's the time to consider what, if anything, you're going to do about rustproofing, heatproofing and soundproofing. It will make it a much more comfortable car in the long run. If I was using the car as a regular driver, I'd apply the heat and sound Lizard Skin materials now. https://www.lizardskin.com/ or if you want to save a few bucks, you can do the DIY stuff I did: https://forum.britishv8.org/read.php?13,8264. Using something like Waxoyl in the chassis and sills will keep rust at bay. While you're putting the wiring harness through the firewall, look for ways to seal up any holes from the engine compartment into the interior (even the small ones where the wiring harness passes through the grommets. Then you can start on the suspension. I think I'd send my brake drums out for balancing now, just because I'd do it as a matter of course on any car since they all seem so far out. If you're doing any chrome work, that should probably go out now as well so it will be ready when the car is done.
Whatever you do, make sure the air hoses go in before the shroud and fenders or you'll hate yourself for ever!
RAC68
I do agree with what has already been suggested. I would add that when addressing rusted repairs, make sure that the frame is well supported, squared, and reinforced at key locations to reduce the risk of deformation when cutting out sections. Along with welding bars to maintain proper positioning, I have cut some 4X4 beams that can be fitted at strategic frame sections.
Also, when reinstalling outer panels, I start at the front and work back. My first application is the front shroud followed by the front fenders and then the doors. This allows me to properly set the spacing between the fender and door. Continuing, I would suggest fitting the rear shroud followed by the rear fenders.
Although others may have a different procedure, I have tried a few and always come back to this approach.
Good luck and enjoy your project
Ray (64BJ8P1)
Healey Nut
Im on my second restoration and Im following the same pattern on both . Turn it into a full rolling driveable chassis first all painted and pretty with no body panels . Do any major exterior body panel prep with the body panels off the car . once they are lets say 80% ready . paint and finish the inside of the doors , wings , shrouds etc . Fit all the body panels and finish the exterior prep and paint it . Do the interior then all the pretty stuff .
Finally drive it everywhere you can with the biggest grin you can and watch all the heads turn as you drive by .
Patrick67BJ8
I was told to install the Hand Brake assembly first and I'm glad I did. I had it rechromed and then I wrapped the chrome with protective wrapping and I'm really glad I did that!
AH100M
As long as the hand brake assembly goes in before the driveshaft, which gets in the way almost as much as the steering column does. On the other hand, the brake lever sure gets in the way when you're doing carpeting!
Lin
Christophe,
I chronicled the week-by-week assembly of the restoration of my 1960 BT7 here: https://valvechatter.us/?cat=528
it is not the easiest site out there to manuever around in as I developed it when web-based blogs were just getting going. You can find a component that you are interested in in the assembly components list and it will tell you in which weeks the component was referenced. I am a hobbyist, not a professional restorer, and most of what I learned along the way I picked up from the great people on this Forum. Your tub looks wonderful. Now the fun starts!
Lin
C
christophe
Thanks for the replies. I have read all of them and I really appreciate the help.
Lin, i will check out your link! thank you!
Csarneson Body panel assembly order? Austin Healey 6
Michael Oritt SU H6 carb for Le Mans--order of assembly of fuel bowl lid Austin Healey 2
steveg Points assembly order of washers Austin Healey 13
Griz Assembly order Austin Healey 10
Tinkerman TR2/3/3A TR3 A REAR WING BOLTS order of assembly? Triumph 3
Crankshaft TR2/3/3A Air deflector order of assembly Triumph 5
Tinkerman TR2/3/3A Water pump order of assembly '60 TR3A Triumph 1
Tinkerman TR2/3/3A 60 TR3A FRONT CLIP ORDER OF ASSEMBLY ? Triumph 10
Tinkerman TR2/3/3A TR3A Order of Assembly Triumph 5
JPSmit Assembly Order #2 - Dash Spridgets 1
JPSmit Assembly Order Question #1 - Radiator Spridgets 1
Lin Assembly Order Austin Healey 1
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
D Tri carb: order of installation question. Austin Healey 5
Jim_Gruber In need of 2 Fulcrum Pin Bolts - MOSS Has them on Back Order Spridgets 3
K Overdrive Screen Replacement Order Question Austin Healey 4
Jim_Gruber 13" Wheels - Here's why you need to order 14" Wheels Spridgets 30
C Need to order correct size Austin Healey 4
MisterB Outer structure repair order/checklist Austin Healey 9
R TR2/3/3A Question on order of welding Triumph 31
Rut TR4/4A Body repair, order of things Triumph 2
F Replacing brake master cylinder, fluid reservoir and flexible brake pipes - order? Austin Healey 4
Got_All_4 TR6 Best place to order transmission parts Triumph 6
Tinkerman TR2/3/3A Front clip order of bolt tightning Triumph 9
Scot1966 TR6 Order of operations Triumph 3
Jim_Gruber Brake Pipes -which one to order Spridgets 32
S TR6 Starter finally cranks...then CRACK. Vicky Brit parts order time. Triumph 5
M Englishparts.com Order Problems Beware Austin Healey 2
TimK 3000 Distributor cap Firing Order/Positions Austin Healey 3
TulsaFred 1275 firing order and plug wire arrangement Spridgets 6
M Restoring proper order to spark plug wires Triumph 36
B Bugeye Reassembly Order Spridgets 9
72_TR6_Oceanside Ignition switch wiring order help Triumph 16
RickB Where to order windshield seals for 78 Midget? Spridgets 3
hondo402000 TR6 TR6 Engine Rebuild parts on order Triumph 30
Tr4dude got a small order from TRF Triumph 7
T Wedge tr7 firing order Triumph 4
bighealeysource BN6 firing order Austin Healey 2
GBRandy Wedge TR8 Powering Steering Pipes - Order Now Triumph 6
T Correct/best order for front suspension rebuild Spridgets 8
T fantastic new cam- order deadline Triumph 0
Westfield_XI 1275 firing order- help needed for 1st start! Spridgets 9
T Anything else to order from AH Spares? Spridgets 9
T Yet one more bushing question - which to order Spridgets 4
T MGA Recommended order for building MGA front susp MG 1
A Anybody ever order anything from Paeco Industries Austin Healey 4
jaegzie Anyone know where I can get or order a coil bracke Spridgets 8
angelfj1 Time to place that overseas order??? Restoration & Tools 10
Brosky TR6 Second chance on Special Order white/blue TR6 Triumph 8
drooartz Parts order... anything missing? Spridgets 5
