General TR Pressing in the Lower Control Arm Bushing
KVH
Is it OK to "sand" down the lower-inner control arm bushings, just a bit? I installed mine using grease and a press and they're in there alright, but awfully tight and a bit elongated/squashed. Should I have sanded them down more? I ran them in a drill for maybe 20 seconds and just didn't want to take more rubber off. Thoughts?
bobhustead
The two piece (metal and plastic) units on my 3 didn't even pretend to fit. I had to scrape the plastic parts with a razor blade. It took hours. You might want to go back to the rubber.
TR3driver
Great Pumpkin - R.I.P
I could be wrong, but I believe the rubber ones (4A and onwards, different than TR2-4) are supposed to be a tight fit in the arms. The rubber deflects with suspension movement, rather than turning as the nylon ones do.
CJD
The lower inner bushings are usually provided as nylon with steel inserts. Are you really installing rubber ones? If you are using a standard kit, I think you may be installing the inner upper rubber bushings in the wrong place?
Popeye
Bronze
Not sure what model Triumph you are working on - if memory serves me, a 4A? Anyhow, for my 4A, I did not need to sand any bushings (magic kit, poly, from TRF). I think I may have had to press in some bushings with a vice (low force), but definitely did not modify any of the parts.
KVH
KVH
Sorry for the late response. My car is a 4A. Those rubber/neoprene lower, inner bushings are deadly tight, and I do need to press them in but the fit is so tight that I did lightly sand the rubber down a bit. They are really stout and heavy with steel tube inserts where the bolt slides in.
Popeye
Bronze
I just looked at my photos and remember those bushings. I believe I pressed them in with a vice and appropriate sockets. The one "trouble" spot I had was the lower outer bushings; I could not get the bolt to go through the metal sleeves. I put "trouble" in quotes, as it was a non-issue, just some gentle persuasion and the bolt slipped in.
KVH General TR Pressing in the lower/inner control arm bushings Triumph 3
John_Koop TR2/3/3A Front brake calipers locking up when pressing on brake. Triumph 18
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
S TR2/3/3A Pressing in silenblocs Triumph 7
Moseso Pressing things apart Triumph 1
Racer-X- Metalastik Lower wishbone bushings and upper fulcrum pin bushings Other British Cars 6
S TR2/3/3A lower small brass bushing Triumph 13
S TR2/3/3A steel bushings for the lower Arms Triumph 10
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
R TR6 Lower A-arm trunnion bushings Triumph 18
edkap2002 TR6 lower radiator hose fitting Triumph 2
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
B Wanted 100-6 or early 3000 upper and lower grille opening pieces Austin Healey Classifieds 1
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
B TR2/3/3A lower wishbone installation Triumph 5
L TR2/3/3A Bent lower wishbone arms Triumph 6
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
KVH TR4/4A Should I Cut the Lower Windshield Gasket Triumph 2
KVH TR4/4A Lower Control Arm Front Pivot Bolt Triumph 9
C TR6 Lower A-arms Triumph 8
wangdango BJ8 lower radiator hose! Austin Healey 2
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
I General TR Lower wishbone arm attachment bracket advice needed Triumph 8
Rut TR4/4A Lower fulcrum brackets Triumph 3
M TR2/3/3A FRONT SUSPENSION: Rusted lower control arm fulcrum Triumph 17
Tr3aguy TR2/3/3A Lower control arm question Triumph 2
aero3113 100 lower windshield seal Austin Healey 4
RCarr BN1 Lower Control Arms Austin Healey 0
C BN1 sitting lower at left rear - I'm told that's normal - really? Austin Healey 13
K TR2/3/3A The "air vent"on the lower part of the front apron below the grille.... Triumph 5
Jeepster Lower wishbone bush replacement. Austin Healey 33
H Post-War Other Herald rear suspension lower block installation Triumph 3
Scotsman TR4/4A Lower steering flex joint upgrade to TR6 Universal joint Triumph 2
Martinld123 Want to lower car about an inch Austin Healey 4
Rut TR4/4A Lower crash pad Triumph 9
KVH General TR Lower Control Arms Triumph 1
BoyRacer BN1 lower control arms Austin Healey 1
B TR2/3/3A Removing front lower wishbone confusion Triumph 3
M TR4/4A Left lower dash crash pad. Triumph 5
Geo Hahn TR2/3/3A lower generator bolt Triumph 7
K TR2/3/3A Refresh...main reson why idle will lower when kicking the gas pedal? Triumph 3
M TR4/4A Lower crash pads for dash....help. Triumph 4
sqbsprite TR6 Frame cracking around lower control arm mount, have you checked yours? Triumph 3
Keith_M Lower wishbone recondition? Spridgets 5
PAUL161 T-Series Windshield lower rubber MG 5
J TR2/3/3A Lower windshield rubber seal Triumph 3
B Lower Steering Column Bush - Where does it go and how? Austin Healey 14
madhouse RF Fender and Lower Cowel Body Parts needed Austin Healey 10
J Poly Lower A-Arm Bushings - One easy question as I am confused Austin Healey 1
