Results 1 to 4 of 4
Thread: Servicing BJ8 drum brakes
Forum to discuss Austin Healey Sports Cars
  1. #1
    Join Date
    Dec 2001
    Location
    Seattle,WA.
    Posts
    150
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Guys,
    I have rebuilt my cars front brake calipers,brake booster and most of the lines lines but have never fiddled with the rear drum brakes. They are not giving me any trouble presently nor have they but want to be proactive on the service. A search of the forum yields no results as to just how to maintain the system back there. I have never had the drums off to check the pads so I know that's the first thing but how about greasing,cleaning and lubricating for maintenance sake? Thanks!
    Scot (1966 Austin Healey BJ8)
  2. #2
    Yoda John Turney's Avatar
    Join Date
    May 2002
    Location
    Concord, CA
    Posts
    3,048
    Thanks Thanks Given
    17
    7
    Thanked in
    Re: Servicing BJ8 drum brakes
    First, don't blow the dust off with compressed air - it's not good for your health. You need to bleed the brake fluid every couple of years. If the rubber dust seals on the cylinders are cracking, you should rebuild the cylinders. Also check for free movement and corrosion. If the cylinder doesn't move slightly on the back-plate, clean it up and use some anti-seize. Also, the friction material is "shoes" on drum brakes, not "pads".
    John, BN4
  3. #3
    Join Date
    Dec 2001
    Location
    Seattle,WA.
    Posts
    150
    Thanks Thanks Given
    Thanked in
    Ok, thanks for the good tips John...will recheck those shoes!
  4. #4
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,491
    Thanks Thanks Given
    1
    23
    Thanked in
    New, 'no name' rear cylinder for BJ8 from Moss: $17.49
    Rebuild kit for same: $12.99
    I just installed a 'no name' on my BJ8; quality appeared to be as good as the original Girling that was shot.
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
