Which steering wheel ??
BOBBYR
Hi Guys, I hope you are all doing well . Here on the east coast , the weather has been gorgeous . Really great for driving .Anyway , I think it's about time to get rid of my old cracked steering wheel in my 65 bj8 , so I thought I would put it out there so you can tell me the do's and don'ts . I thought of the moto lita wheels but I'm not sure which parts go along with operating turn signals and horn . Any suggestions would be appreciated . Thanks for your help , BobbyR
DerekJ
Moto Lita make excellent wheels and bosses. You need to buy the boss to be able to fit the wheel. The trafficator can be refitted into the Moto Lita set up without any problems or you can use the opportunity to ditch the trafficator and install one of their aluminium horn push buttons which look really good. Then just put a switch on the dash for your indicators.
EV2239
I have a Nardi on my Porsche and the standard wheel restored on my Healey. After a Nardi the Motolitas don’t seem so great, so I got the standard one restored. I’d go with Bob’s recommendation.
Here's the Lempert wheel I got for our 100M (spent extra for chechen wood and the flush riveting instead of screws on the hub):
I had to wait about 8 mos., as Mike sources his hubs from Moto Lita and they were back ordered and require machining to fit.
maxwedge5281
16179180_10207859219108146_237276112729826_o.jpgwhy don't you keep the original wheel....and reduce to thirteen inches! knock the plastic off, cut the hoop, roll a new one to 13 inches and have it recovered...to me looks much better than a wooden wheel as I love the banjo look!
RAC68
Hi Bobby,
Yes, the driving the past few days was great in NJ.
Although your choice of steering wheel is a factor of taste, I must point out that the configuration of the wheel is also a factor of choice. The original wheel has a diameter of 16.5" with one spoke that goes up between the gauges and 2 down (as in an inverted "Y" see most of the pictures above). I had acquired a wooden 15.5" steering wheel (and hub) at a swap meet at least 3 decades ago that needed refinishing. Although the 1" difference seems small, the extra space at the legs was very beneficial for comfort and did not noticeably lessen the steering ease. Additionally, the spokes on my wheel are in the form of a "T" with the center strut downward. This configuration allowed the gauges to appear unencumbered as with the original configuration.
Although the wheel configuration will not cause major operating differences, I would suggest considering the pattern and diameter that makes you feel most comfortable when driving.
Ray(64BJ8P1)
shortsguy1
MaxWedge-
Could you comment on the difficulty of steering at low speed with a 13 inch steering wheel? I have planned to do something similar to what you describe, but worry about maneuvering in parking lots.
dougie
The iconic look of a handmade wood steering wheel on a classic sports car is the perfect nuance that compliments their spartan interior. I custom ordered a 14" Moto-Lita wheel for my '57 vintage racer and love the look and feel.
maxwedge5281
I'm 77 and have no problem with steering resistance. you lose some leverage but the spoked...banjo...wheel looks much more at home in the healey to me! and the smaller wheel gives so much more room in the cockpit! but, I do have a much lighter engine with the sbc conversion and 200 4r four speed automatic overdrive transmission!
RAC68
Hi Shortsguy,
When going from 16,5" to 13" steering wheel, I would expect you would experience a much greater steering effort as a result of the lost wheel torque. The Healey has a heavy engine and a less-then-efficient steering box and configuration which I expect would require excessive driving effort resulting in fatigue on longer drives. Although I have seen 13" wheels installed in Sprites, I know of no one that has installed that size wheel on a Big Healey.
My thoughts,
Ray(64BJ8P1)
shortsguy1
MaxWedge-
Thanks for answering my question. And for clarifying how your engine weight differs from standard.
Ray-
My plan is actually to go from 16.5 inch to 15", assuming I can ever get around to it. I was simply asking MaxWedge since he has first hand knowledge of a relatively small wheel for a Healey. In my case, a 15" steering wheel will give a little more room for my legs, but hopefully not change the steering at low speeds too much. I have a spare, old, beat up healey steering wheel, which I plan to use the hub and spokes from. I found an inexpensive (new) tractor steering wheel, which is 15" diameter with spokes in the same location as a Healey's. When time allows, I just need to figure out how to safety attach the healey spokes to the tractor steering wheel. This will obviously involve removing any steering wheel plastic where the banjo spokes will attach. I then plan to use epoxy to re-create whatever portions of the tractor steering wheel were removed. A nice coat of primer and black paint will hopefully hide all of my handiwork (or not-so-handiwork in my case). If it still looks ugly, I will just get a nice leather cover to hide my poor craftsman skills. If I do ever do this, I will document it all so that others can partake later if interested.
John Turney
.... When time allows, I just need to figure out how to safety attach the healey spokes to the tractor steering wheel. This will obviously involve removing any steering wheel plastic where the banjo spokes will attach. ....
IIRC, the Healey rim has a metal (steel I presume) ring under the rim that the spokes are welded to. I would assume the tractor wheel would also. You will have to remove quite a bit of the plastic when you weld them together.
John Turney
Hi Shortsguy,
My thoughts,
Ray(64BJ8P1)
I have a 15" wheel and 195/65-15 tires. Long drives are not a problem because the car movement allows the tires to turn easily, but parking at car shows takes some real effort when backing into a space.
maxwedge5281
when I reduced my steering wheel, I had a hoop rolled. I cut the original healey rim off. I then drilled through the new rolled hoop such that the individual banjo spokes passed through the hoop. then the spokes are welded in place in the hoop. very strong and very sturdy!
Patrick67BJ8
BCS sells a bearing for the top of the kingpin that is called “Torrington” bearing. It helps to make steering easier with the small,er diameter wheels. I installed mine when I restored my BJ8.
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
K 1968 Midget Steering wheel Spridgets 1
Editor_Reid Wrapped Steering Wheel Austin Healey 9
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
kodpkd Leather Steering Wheel Cover Austin Healey 3
S Steering Wheel Brand Austin Healey 5
B TR4/4A What is this Steering Wheel Center? Triumph 6
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
Celtic 77 MGB Steering wheel fitment MG 11
S TR2/3/3A Steering wheel removal. Triumph 4
LAW75 Derrington Steering Wheel Austin Healey 19
waltesefalcon New steering wheel Other Cars 2
R TR2/3/3A Steering Wheel hitting my belly Triumph 22
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
A Austin A40 trafficator steering wheel Other British Cars 5
T Steering Wheel Adjustment Range Austin Healey 0
R TR2/3/3A Steering wheel hub removal Triumph 11
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
J Wanted Adjustable steering wheel circlip Triumph Classifieds 4
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
Cappy Moto-Lita Steering Wheel Installation Austin Healey 3
K TR2/3/3A Steering Wheel hold down Nut Triumph 6
J Steering Wheel Repair Austin Healey 32
Walter74 Adjustable steering wheel removal Austin Healey 4
D TR2/3/3A Shaking in steering wheel above 50 mph. Triumph 19
G Steering wheel offset Austin Healey 10
D Steering Wheel Repair Austin Healey 2
K For Sale TR3A Steering wheel Triumph Classifieds 4
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
Exotexs For Sale 1968 MG-B steering wheel and handbooks MG Classifieds 0
K TR2/3/3A Steering wheel Lock Nut? Triumph 2
R TR2/3/3A Frozen Steering Wheel [Adjustable] Triumph 7
S Steering Wheel Side to Side Movement Question Austin Healey 6
Ripper01 SOLD-TR6 Steering Wheel for sale Triumph Classifieds 2
K TR2/3/3A Making your own steering wheel stator tube? Triumph 16
BoyRacer Steering Wheel Location with non-adjusable column Austin Healey 6
Zitch For Sale Les Leston Wood Steering wheel with Triumph hub and boss Triumph Classifieds 0
BoyRacer Wanted Steering Wheel Hub Adaptor for non adjustable column Austin Healey Classifieds 1
Gliderman8 TR6 Corona boredom relief - Steering Wheel Bushings Triumph 6
S Wedge tr7/8 quick release steering wheel Triumph 0
K TR2/3/3A The 3 Steering Wheel "Grub Screws" and the Control Head. Triumph 2
R Wanted wood steering wheel Jaguar Classifieds 0
K TR2/3/3A The Steering Wheel Nut Triumph 20
AUSMHLY Adjustable steering wheel removal Austin Healey 5
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
angelfj1 TR2/3/3A How to restore a bluemels steering wheel Triumph 2
