Well my Midget made it home... Need Help!
RickB
RickB
Re: Well my Midget made it home...
I'll feel better after an oil change, can't remember the last time and I may have crud in the old oil after the head R&R. Going to take it easy until I have fresh oil.
Gundy
mrsprite said:
Gundy said:
Just curious...what is that engine's redline?
80 HP for starters sounds sweet!
I'm not sure what a stock A15 redlines at, but with the GX head (has double valve springs) 7000+RPM's is not unheard of. Get a bigger cam and they can spin over 8000 RPM.
80+ HP makes driving a Spridget entertaining....well, more entertaining than it already is. :smile:
I hear that! My BE is on the + side of 80 hp and it is more
fun than a barrel of monkeys! It's modified just a bit. :wink:
Billm
Here is a shot of that head for Kurt:
BillM
RickB
RickB
crud - front carb started pouring gas out it's vent - gotta go look at that now...
G
Looks allot like the 1500 head. Must be nice to have a motor you can spin w/o having to worry it's gonna go BOOM. What all does it take to put an A15 in a spridget? (just wondering)
nomad
Rick: A warning! Check out the 1200 datsun wiki on heads and make sure yours is oiling the valve train correctly now. Seems the GX head is for the early engines and they oil differently than the late.
Info I have shows the smog A15 datsun as only a little more powerful than the 1500 bmc motor. I believe it is considerably tougher though. As to fitting it, it is not a drop in. Not too bad in a 1500 midget though since you have the correct rad and crossmember mods already. Then it is a motor mount and intake and exhaust routing problem. Also pan clearance, Datsun trans we already are using.
Thanks for the pic's, Bill, I think I want it. Meet with you off the list.
Kurt.
RickB
RickB
Right you are, I've actually got a later head not a "true" gx.
It's the H72 and came with smog equipped cars.
Pull that crud off and plug some holes and you've got a good head that works with the later motors.
Believe me, I spend considerable time on the Datsun 1200 Wiki.
G
Hey Rick, what heads am I supposed to keep an eye out for? Is yours rare? I've found two 210's and was wondering if anything was worth saving off of them.
mrsprite
My Bugeye is mostly stock....not any real hacking done to get the A15 in there, but the rail where the steering rack mounts was cut out and reinforced to make room for the crank pulley. Also new motor mount brackets were welded in.......other than that, the body/chassis is stock.
To clear the front crossmember, the oil pan was cut and modified to fit. I also have a remote oil filter (huge 1 quart filter) to make up the lost volume and because it is impossible to fit a filter in the stock location on my car.
The transmission fits using the stock trans bolt holes (has what appears to be a custom trans mount & bracket). The driveshaft is modified too.
The PO did a nice job on the install......it's pretty clean. I am debating keeping it or installing a newer twin cam engine......it's a toss up because rebuilding the A15 like I want will be more expensive than a low mile 4AGE black or silver top will cost and I'll never see 160HP out of the A15. I guess I will cross that bridge if/when the A15 lets go.
As for what to look out for.....head-wise you want closed chamber oval port heads (heart shaped chambers). The 1200GX was never imported into the US, but a few made it here anyway. Nissan sold a similar head through there performance division that will fit later engines (my Bugeye has this head). A run of the mill 210 will probably not have this head, but you never know. If you find one with twin flat top Hitachi SU clones then it is probably a GX or performance head. Grab it and you can make a few bucks.
RickB
RickB
Front carb leaking gas out overflow.
I pulled it and flipped it over and took it apart.
It already has a plastic float.
The float valve seats and shuts off, I put it back together and the thing is still pouting gas out the overflow pipe with the key on.
Either the float has a hole in it or it is sticking.
I'll have to take it apart again tomorrow.
mrsprite
That's no good....I hope you figure it out. BTW.....what do you want for that Datsun tach??
RickB
RickB
that's just a picture I got at datsun1200
So... how is the float oriented in the car? I'm still concerned about the angle of the carbs.
RickB
RickB
Thought about that, but the back one is working fine at the same angle.
These don't have to be level and plumb to work - right?
G
I don't know about the HIF's ,b ut a float 'pposed to be level most of it's life. I could be causing your problem. It could be a bad viton tip on one too. What's the throat size on those?
RickB
RickB
The throats are 1.5 inches.
I was also thinking it could be the tip of the valve, it looks like black rubber - maybe it's shrunk?
When I took it apart I hooked up a tube to the fuel inlet and blew in and air would flow with the float down and stop with the float up.
Deleted member 8987
Ground.
Jags have them, too, but in the bottom of the intake on a 2.4L.
Bikes used to have them, so you could "tickle" the carb before starting and not get gasoline all over the coil.
The purpose is to get any leaks away from exhaust, starter motor, spark, so you don't go "BOOM!".
Did you take the float valve seat out and make sure nothing is stuck in the throat holding the tip open?
Usually, pulling the bowl and emptying it, then re-starting will flush small shXt out of the seat and off the tip.
What was in the bottom of the boawl when you took it off?
Did you shake the float next to your ear and listen for "slosh"?
Need me to make a high-speed run over there?
RickB
RickB
I have to take it apart again today after work.
I'll follow your instructions, could easily be something in the seat.
Wish there was someplace local to get parts & pieces for these.
Boink Last Midget Made Spridgets 10
G Midget Cobra? Who made this? Spridgets 19
D Trying to get back working on the 1974 Midget Spridgets 11
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
B For Sale '69 Midget MG Classifieds 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
D I have doubled the value of my MG Midget. Spridgets 2
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
A 78 MIDGET BUMPERLESS Spridgets 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
D MG Midget 1275 rear oil seal. Spridgets 0
D Engine Colour for a 74 Midget. Spridgets 8
B 1977 Midget Bra Spridgets 9
B Midget Differential Capacity Spridgets 5
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
G Best fuel option for a 72 Midget Spridgets 5
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
NutmegCT General MG MG Midget on Route 66 MG 3
D Back on the Midget after a vacation and work break. Spridgets 48
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
AngliaGT For Sale MGB /Midget Wooden Shift Knob MG Classifieds 0
J Midget front shocks Spridgets 4
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
M MG Midget decoding Spridgets 1
JPSmit 60 years - Mg Midget Spridgets 0
M 1972 Midget Seat Belt Replacement Spridgets 4
D MG Midget in distress. Spridgets 155
D Is it a 1965 or a 1966 MG Midget? Spridgets 2
G 79 Midget 1500 overheating Spridgets 2
G 79 Midget Clutch issues Spridgets 9
