Vent Window Rubber
jhorton3
Does anyone have a way of getting new rubber seals back in a vent window frame?
Platinum
I've never had trouble just putting them in by hand... stuff the things in the channels. If a bit of "nudge" is needed, a popsicle stick works well as a tool.
jhorton3
jhorton3
The rubber that was in there was really hard to get out. I used a screwdriver and needle nose grips to take it out piece by piece. I'll see if I can round up a popsicle stick. Wondering if I take a bit of dishwashing liquid if that would lubricate it enough to fit easier?
tony barnhill
Great Pumpkin - R.I.P
Yep, something liquid & saopy to help it slide....I think the real problem is size - you're working with something small in a tight, tiny place (with just a few corners!).
I have a plastic orange peeler that I stole from the kitchen drawer. They are the perfect size/shape/stiffness for such jobs. You might use glycerin instead of dish detergent so that you do not have a sudsing problem later.
Platinum
Glycerine is "lube-of-choice" here as well, but I wouldn't think it necessary for the wing window seals.
Trev! I LIKE the plastic orange peeler thingie, BTW! <slopes off to th' kitchen> /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
jhorton3
jhorton3
I got a small plastic putty knife from Ace. Put some soap on the backside of the seal and started working my way around. It did very well. Now I've got to find the body to vent window seal I have around here somewhere and I can reattach it to the car.
Bayless How to repair broken vent window studs? Spridgets 1
T Early BJ7 Vent Window Seal Austin Healey 2
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
A PLATE, handle locking on Vent Window Austin Healey 0
P Rivets on windshield and vent window frame. Austin Healey 1
B BJ8 vent window collar fused on Austin Healey 7
N GT6 GT6 I II III Series rear vent window sizes Triumph 4
healeydan BJ7/BJ8 Vent Window Corner Block Austin Healey 13
jsfbond Vent window install Triumph 2
N Vent window screws Austin Healey 1
R Vent window handle spins MG 0
T Door side vent window Mlll Midget Restoration & Tools 4
Woodie remove a vent window Spridgets 9
J Vent window attachment on BJ8 Austin Healey 12
V 65 Sprite vent window removal Spridgets 10
Jim_Gruber Pics of Windshield Seal to Vent Window Frame Spridgets 7
B LH Vent Window Removal MG 23
Jim_Gruber Vent Window to Windshield Gasket Length Spridgets 5
G Driver's vent window/windscreen gap ... MG 5
A Vent window & waist moulding sealing correct BJ8? Austin Healey 6
Baz MGB-GT GT Vent window MG 6
T Vent window seals MG 12
Jack_Long Vent window attachment MG 12
Velox Vent Window Restoration Austin Healey 1
A vent window seal replacement Austin Healey 0
78MGB How To Replace Vent Window Seals??? MG 7
H Vent window post removal question MG 5
tinman58 TR2/3/3A Vent tube Triumph 3
M 1275 Timing Cover Vent Spridgets 2
T TR2/3/3A Vent lid Mechanism Triumph 6
B For Sale BaulyCars - Scuttle Vent Cover Triumph Classifieds 0
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
D BT7 Air Vent Control Cable Routing Austin Healey 0
B Roof vent position on BN7 hardtop. Austin Healey 15
C TR2/3/3A scuttle vent Triumph 6
M TR6 Tr6 fresh air vent replacements Triumph 1
T TR6 Air vent rod connection Triumph 1
S TR2/3/3A vent lid rubber Triumph 11
D Austin Healey side rally vent Austin Healey 10
AUSMHLY Hose, vent pipe to air cleaner, BJ8 Austin Healey 7
P Help With Side Vent Glass Removal Austin Healey 7
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
M TR2/3/3A TR3 Valve cover vent oil leak Triumph 8
HighAltitudeTR3 TR2/3/3A Vent Tip... Triumph 16
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
T TR2/3/3A Is this overdrive vent sufficient? Triumph 3
N TR2/3/3A TR3 Scuttle Vent Triumph 15
N TR3 scuttle vent FORUM Navigation Questions 1
S TR2/3/3A Smoke coming out of crankcase vent? Triumph 21
Rut TR4/4A Defrost vent finish Triumph 3
