Ultra-rich Fuel Mixture and Flooding Inlet Manifold Drains
Walter--
In your initial post you said you "recently revised" the engine. Were any of those revisions related to the fuel system?
Have you actually fitted the fuel pressure regulator and if so what did it read when you decided "it did not solve the issue"?
Did you try to adjust the pressure down and if so what was the result?
Have you followed Red's suggestion of checking the fuel level at the jet bridge?
Have you considered fitting an SU pump?
All the suggestions sound good, but if you think there might be any debris in the carbs at all, you could try flushing them out. disconnect the fuel lines and run the engine until you burn all the fuel in the carbs and the engine dies. Then squirt a can of carb cleaner into the carbs and lightly tap a wrench on the bottom of the float bowls. The vibrations should free up anything sticking. You can also try blowing a little compressed air into the carbs (20lbs pressure or so). Reconnect everything, start it up and see if it improves. I had to do it twice before everything on my strombergs loosened up.
Walter--
i installed a revision kit on the carbs and changed the old fuel filter with a new one. Also all fuel hoses have been replaced.
I fitted the pressure regulator and regulated back to 2 psi there was still dripping fuel from the inlet manifold drain and the mixture was ultra rich. Fuel level at bridge was not visible in jet.
I disaasembled both carbs and cleaned every single part, but i will try this method just to see if it helps.
Hi Walter--
Thank you for you reply. Mixture and fuel level are separate issues but putting mixture aside for the moment I am at a loss to understand how, if you are making this observation with the ignition on and the pump is energized, fuel can be escaping from the manifold drains and yet not be visible at the bridge.
Since nothing else seems to have an effect I'll throw a couple SWAGs out. Since the problem appears to be with both carbs, I'd want to take a close look at the float valve installations. With needle valves, I've always been concerned that if the float lever isn't 'just so;' i.e. perfectly flat between the hinge and the spoons on the end the needles could get cocked sideways in the valve body and not close completely (if the hinge isn't set correctly the floats could drop far enough to cause this). Also, since needle valves are spring loaded there's some possible difference in setting; i.e. did you set the correct angle of the levers (516" on some cars; 7/16" on others IIRC)? The flat part of the levers generally end up parallel to the lips of the float bowls. Was the depth set with the damper spring compressed, or not? I've never seen an official explanation of why there are springs in the needles, but eventually came to the conclusion that they are used to damp the bouncing of the float bowls to smooth fuel flow. Therefore, I've always set the depth with the springs compressed, since fuel flow won't stop until the springs are compressed and the needle seats are seated.
Other than that, we really need to see photos of the jets in the bridge--dashpots removed, of course--with pump running so we can see the depth of the jets in the bridge and the fuel level. With a stuck 'choke'--jets stuck in the lowered position--the fuel level could be above the top of the jets, and you would get flooding.
