Tri-Carb Project
BigGreen
Fit and remove ... to avoid problems after painting
Healey Nut
Healey Nut
The grill surround is just sitting there so that the painter can make sure any filling he has to do doesn’t affect the fit of the surround .
Healey Nut
Healey Nut
I declare my hardtop as complete , my next task is to make up a new dash pad , as you can see the old one is a little tired . Paper template kinda sorta made up , I will rough cut it out then make some adjustments and shape changes by matching it to the car once I get it back from paint .
I will reuse the original front bow with rubber pad along with the de mister vents and just replace the plywood , vinyl etc .
The car is in primer right now and getting its final blocking out etc before her coat of Healey Blue .
Healey Nut
Healey Nut
So here she is in Urethane primer before final blocking and paint .
dougie
Can you start to see the finish line....:giggle:
Healey Nut
Healey Nut
Not yet but it’s come a very long way from the decrepit state it was in when I bought it as an abandoned project in numerous boxes.
Healey Nut
Healey Nut
So I went to see the car yesterday , all the wings/fenders doors have been off the car and back on so my custom fender vent grills and the stainless beading could be installed . My painter paints the joint edges of the fenders and allows some overspray on the top edge of the fender . They all then get refitted with the beading in place . The plastic film gets removed and the beading masked with masking tape . Car now gets painted and the colour blended to the overspray at the beading . Car gets clearcoated and masking on the beading removed before the clearcoat sets up . This is the way he did my other two Healeys and it works great . No risk of scratching new paint installing beading .
So hopefully this week the car will get its final coat of Healey Blue .
Today was windshield assembly day , original glass , rechromed original frame , new corner brackets and seals etc .
It was fiddly and a challenge but patience perseverance jigaloo and ratchet straps paid off .
Healey Nut
Healey Nut
So finally she’s painted , my painter just sent me this . Needs a few days now just to set up and I can bring her home to do the pretty stuff . The finish line is in sight 👍👍
Healey Nut
Healey Nut
So I got the car home yesterday (Sunday) , got her up to a nice working height on my custom Dolly blocks . Gave her a good cleaning that sanding dust gets everywhere .
Started to add some parts , she’s looking like that little rally car already .
Healey Nut
Healey Nut
Busy couple of days . It seems like everything is a bit of a chore , take this bit off to put this bit on and of course nothing fits exactly as it did in mock up but I’m getting there .
Of course I’m discovering that no matter how much planning I did I’m still missing little stuff .
Healey Nut
Healey Nut
It’s the little touches that count .
This vintage switch panel has been kicking around in my parts bins forever . It came in a box of spares with my first Healey 20 plus years ago .
All I had to do was build a little rally car with lots of lights to use it . 😁.
I need to find a source for the tiny bulbs , they are like screw in xmas light bulbs . Even I don’t get them working they still look cool .
They all have bulbs in them but only one of them is good .
Im on the hunt for a pair of those Vintage rally stopwatches to mount on the dash too .
Healey Nut
Healey Nut
Tks Reid . The chrome has just the right amount of Patina , matches the period cigarette lighter notice the white metal has those tiny bump like blisters that white metal gets with age .
HealeyPassion
It's lookin' great!! Congrats on getting to this point!! The end is in sight... sorta if you use a long lens!... which I tend to do!
Healey Nut
Healey Nut
Another part of the journey completed . Full leather no vinyl from AH Spares .
Healey Nut
Healey Nut
More progress pics . carpet underlay done , rear seat delete carpet area done . Some finish details done . Need a break from the glue fumes for a bit .
Healey Nut
Healey Nut
The stuff on the floor has a rubber granular backing and is more durable and is supposed to be like the original (came from McGregor) , the other stuff is just regular jute and I had a pile of it as it gets used as a protective shipping wrap on the machines I install/service so it was FREE!!!!!!
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
D Tri carb: order of installation question. Austin Healey 5
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
D 62 tri-carb upper fulcrum pins Austin Healey 4
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
lbcspinners 1962 Austin-Healey 3000 Mk II BN7 Tri-Carb 2-Seat Roadster: for sale on BaT Austin Healey 2
D Grose valves / Tri-carb Austin Healey 11
D Tri-carb PCV valve Austin Healey 61
D 62 tri-carb fuel line connection Austin Healey 10
C Tri carb Austin Healey 7
T Tri-carb questions. Austin Healey 10
J BT7 [Tri-Carb] Restoration Upgrades Austin Healey 2
D 62 tri-carb tuning question Austin Healey 8
D BT7 Tri-Carb Distributor Cap Austin Healey 9
D BT7 tri-carb linkage set up Austin Healey 23
D BT-7 tri-carb Two more questions Austin Healey 18
D BT-7 tri-carb ring gap Austin Healey 10
D BT7 tri-carb installing my crank Austin Healey 4
D 62 / BT7 tri-carb engine Austin Healey 16
D 62 tri-carb wiring harness Austin Healey 10
HealeyPassion Tri-carb intake manifold balance tube size Austin Healey 10
steveg Rare colored tri-carb BT7 on eBay Austin Healey 13
davidb AH 3000 tri-carb throttle shafts Austin Healey 13
W Barrett Jackson Auction 62 2 Seater Tri-carb only brings 48k Austin Healey 19
Norman Tri carb - overheating issue ???? Austin Healey 10
K Tri-carb help Austin Healey 11
K Tri-carb help please Austin Healey 0
AH67 62 MKII Tri Carb, done with some pictures Austin Healey 9
M WTB: Tri Carb Choke Linkage Parts Austin Healey 8
BoyRacer What are MK II [tri-carb] 2 seaters selling for? Austin Healey 12
D BT7 Tri carb Backfire Austin Healey 2
M Tri Carb Camshaft Austin Healey 4
B tri carb problems Austin Healey 17
B Gas mileage Tri-Carb Austin Healey 2
A tri carb on ebay Austin Healey 14
C Cold air box for Tri Carb 3000 BT7 ??? Austin Healey 9
G tri carb vapor lock Austin Healey 30
J Seeking tri carb help Austin Healey 16
M 100-6/ 3000 tri carb set up Austin Healey 13
Patrick67BJ8 Ruddspeed Tri-Carb Set-up Austin Healey 9
6 BN7 tri-carb will not start Austin Healey 7
6 BJ8-BT7 Tri-carb Conversion? Austin Healey 7
B PCV Valve Tri Carb Austin Healey 11
C Tri - Carb assistance ! Austin Healey 5
Dave Richards WOW! a "RARE" tri-carb Austin Healey 12
C AH 3000 Tri-Carb conversion. Austin Healey 4
V Choke cables for tri-carb Austin Healey 5
