Hi David,The only one I know of is in Alabama. He rebuilds them.
Where is it leaking from? The adaptor plate or the solenoid mounting plate?
David
John,If you are installing the o rings as per the diagram in the OD manual, then the shaft will leak. The o ring position in the diagram is on the wrong side of the plate. I figured this out by replacing the o rings 3 times, and finally removed the solenoid plate to install them where they belong...on the inside of the box.
I did add two fuses at the relay. Is there a way to check whether the relay is bad?The inexpensive ones work fine as long as you don’t short across the terminals with a multi tester. I did it twice while in a fairly advanced yoga position. I’m glad I didn’t do that with a $200 relay.
David, new question. I replaced the oil ring on the solenoid side of the O.D. ; took the housing off. That side no longer leaks. I have ordered a 6" 7/64" hard steel drill to try and get that #@&*( set pin out at the lever. I bent two hardened steel punches trying to knock it out. I tried to slip a extra "O" ring over the lever, still leaks.Thanks David,
It's DEAD! Ordered the cheaper one through Moss.
Dick
I assume I am trying to drive the tapered pin out correctly as the backside had a larger pin head and the front had a recessed hole where you could see the smaller end of the pin. I could not drive it out , through the hole in the lever and bent two hardened steel punches. I could not get my drill lined up with the hole, to close to the case. So, I have ordered 2 ea. 6" 7/64" hardened steel drills and will attempt to drill the pin out. This is nthe only place that is still leaking oil so have to change that "O" ring.David, Should the lever be in the position shown on your pic before it is actuated. And if I move the lever forward, should it stop lined up with the 3/16" hole?
Dick
I have a 7/64" drill/tap combination and plan to replace the pin with a screw?I assume you know that, as with the driver's side seal, the pax side also goes inside the box and not on the outside between the case and the lever? It goes inside the case between the case and the actuating cam. The drawings in the manual show the seal on the outside, which is not the correct location. I am not sure if the actuating rod can be removed from a fully assembled box to change that seal...but give it a try.
Also, the holes for the locator pins to set the solenoid will get you close, but after 60 years all the boxes are worn and will not likely operate correctly if you just put the pin in, set the solenoid and drive. It normally takes a tweak more open to get the boxes to engage and release positively. I set the solenoid by jacking the car and operating the OD with the wheels off the ground. Tweak the setting until you just get positive engagement, and that will give you a positive release too.
If you are force to drill the pin out, you will need a taper ream to repair the hole when you are done. If you bent the drifts, it likely means you are trying to tap a little off center...at an angle.
