[ QUOTE ]
What about the interior light controls and cigarette lighter? I do not want to mess those up? Is there a way to reach around? I see there seem to be 4 screws that hold that part of the dash togther. 2 below all the controls, and 1 near each knee pad correct? Also, will I have to hard wire the radio, or do it have a plug that will fit in to the back of the radio?
Thanks
Rod
[/ QUOTE ]
I'm not sure of the count for the screws, but that sounds right. As far as disturbing the other items, if you pull the console very carefully, you shouldn't have a problem. As far as the wiring goes, I imagine the new radio will have a different plug than the original. But as long as you follow the directions that came with the new one, It should all go together pretty easily.
