jclay
The sense wire might be intact at the terminal and everything looks to be working correcting correctly. Before you do anything else, go check the main leads behind the down pipe on the oil pressure sender side of the engine, the wires usually burn and fuse together along that run.
Once they start doing that they will burn in two.
No connection, over charge!
There is a service bulletin advising that you reroute the sense wire to the starter connection instead of to the battery line connector.
You can read what I have done here:
https://www.overhaulinforums.com/viewtopic.php?id=1533
Note that I replaced all the wires that go to the starter with heat resistant oven wire.
