TR6 tr6 suspension on a tilt
32chevy
lifted my moms new tr6 73 lifte and inspected the undercarrage when i lowered the car the right side seems to be higher about an inch. hasn't settled yet. what is the problem?
Aeroken
Roll the car 6 or 8 feet then roll it back and it should settle down nicely. The tires need to scrub outward against the ground a little bit to allow the suspension to compress the rest of the way.
Ken
G
The best thing you did for your Mom yesterday was join the BCF. Before you do any mechanical work on her car, check with these members. Just to be safe. :yesnod:
DougF
Were the wheels standing fairly straight before you lifted the rear end or was there a fair amount of negative camber?
EWD TR6 74 TR6 - suspension bushing tightening Triumph 1
F For Sale suspension upgrades TR6 Triumph Classifieds 0
G TR2/3/3A TR6 Front Suspension A-Arms on a TR3A? Triumph 5
P TR6 TR6 Suspension changes Triumph 20
Woodie TR6 TR6 suspension - Shocks Triumph 1
brgrmyster TR6 TR6 New Suspension Binding Triumph 17
R TR6 Front TR6 Suspension Question... Triumph 7
S TR6 Rear suspension TR6 Triumph 8
L TR6 TR6 Front Suspension Resto Project Part One Triumph 11
I TR6 This can't be good. TR6 front suspension rebuild Triumph 25
Gliderman8 TR6 TR6 Alignment / Suspension help Triumph 20
I TR6 Tinster's TR6 front suspension restoration part 1? Triumph 7
I TR6 TR6 front suspension rebuild suggestions Triumph 19
T TR6 Tr6 front suspension ? & downside of Cali cars Triumph 1
I TR6 69 TR6 suspension spring choice? Triumph 7
T TR6 TR6 front suspension re-bushing question Triumph 18
Aldwyn TR6 TR6 Rear Suspension Triumph 31
C TR6 Trying to put TR6 rear suspension back together Triumph 1
E TR6 TR6 Front Suspension... Is there a trick? Triumph 8
hondo402000 TR6 Air suspension for Tr6 Triumph 1
John_Mc TR6 Front Suspension Rebuild TR6 Triumph 16
Rob_T TR6 TR6 suspension springs Triumph 9
G TR6 TR6 front suspension in a TR3 Triumph 3
G TR6 Rear suspension [trailing arm] adjustment on a TR6 Triumph 18
jerrybny TR6 TR6 Suspension Triumph 11
J TR6 TR6 suspension Triumph 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
