TR6 Horn issue 1974 TR6
Pkdogg
My horns work until I insert the key and turn it to the first position, at which time the steering lock disengages causing the horn to stop working. Then, while turning the wheel in either direction, the horn will sound at approximately the four and 8 o’clock positions only. When I turn off the key and pull it out ( at which time the steering lock re-engages ) the horn works properly. So, it seems that the steering lock solenoid interrupts the connection. any thoughts as to why this would be?
Thanks in advance to all, Keith
Brighton Bob
There is a copper/brass ring that a spring loaded plunger contacts with when you press the horn button. I ordered the ring and plunger which had warn down figuring on replacing both. I replaced the plunger (easy) and not the ring (a PITA). Years later the horn is working fine. The plunger is the wear item that evidently isn't making good contact. If I was you I would just replace the plunger.
P
Pkdogg
Hi Bob, yeah i neglected to mention that i have replaced both of those items and they are working properly.
Thanks for your response
mezy
look for a bad earth on the steering column sounds as if the steering lock plunger when engaged is making the earth the horn should have.
Administrator
Boss
Welcome to BCF, Keith. As you posted a specific technical issue, I'm moving your post from our "New Member Introductions" forum to our Triumph forum. I'll leaver a "re-direct" link in the Introductions forum for a couple weeks. If you're reading this, you have now in the Triumph forum.
In the mean time, you can post another post in the Introductions forum just to introduce yourself and tell you a but about your TR.
bugedd horn issue....short?? Spridgets 4
B TR2/3/3A TR3A Horn Issue Triumph 12
bugedd Horn issue Spridgets 12
G MGB 78 mgb horn issue MG 8
P TR2/3/3A TR2 Horn Mounts Triumph 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
J MGB HELP, my horn does not work! MG 8
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Sopwith_Camel horn relay wiring Jaguar 3
K TR2/3/3A The horn and turn signal assembly. Triumph 3
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
D TR2/3/3A Traffic at or and horn button not working Triumph 2
P TR2/3/3A 6 volt Oogah horn Triumph 8
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
jehuie Morris Minor horn mystery British Motor Corp 12
Sixpack TR6 Horn Mystery Triumph 3
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
R Horn relay Spridgets 2
K TR2/3/3A The chrome ring around the bakelite horn button? Triumph 4
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
P TR6 TR6 Horn Relay Problems Triumph 8
S Indicator / Horn Switch Austin Healey 10
nichola TR6 Help me - circuit breaker above horn relay Triumph 5
nichola TR6 What is this, connected to horn relay? Triumph 8
Bayless Wanted: Spridget horn button bracket Spridgets Classified 1
71TR6 TR2/3/3A Control Head horn contact Triumph 7
71TR6 TR2/3/3A Windtone WT618 horn current Triumph 9
D TR2/3/3A Tr3 horn testing and wiring Triumph 8
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
D TR6 Replacing Horn insert in steering column Triumph 11
nevets BN6 horn button Austin Healey 17
C TR2/3/3A Horn Control replacement Triumph 3
Bayless Question on '67 horn button Spridgets 5
K TR2/3/3A Horn Button Removal Triumph 10
S TR2/3/3A Horn not working unless I rotate the control head Triumph 6
TRMark T-Series Horn/Dipper Switch MG 4
R German horn on BJ7 Austin Healey 8
K Is my BJ8 horn switch connected to ground positively or negatively? Austin Healey 3
longbridgehealey Horn question follow up Austin Healey 12
longbridgehealey 100-6 BN4 horn question Austin Healey 2
UmmYeahOk GT6 Steering Wheel Horn Troubles Triumph 11
K Restoring Horn Push Button Austin Healey 12
Jim_Gruber Intermittent Horn Spridgets 2
Joe_Healey TR5/TR250 Bubba Horn Triumph 0
G TR4/4A Horn Brush Question Triumph 7
edkap2002 TR6 horn brush Triumph 3
E TR4/4A Wiring the horn when installing a Moto -Lita steering wheel Triumph 4
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
Jim_Gruber In need of a really loud horn Spridgets 13
T Lucas HF 1748 horn parts Austin Healey 5
