Hi Kevin,
I've been pondering your vertical link issue all morning.
I don't believe you have a problem. But then, I'm not a
TR6 Expert mechanic so I could easily be wrong. My theory:
If you could easily turn the stub axle by hand BEFORE you
installed and decompressed the coil spring.......
then the trunnion is probably installed properly and so is the
Vert link to the ball joint. Peter K makes a good point with
backing off a flat.
The partially, uncompressed coil spring still has tremendous
energy stored in it. It is pushing DOWN on coil spring pan and
pushing upward on the ball joint. That energy tightens the
ball joint and tightens the vertical link threads against the
trunnion threads; making it difficult to rotate the stub axle.
Place a small jack under the front edge of the coil spring pan
and raise the spring pan a small amount. Install the new shock
absorber inside the coil spring (you may have to raise the
coil spring pan a bit.) Tighten the new shock top and bottom.
Just for fun, try to move the stub axle now. It should be easier.
Now jack the spring pan up about an an additional 1 inch. The
stub axle should move even more easier. Now, gently lower the
jack and proceed with installing the steering components.
I don't think you have a problem but the Triumph Experts will
jump in real fast and correct any blunders I may have stated
in my theory about your why your vertical link is not yet
smooth.
Don't forget to put a torque wrench on all your fasteners....
after the car is operational and you have driven it around
the block.
best regards,
I hope I have not offended anyone
by posting technical info in the Triumph forum.
dale
