TR6 TR6 starts, runs, then dies
mrbadwrench
I've just got my TR6 (sort of) running after 2-3 idle years. I've replaced ignition parts - coil, points, cap, rotor. I drained the gas and added new. It started and idled well for about 10 minutes, then coughed and died. Would not re-start. Couple of hours later, it occured to me it may have run out of gas. I added about a gallon. It started and ran fine for 5 minutes, then died again. Would not re-start. I appreciate any ideas.
Rob DeScherer
Definitely change the fuel filter. I thought that I nad a problem with my carbs, but it was a clogged fuel filter. While you are at it, you should probably by the rebuild kit for your fuel pump. There is probably a lot of junk built up in there as well.
CDNMGBguy
What state is your car battery in, when a car idles it relies to some extent on the battery to power the beast. Ditto starting up. If the battery, or the alternator are not functioning optimally the car may start then dies.
Brian.
John-Glen TR6 TR6 Only starts when being jumped Triumph 10
BierRunner TR6 TR6 Trunk Lock Striker Triumph 1
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
A For Sale 1974 TR6 Triumph Classifieds 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
JPSmit TR6 at lunch today Spotted 0
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
charlie74 ‘74 1/2+ TR6 Spotted 0
E TR6 TR6 flip-up bonnet question Triumph 4
Marvin Gruber For Sale 1974 TR6 for sale, $7200 Triumph Classifieds 3
